10-19-2011, 02:58 PM
#256 |
Oddometer: 1,143
I was at my KTM dealer today with my 640ADV, to carry out an oil change and a valve check. (I did the job with the dealers supervision on me - we're kind of friends..)
However, he told me that I don't need to bleed the frame, only put in the 600ml oil, and thats it. I couldn't believe him (asked him three times), but I did that. Then I came home with the bike (~20miles), and realized that it has developed a knocking sound (it might just be my paranoia though).. Have I just messed up the conrod bearing? Do I need to bleed the frame? Is it too late already? Oil level in the sight window is OK, and it took about 2l-2.1l oil with the 600ml included in the frame. Thanks..
2005.5 950 Adventure Sumi screwed with this post 10-19-2011 at 03:40 PM |
10-19-2011, 04:52 PM
#257 |
BITD/Rallye
Oddometer: 5,309
paranoia probably...
But on another note ...just a friendly reminder.. check your sprocketbolts and countershaft bolts.. all of you... and since its a oil thread.. check your oil drainplugs
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle wrk2surf screwed with this post 10-19-2011 at 07:07 PM |
10-20-2011, 01:08 AM
#258 |
Oddometer: 1,143
2005.5 950 Adventure |
10-20-2011, 11:43 AM
#259 | |
Oddometer: 705
Oh, for God's sake! Does your owner's manual say that you have to "burp" the frame/oil system? Why do you think people around the world wrote how-do's for an oil change on a LC4? Maybe cause it's a bit different from many other bikes?? I'm sorry if my words come out a bit sharp......but if it's in the manual why would anybody not do it?? After all it makes sense to do it - if you understand how the oil circuit on the LC4 works..... At 20 miles you haven't developed a knocking sound related to not burping the frame, but at 350 miles you might, if an air pocket has developed in the oil system..... And BTW....what does your owners manual say about the oil quantity required by an LC4 engine? Cheers! M.
ENDURO DALMATIA LC4 Adventure parts for sale: http://s485.photobucket.com/albums/r...%20for%20sale/ |
10-20-2011, 12:02 PM
#260 | |
Oddometer: 1,143
Well, I kind of trust my KTM dealer as he already did probably more oil changes on the LC4s than all of us here.. But you are right, it's in the manual, to blurp it. That is why I'm in a doubt. Cheers!
10-24-2011, 02:40 AM
#261 |
viertaKTMotor *****
Oddometer: 155
Hi there,
just read something new about burping the frame. Short story: friend of mine bought a KTM Military 400 LS-E/Mil. I went to the dealership to aks them about any possible documentation as she intends to work herself on the bike. She wants to learn it if the need arises somewhere down the road to repair it. Anyway I have now an official engine repair manual from KTM 400 - nice reading. I began to trace any differences in the Repair Manual from my 640ADV Repair Manual. To my amazement the 400 Mil Manual states (in German) to fill the frame with 0,6 oil, tighten the filler plug with new copper gasket and to burp the frame by (Attention please!) loosening the bolt on the left (clutch side) engine cover. As soon as it leaks oil tighten the blt with 10 Nm. Here is a picture of the said manual: ![]() So… what do You guys think about it? Does it make sense? Is it the way we should do it too? Is the 400 Mil so different than 640 ADV? |
10-24-2011, 04:15 AM
#262 |
Oddometer: 5,643
Good advice. I limped back to camp on the second day of the Shenandoah 500 DS ride with only two sprocket bolts. I must have forgotten the Loctite when I was switching sprockets with my 200.
KTM 640 LC4E KTM 200 MXC XT200 |
10-24-2011, 12:50 PM
#263 | |
Trans-Global Chook Chaser
Oddometer: 2,699
It looks like both methods are doing the same thing - bleeding out air until the frame is filled with oil, just at different points. Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
10-26-2011, 08:05 PM
#264 | |
Oddometer: 1,143
Now my problem is, that it's leaking oil all over the frame / engine, it's a mess everywhere:) Is there a trick on that washer under the frame plug? Do I have to change it every time when I undo that bolt?
10-26-2011, 11:34 PM
#265 |
viertaKTMotor *****
Oddometer: 155
It was my problem too - are You sure that You don't overfilled oil?
10-27-2011, 03:16 AM
#266 |
Oddometer: 1,143
Yeah, it's not overfilled, and is leaking from the frame plug (the bolt where you fill the frame with oil)
10-27-2011, 03:53 AM
#267 |
viertaKTMotor *****
Oddometer: 155
Ten why not put a new copper ring there ;)
Eventually add a dab of hi-temp silikon to the last few threads just to be sure. |
10-27-2011, 07:06 AM
#268 | |
crash test dummy!
Oddometer: 2,059
625's and i think some of the 620's do the same thing. they are just bleeding the system in a diff place. on another note, the "adding 600cc of oil to the downtube" was not added to the manual until later models. previously it just said to dump all the oil into the case, loosen the "burp" bolt on the frame, start the engine and wait for it to come out. when it does, turn off the bike, tighten the bolt, and your good. many arguments have taken place about whether or not this is a good idea. does this cause wear on the top end? does it cause damage while waiting for the oil to circulate? or does it really matter? all i know is that i "inject" 600cc of oil into my downtube, then i burp it like the manual says. take that for what its worth.... laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW. '12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
10-03-2012, 09:50 PM
#269 |
Oddometer: 4
Creeper, much thanks for the write up! Picked up an 04 625 and am ready to change the oil this weekend. Should be a breeze now... or a mess to clean up. Although I think the guys at the local hardware store think I am building a meth lab, I kept telling them its a tool for an oil change
10-03-2012, 10:54 PM
#270 |
Traveler
Oddometer: 4,009
It's been said before...
Tighten the dipstick before starting the engine... Or prepare for a big fuckup oil explosion. bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
