02-02-2011, 07:19 PM
#106 |
BITD/Rallye
Oddometer: 5,311
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
02-15-2011, 07:38 PM
#107 |
2 wheel rider...anytime..
Oddometer: 1,525
Greetings fellow riders. Thought I'd share with you my Guts Racing soft seat foam for sale ad, in case anyone is looking to soften up their seating area.
http://www.advrider.com/forums/showthread.php?t=659823
6th Gen VFR800, '08 KTM 690E, '05 CRF450X '96 XR600TT, '00 Bandit 1200, '01 TTR-150L |
03-07-2011, 01:25 PM
#108 | |
Oddometer: 1
I also have a 2005 crf450x
Does your bike have the emissions pump on it? I removed mine with a aftermarket kit (about 35 bucks), it stopped backfiring. I also changed my main jet to a 150 and my pilot to a 50. |
03-18-2011, 10:05 AM
#109 |
Sweet!!!!!!
Oddometer: 137
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return. |
03-19-2011, 06:37 AM
#110 |
some pics with my crf450x:
owned '07 Honda CRF 450 X - the beast '98 Suzuki DR 650 SE - first love |
03-19-2011, 06:39 AM
#111 |
from back
03-19-2011, 06:40 AM
#112 |
beside my DR 650
03-19-2011, 06:42 AM
#113 |
right side
04-01-2011, 11:01 PM
#114 |
Sweet!!!!!!
Oddometer: 137
07 crf450x
http://www.youtube.com/watch?v=iOHsdDOvlno
Test Ride on Johns Peak Oregon.
04-02-2011, 09:57 AM
#115 |
Oddometer: 22
More pictures! More information on increasing oil capacity, please.
Anybody have any cool shots of them riding their 450x in Colorado?
04-02-2011, 10:35 AM
#116 |
Sweet!!!!!!
Oddometer: 137
Race Prep CRF450X
Run additional oil in the transmission cavity. Instead of filling to the oil check screw level we fill to the bottom side of the threads, removing the aluminum plug used for crankshaft access, on the right side of the engine case.
Behind the left side cover there is a “natural” color main coupler. On the ECU side of this natural coupler there is a Pink wire. Underneath the Pink wire is a blank terminal plugged with a rubber cap. Swap the positions of the Pink wire and the rubber cap. Reconnect the coupler to the wiring harness. (in Modified form the Pink wire is not connected to any other wire). This allows an additional 1000 RPM’s before engine hits “rev-cut” and provides a completely different (more aggressive) ignition curve. Magnesium clutch access cover is easily punctured by the cleats on the rear brake pedal during a tip-over or impact with a berm. Be sure to file and round off the inboard cleats and sharp edges of the pedal, use a rubber pad attached to brake pedal top side, and/or consider an aluminum access cover to prevent oil loss. Opened airbox…as mentioned above follows guidelines listed in attached Honda WRENCH newsletter. This is a competition modification only. · Drill out the two pop rivets holding on the air snorkel and remove it · Cut the section shown inside the raised cut line while wearing eye protection. · Cut out the black “triangle” from the left side cover/air filter access door as shown below. · Reinstall the airbox and the sub frame. ![]() Straight from Honda's CRF desert Race book ![]()
04-05-2011, 03:24 AM
#117 |
Oddometer: 1,579
CRF450X has gone EFI for 2012 by looks of this
04-07-2011, 07:03 PM
#118 |
Oddometer: 1,402
CRF450r's aloud on here?
Should have less than 2k bucks in the rig once I get it on the road!
If I were president the first thing I would do is sign an executive order to formally change the name of 'Welfare' to 'Farewell' |
04-18-2011, 10:00 AM
#119 |
Sweet!!!!!!
Oddometer: 137
07 crf450x
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return. helipilot650l screwed with this post 05-05-2012 at 09:41 PM |
04-18-2011, 10:01 AM
#120 |
Sweet!!!!!!
Oddometer: 137
07 CRF450x On Johns Peak
