Old 01-23-2011, 02:34 AM   #241
Afterdark
Afterdark's Avatar
Oddometer: 357
Originally Posted by TaxMan View Post
say one was in BFE in the sticks and had to do an oil change, i guess i'd just lay the bike nearly on its side to fill it? come to think of it, maybe that's what i should have done!
This method has always worked for me, sometimes at home too.
Mark
Afterdark is offline   Reply With Quote
Old 02-26-2011, 04:01 PM   #242
wiayeman
Oddometer: 11
I did a search. If this has been covered, my apologies.
I changed the oil, burped it, rode around the block and...........
oil is pissing out of the frame plug. Do I just need a new crush washer or is it something more sinister?
If it is just the crush washer, can I go to any parts house and match it? OR, do I need to buy the KTM one.
Cheers
wiayeman is offline   Reply With Quote
Old 02-26-2011, 05:28 PM   #243
airgord
What am I doing out here!
airgord's Avatar
Oddometer: 835
Go match it, buy a few for your tool box, happened to me before.
Riff Raff 2011
airgord is offline   Reply With Quote
Old 05-09-2011, 10:34 PM   #244
Retromountainrider
Oddometer: 31
Did the oil change. Put in the required 0.6l, and startedup the bike, but no oil coming out of the plug. What now?
2010 Triumph Thruxton
2001 KTM LC4 640E
1993 Kawasaki KE100
Retromountainrider is offline   Reply With Quote
Old 05-09-2011, 11:44 PM   #245
makazica
makazica's Avatar
Oddometer: 705
I'm kind of feeling that you rushed into this.....take it slower....
So, you poured 0,6 L of oil into the frame and you poured 1,3 L into the crankcase, right?
Then you went to burp the frame. You started the bike. The bolt on the frame should just be just half a thread in. Put a rag underneath it. When I change oil and filters it sometimes takes like 30 or more seconds for the oil to start coming out. Sometimes I need to remove the bolt completely and wait for the oil to start coming out. If I remove the bolt, when the oil starts coming out, I shut off the engine, thread the bolt completely in. Wipe the oil that poured out and do it again, this time not removing the bolt completely. When oil starts seeping around the threads I call it good.
M.
ENDURO DALMATIA
LC4 Adventure parts for sale:
http://s485.photobucket.com/albums/r...%20for%20sale/
makazica is offline   Reply With Quote
Old 05-10-2011, 07:12 AM   #246
Retromountainrider
Oddometer: 31
I did exactly what you said here. But no oil Coming out. Maybe I didn't put enough oil in.
2001 KTM LC4 640E
1993 Kawasaki KE100
Old 05-10-2011, 07:24 AM   #247
gunnerbuck
I.Hopp.
Oddometer: 3,077
Did you give it 30 seconds or so of run time? Did you fill the spin on filter with oil?
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 05-10-2011, 07:38 AM   #248
Retromountainrider
Oddometer: 31
Wait. I got it figured out! Thanks for your help :). Appreciate it.
2001 KTM LC4 640E
1993 Kawasaki KE100
Old 05-10-2011, 10:37 AM   #249
Retromountainrider
Oddometer: 31
Yesterday when I fired up the engine I didn't get any oil coming out of the frame, this morning when I started the engine the oil came right out. Weird, I wonder what changed. Both times I let the bike run for the same amount of time.
2001 KTM LC4 640E
1993 Kawasaki KE100
Old 05-10-2011, 12:55 PM   #250
makazica
makazica's Avatar
Oddometer: 705
Air came up as it is lighter than oil....I reckon....
In future, just run the bike until oil comes out, no biggie!
M.
ENDURO DALMATIA
Old 05-10-2011, 02:22 PM   #251
Retromountainrider
Oddometer: 31
And I guess that would be why we bleed the system ;).
Thanks for your advice guys. I'm very new to duel sports and working on bikes in general. Always good to know people are willing to help on ADV rider.
2001 KTM LC4 640E
1993 Kawasaki KE100
Old 05-11-2011, 09:15 AM   #252
bmwktmbill
Traveler
Oddometer: 4,012
M.
Maka,
I learn something every day, I always burped with the plug completely out...makes a big mess.
thanks.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 05-11-2011, 09:21 AM   #253
bmwktmbill
Traveler
Oddometer: 4,012
M.
Maka,
thanks.
bill
Bill Shockley
Old 05-11-2011, 09:36 AM   #254
makazica
makazica's Avatar
Oddometer: 705
Originally Posted by bmwktmbill View Post
Maka,
thanks.
bill
I bet it makes a mess!
M.
ENDURO DALMATIA
Old 05-16-2011, 10:30 AM   #255
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,844
Originally Posted by creeper View Post
How to change the oil and filter on a KTM LC4
Additional information as of 05-07-06
After discussing the options, it's possible that the best way to burp the frame on an '02 and earlier 640 would be to install the filler bolt loosely in the frame, in other words, threaded in, but not quite all the way, then start the bike and wait for the oil to flow out past the threads. As soon as you see the oil, tighten the bolt... then shut off the engine.
Have a rag or two handy to soak up the oil that slides past... but if your quick about it, there should be a minimum of mess.
Truth be told, it may actually be the best way to do it on any year, as the hose trick is a little on the fiddly side of life
I too am guilty of not re-reading threads from time to time... and I've been bit worse than oil on the ceiling of the garage!
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 09:30 AM.
