01-31-2013, 06:29 PM
#301 |
Traveler
Oddometer: 4,014
Loosen the oil filter...retighten. run, repeat.
bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
02-07-2013, 06:57 PM
#302 |
I.Hopp.
Oddometer: 3,078
Hi Flo Filters
I have been using Hi Flo filters from day one on my 640s mainly because of economics... The OEM spin on filters through KTM are priced around $25 and the paper filters about $10 which adds up to about $35 combined... I buy the Hi Flo filters in bulk and can get 3 of each {6} for the same price... If you are looking to do the same I found that these guys have good prices on Hi Flo filters and will soon have a proper website up: http://www.classiccycleparts.com/
640 A x 2 |
03-01-2013, 11:00 AM
#303 |
Oddometer: 6
Hey guys, I have recently changed my oil and apparently made the mistake of putting too much oil in. I discovered this when my 98 620 LC4 started running poorly after about 150 miles. BTW when it began running poorly there was a significant amount of oil in the air box. I have since drained the oil to the proper amount but the oil smells of fuel and seems awfully thin. Do you recommend just starting over with a fresh oil change and new filters? Or am I screwed?
03-01-2013, 02:26 PM
#304 | |
Oddometer: 833
If the oil smells like fuel, I would change it again. How did you get fuel in the oil??? You are not screwed........it's nothing that time and money won't fix. Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
03-01-2013, 03:01 PM
#305 |
Oddometer: 6
That's what concerns me. From my understanding, fuel has no place any where near oil. Money is something I have access to, time however is a different story. Which leads me to my second conundrum; if I have no time, is it worth fixing? Things to think on I guess.
03-01-2013, 03:13 PM
#306 |
Oddometer: 65
it really warms my lc4 powered heart to see that this thread is still active
![]() i have the instructions printed, and still use them. granted i have only put about 11k miles on my 625SMC
05 KTM 625 SMC 09 KTM 200 XCW 00 KTM 200 MXC |
03-01-2013, 09:55 PM
#307 | |
I.Hopp.
Oddometer: 3,078
640 A x 2 |
03-01-2013, 10:25 PM
#308 |
Oddometer: 1,235
What gunner said. If the petcock is open while the bike is off and the float valve leaks, gas drains and overflows through the carb and past the piston into the crankcase. If your oil smells strongly like gas you should change it and fix the cause. Remember, your oil is now as flammable as gas so be careful around sources of ignition!
Sent from my SCH-I535 using Tapatalk 2 |
03-02-2013, 09:50 AM
#309 |
Oddometer: 6
Thanks guys! This actually makes a lot of sense. The bike has sat longer than expected and I did not properly prepare it for storage. For the time being i am going to drain the fuel, then when I have some spare time I will change the oil and clean the carb and fuel tank. Thanks so much for the advice.
03-02-2013, 07:30 PM
#310 |
Traveler
Oddometer: 4,014
Replace the rubber tipped needle and the O-ring,
set the floats. b
03-11-2013, 03:07 PM
#311 |
bantu
Hi Guys - im a new lc4 adventure owner and decided to do an oil change. all went well but i just have two questions which ive searched the answers for to no avail. i filled it up with motorex oil and the oil through the sight glass is still black. should i flush/change oil again or is this normal. i did get the oil hot and drained it properly and changed all the filters. secondly - when the motor runs what should one see in the sight glass? i see oil slowly pulsing down the window. seems the oil is circulating which seems good to me - just want to be sure this is what should be happening. any advice will be appreciated....
03-11-2013, 03:19 PM
#312 | |
Trans-Global Chook Chaser
Oddometer: 2,703
Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
03-11-2013, 03:24 PM
#313 | |
bantu
