Old 10-31-2007, 07:21 AM   #121
nyc_gs
Lurker
nyc_gs's Avatar
Oddometer: 241
Afraid of that...
Originally Posted by meat popsicle
Jason,
That copper washer (soft metal) is what helps mate the drain plug to the case and seal the drain. Perhaps yours has sealed without it but I would keep a watchful eye on your oil level. Some might say you had better replace it; can you get some friends to help you turn the bike upside down to replace it without loosing your new oil? Remove your mirrors and watch the fairing and
That's what I was afraid of. :(
Guess I'll be back in the garage tonight dropping the oil again to replace that washer. Man that sucks.
I'm assuming if I drop all of the oil from the bottom I can stick to filling just the crank case with 1.3-ish liters of oil, yeah? The 600 ml will still be in the frame so I'm thinking 1.3 is going to be fine (maybe a little under) to re-fill. I can then top-off as needed. Just don't want to overfill.
Thanks for the input, much appreciated.
-- Jason
nyc_gs is offline   Reply With Quote
Old 10-31-2007, 08:53 AM   #122
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,242
Maybe you are already going to do this, but if not you should be able to drain the case, replace the washer, and then refill the case with the same (yet new) oil. You have a clean catch basin?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 10-31-2007, 08:57 AM   #123
nyc_gs
Lurker
nyc_gs's Avatar
Oddometer: 241
Ah...
Ah, ha. No, I had not even thought of that...good idea. I do have a clean catch basin, however, I'm one of those guys who always errs on the side of caution, so I'll just put in new.
Never know just how clean that catch basin really is...
Thanks again, great info and suggestion.
-- Jason
Old 11-01-2007, 07:39 AM   #124
nyc_gs
Lurker
nyc_gs's Avatar
Oddometer: 241
Out with the old...
I dropped the oil again last night and added new copper washers to both drain plugs. All seems good in the world again.
Surprisingly, at least to me, was that not that much oil came out when I drained the two drain plugs from the bottom. Only about 600-700ml, not 1l+ that I was expecting.
However, it now has new washers and new oil (again) and all seems good.
Thanks for the input.
-- Jason
Old 01-23-2008, 08:20 AM   #125
flux_capacitor
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,631
I just wanted to chime in and say thanks, Creeper, for this how-to. It made my life pretty easy and mess free. I was a little anxious about my LC4's first oil change but with this guide printed out it was cake. Speaking as someone relatively new to wrenching, it is nice to find someone who understands that not everyone is fortunate enough to have been working and riding bikes their entire lives. Everything in the change went according to plan. I am used to getting oil everywhere from my days of owning an RFS...this seemed so much easier once you do it.
And, thanks to Meat Popsicle for indexing all this info...I am sure it has been a chore!
Anyway, just wanted to let you both know your work is appreciated. Thanks.
flux_capacitor is offline   Reply With Quote
Old 02-20-2008, 02:03 AM   #126
redgoat
redgoat's Avatar
Oddometer: 4
Very nice technical writeup Creeper! Thanks! BTW what weight oil do you use for your 640?
redgoat is offline   Reply With Quote
Old 02-20-2008, 08:55 AM   #127
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Me and Meat say... your welcome. Your the guy we did it for... and redgoat too.
Thanks... Motorex, Repsol or Mobil 1 15/50 "red cap"... which is now "silver cap". I don't have the 640 anymore, but I still use the same oils in my Sherco... in fact, I just put the last of my Motorex stash in the Sherco yesterday. Next oil change will be Mobil 1.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 03-19-2008, 10:11 PM   #128
PaulDuke2
Oddometer: 9
Great write up Creeper
Just done my first change on an 03 Duke 2 .
The burping may be to show that the oil pump is working .
BSA watch return to tank . Yam. Verago loosen screw on top filter house ,
run engine till oil shows , close screw.
paul
PaulDuke2 is offline   Reply With Quote
Old 04-07-2008, 06:50 PM   #129
lowes48
lowes48's Avatar
Oddometer: 229
Thanks Creeper!
Hey guys,
Just did my first oil change on the 2000 Duke 2. (My first, not the bike's!) Anyway, thanks to Creeper for the step-by-step instructions and to all the others who had helpful suggestions as well. The "start it and wait for oil to seep out the fill hole" trick was way easier than fooling with all those bottles, hoses, etc... I'm using Rotella this time, but that is another story for another thread... Thanks again for the helpful write up and I look forward to more DIY help on the Duke 2!
lowes48 is offline   Reply With Quote
Old 05-11-2008, 08:07 AM   #130
motorad666
Oddometer: 8
Oil change question on 2007 640 Adventure
Thanks to Creeper's awesome confidence inspiring how-to, I am about to embark on my first oil change on my 640 (not the bike's). One question for anyone out there relates to the "in with the new." The process in the KTM owner's manual is obviously written and laid out in a way that a novice like myself will screw it up and have to do it twice. I only want to do it once, so I have this question. After draining the system, the manual describes replacing the fine screen filter on the frame breast pipe, followed by this: "remove screw connection on the clutch cover, fill with 1.3 liter engine oil and attach plug again."
I assume they are referring to filling the crankcase with 1.3 liter through the filler plug, right?
Sorry for the dumb question.
Motorad666
motorad666 is offline   Reply With Quote
Old 05-11-2008, 09:36 AM   #131
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Motorad666
That would be the rough translation from Austrian to English... yes.
C
So... how's tricks?
Old 05-11-2008, 11:39 AM   #132
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,326
C
Not to be a hairsplitting dick, but there is no "austrian" language..
rumor has it they speak german
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 05-11-2008, 05:33 PM   #133
meat popsicle
Ignostic
Oddometer: 14,242
Sometimes when those Australians speak I have no friggin' idea what they are talkin' about... And hairsplitting dicks say they speak english.
Old 05-11-2008, 06:13 PM   #134
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
So Laro-buddy... you've taken over for ChrisC all together, or your just the acting HSD when he's indisposed?
So... how's tricks?
Old 05-11-2008, 07:19 PM   #135
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,614
C'mon meat-pops, repeat after me:
A U S T R A L I A: a large island continent west of New Zealand
A U S T R I A: a country in Europe where Hitler was born
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Times are GMT -7.   It's 01:07 PM.
