Old 12-11-2012, 05:41 PM   #286
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 416
Originally Posted by Droptarotter View Post
No, you are not missing something...........IIRC, the spin on filter only takes about 100cc's when pre filling. Just pour in as much as you can and spin it on.
Cheers
Thanks Mate.....Appreciate the quick response
Conman62 in the "other world"......dirtbikeworld.net
The beatings will continue untill morale improves!
2006 KTM 525 EXC
LC4nicator is offline   Reply With Quote
Old 12-12-2012, 01:02 PM   #287
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 416
Sorry guys....another question....
If we are to fill the frame with 0.6ltrs & the crankcase with 1.3ltrs, why is the manual specifying 2.1ltrs?
Are they taking in account the extra 0.2 ltrs in the filter and lines?
Sorry to be pedantic however, I like to be certain of things.
Cheers.
2006 KTM 525 EXC
Old 12-12-2012, 05:18 PM   #288
Droptarotter
Oddometer: 833
The Factory lists the oil capacity from the motor never being filled. No matter how long you let it drain you will not get all the oil out.
So.....put 1.3L in a bucket......pour as much as you can out of the 1.3L bucket into the spin on filter. Pour the rest into the engine.Add .6L to the frame. Start, burp, shut off, tighten frame filler plug, recheck.
That should put the oil level a little above centre in the oil sight glass.
Hope that helps!
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 12-12-2012, 05:54 PM   #289
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 416
Thanks once again Droptarotter.
I suspected this to be the case.
Just looking for consensus I guess.
Cheers
2006 KTM 525 EXC
Old 12-12-2012, 10:42 PM   #290
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
Because the guide was written for Creeper's earlier-year bike with different values.You need to go through his guide cross-referencing your manual and adjust oil volumes and torque values to suit. This applies to all Creeper guides, indeed to any guide, any where!
I have annotated my paper copy in my garage "run book" and have also added the fastener sizes so I only have one point of reference: I find the torque value and the socket to grab from the one consolidated source. Makes life easier!
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf is offline   Reply With Quote
Old 12-13-2012, 10:36 PM   #291
bmwktmbill
Traveler
Oddometer: 4,015
Cheers
Why not use the dipstick.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is online now   Reply With Quote
Old 12-19-2012, 10:00 PM   #292
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 416
b
Sorry...just got back to this thread....
Unless I'm mistaken but there's no dipstick on my bike................and everyone can leave the comments about the rider to themselves!
2006 KTM 525 EXC
Old 12-20-2012, 09:49 PM   #293
bmwktmbill
Traveler
Oddometer: 4,015
'02 640a, dip stick is on the clutch case fill plug.
What does your owners manual say?
bill
Bill Shockley
Old 12-20-2012, 11:29 PM   #294
Alik
viertaKTMotor *****
Oddometer: 155
bill
Bill, he've got an 05adv. Since 2003 HF LC4 engines have a lurking window in the clutch cover.
Alik is offline   Reply With Quote
Old 12-21-2012, 09:44 PM   #295
bmwktmbill
Traveler
Oddometer: 4,015
No dipstick?
OK.
Stupid idea.
But use the window.
bill
Bill Shockley
Old 01-27-2013, 04:59 AM   #296
thanosktm620
thanosktm620's Avatar
Oddometer: 6
Hi guys
I have a question.
I have changed(for the first time alone) oils in my LC4 620 '97 but I forgot to drain the frame plug.
I filled in 2lt of oil(As I was told in the KTM dealer)but now the oil level is above max.
What should I do?Leave it until the engine spit the oil in airbox,remove some oil or do the procedure again from start?
thanosktm620 is offline   Reply With Quote
Old 01-27-2013, 05:55 AM   #297
gunnerbuck
I.Hopp.
Oddometer: 3,078
Originally Posted by thanosktm620 View Post
Hi guys
I have a question.
I would drain out the oil and refill with the proper amount, I know on the newer models the engine gets 1.3 L while the frame takes 0.6 L, yours is probably the same...
You could also just remove the dipstick and lay the bike on its side to drain out just enough oil to bring it to the correct level...In the future remember that if you don't drain the frame you still will have 30% dirty oil running through your engine...
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 01-30-2013, 12:16 AM   #298
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,169
Old models are 1.3 + 0.6, newer ones are 1.5 + 0.6. /pedant. ;)
Get a big syringe extended with a bit of plastic tubing and suck the excess out through the oil filler.
Have you run the engine yet?
Cheers,
Colin
Cheers,
Colin
Old 01-30-2013, 12:58 AM   #299
640 Armageddon
640 Armageddon's Avatar
Oddometer: 440
Hi guys
I have a question.
+1 on getting it out of the system.
Otherwise just wait for it to get burned
As Colin said, use a syringe with an extension to suck the oil out of the engine. Easier and cleaner.
D.
Work like you don't need the money
Live like there's no tomorrow ...
640 Armageddon is offline   Reply With Quote
Old 01-31-2013, 01:19 AM   #300
thanosktm620
Oddometer: 6
Cheers,
Colin
D.
Colin....I just run the engine around the block for a couple of minutes.
I was thinking to remove the extra oil by the frame plug,but your way is more easier and cleaner as 640Armageddon said.
Times are GMT -7.   It's 10:32 PM.
