Old 02-09-2013, 05:48 PM   #541
neduro OP
Addict
neduro's Avatar
Oddometer: 11,941
Originally Posted by Motoriley View Post
Any news from the RAM folks when these will ship in the right size?
They keep telling me they aren't going to make them. Which, in my opinion, doesn't mean they aren't going to make them, it means they haven't yet.
I'll keep checking...
Spud rider- interested to hear the results!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 02-09-2013, 06:47 PM   #542
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,683
Tough nuts
They are making the 1" in other sizes so I guess I'll have to get creative!
http://www.rammount.com/CatalogResul...9/Default.aspx
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 02-09-2013, 08:50 PM   #543
Spud Rider
Spud Rider's Avatar
Oddometer: 3,762
If you really want to employ the Ram Tough Balls, you can use them right now, provided you don't mind adding 20mm to the length of the mount from the mirror perch.
The RAM Tough Balls are currently offered with an 8mm thread.
http://www.rammount.com/CatalogResul...6/Default.aspx
Buy a pair of Emgo Universal Mirror Adapters, part #20-28109. You can buy a single adapter on eBay for $5.25, delivered.
http://www.ebay.com/itm/Emgo-Univers...-/350589867470
You can also get a single Emgo adapter for $2.06 from Powersport Superstore.
http://www.powersportsuperstore.com/...-p/4145572.htm
Install the Emgo adadpter in your clutch perch. Then screw the 8mm, RAM Tough Ball into the Emgo Adapter.
Spud
Spud Rider screwed with this post 02-09-2013 at 09:35 PM
Old 02-10-2013, 01:22 AM   #544
DDT Rider
Oddometer: 473
Sorry for the pun, but what's the advantage of these tough balls?
DDT Rider is offline   Reply With Quote
Old 02-10-2013, 01:57 AM   #545
Spud Rider
Spud Rider's Avatar
Oddometer: 3,762
I quote from the RAM website.
"Introducing the new RAM Tough-Ball™. Why call it tough? Because this latest addition to the RAM product line has steel inside and out."
The standard RAM ball is made of aluminum. The RAM Tough Ball also has a hex nut on the base, which makes it easier to securely tighten, and loosen the Tough Ball.
Spud
Old 02-10-2013, 04:17 AM   #546
DDT Rider
Oddometer: 473
I was wondering why the ram balls did not have a hex at the base...it seemed like such a no-brainer.
Old 02-10-2013, 08:58 AM   #547
Motoriley
Motoriley's Avatar
Oddometer: 2,683
Tough nuts
The original RAM balls are soft and tend to take a set after being left in the same position. This makes it a bit tough to adjust as the ball is deformed a little and the mirror arm wants to return to the same position.
Old 02-10-2013, 03:05 PM   #548
DDT Rider
Oddometer: 473
I see the new balls have a screw that is M8X1.25....does that match the BMW thread?
...dang the universe is evil...I see BMW uses M10X1.5
Old 02-10-2013, 03:09 PM   #549
neduro OP
Addict
neduro's Avatar
Oddometer: 11,941
BMW is 10mm x 1.5.
I'll try to get my hands on a toughball in M8 and do some tests, I agree with Motoriley that it could be promising.
Old 02-10-2013, 03:25 PM   #550
Spud Rider
Spud Rider's Avatar
Oddometer: 3,762
The Emgo "Universal" Mirror Adapters employ M10-1.25 and M8-1.25 threads. These adapters sell for $2.50 apiece at Motorcycle Superstore.
http://www.motorcycle-superstore.com...WT.MC_ID=10010
Most motorcycle mirror mounts employ the M10-1.25 thread. However, it appears BMW bikes are an exception.
For most motorcycles, using the 10mm male to 8mm female adapter will allow the installation of the 8mm, RAM Tough Ball, part #RAP-B-379U-M81208
The Emgo "Universal" Mirror Adapters are available in either black, or chrome finish. Install the Emgo adadpter in your clutch perch. Then screw the 8mm, RAM Tough Ball into the Emgo Adapter.
Spud
Spud Rider screwed with this post 02-10-2013 at 04:02 PM
Old 02-17-2013, 03:49 PM   #551
SteveROntario
Oddometer: 52
Removing the reflector turned out to be easier than I thought! The middle is a good starting point as there is a cavity behind the glass, I was able to punch in the centre and work my way out from there in a matter of minutes using a 2 1/2" long wood screw.
Steve
Use clear silicone, not superglue. Getting them out is a pain, we try not to do it.
Glad to hear they survived the crash, Lonestar, and hope you're ok!
For anyone else thinking of testing the crashworthiness, Lonestar has done your work for you, no longer necessary to auger!
2009 Suzuki DR-Z400SM (Zed version) with offroad wheels
SteveROntario is offline   Reply With Quote
Old 02-20-2013, 10:57 AM   #552
neduro OP
Addict
neduro's Avatar
Oddometer: 11,941
Lemons out of Lemonade
Every problem contains an opportunity. At least, I hope it does.
With that in mind, WE ARE BACKORDERED!
We got a bad batch of glass (bubbles), and rather than make mirrors that are not up to our standards, we reordered new glass. Demand was faster than our supplier... we should have new glass in on 2/28 and will fill all orders immediately once it arrives. Your card will not be charged until the order ships.
To compensate, we are holding our first ever sale. If you order during the backorder period, use this code for a 10% discount (hopefully this rewards your patience for delivery!).
2020HINDSIGHT
Enter the code on the next page during checkout, and it will be applied to your order.
The fine print: We can't retroactively apply the code to an order, and we can't 100% guarantee 2/28 for a ship date (it will be close to that, hopefully before, maybe a few days later).
Old 02-26-2013, 04:48 AM   #553
N8
Oddometer: 64
Thank you for the discount. I couldn't figure out how to make the code work with paypal - worked fine with credit card payment (just an FYI for others).
N8 is offline   Reply With Quote
Old 03-01-2013, 11:57 AM   #554
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,741
sweet discount! ordered, thanks!
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is online now   Reply With Quote
Old 03-01-2013, 01:50 PM   #555
neduro OP
Addict
neduro's Avatar
Oddometer: 11,941
Glass came in, but our web guru is on a plane to the Tuareg... so the discount will stand for another day or so until GSNorCal can take it down. Orders will be going out Monday.
Times are GMT -7.   It's 01:17 PM.
