Old 04-27-2010, 07:57 AM   #16
GR0NK OP
Got some screws loose!
GR0NK's Avatar
Oddometer: 1,366
Originally Posted by wanna bECO
Gonk, where are you located... phoenix??
Northern Ontario, Canada. Little place called Valley East.
Sean
Team Valley Bomb Squad
2010 P2D 3rd place
2012 Dacre Challenge 2nd place
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 04-27-2010, 08:07 AM   #17
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,181
You probably already know about Dr ATV for parts.
http://www.dratv.com/engineparts3.html
scooteraug02 is offline   Reply With Quote
Old 04-27-2010, 08:30 AM   #18
wanna bECO
wanna bECO's Avatar
Oddometer: 720
oh darn, I'm in phoenix... the "valley of the sun" and I found this..
http://mohave.craigslist.org/mcy/1704117658.html I think this is the bike your talking about.
have you ever used "searchtempest" it's perfect for searching around large areas on craigslist.
Just cuz my bike is shiny, doesn't mean that I'm a hiny
current stable
'94 Harley .... a blue one
'82 Honda passport
'87 Honda spacy 250
And an E Bike
85 spacy 250
81 passport (in pieces, many parts for sale)
The hit's just keep coming.. bought another 81 passport (11-28-09)
http://tiny.cc/ITgetsBETTER
wanna bECO is offline   Reply With Quote
Old 04-29-2010, 09:33 PM   #19
GR0NK OP
GR0NK's Avatar
Oddometer: 1,366
Yeah I used it a couple times but Craigslist isn't as popular in Canada. We have Kijiji instead. www.kijiji.ca
Sean
2010 P2D 3rd place
Old 04-29-2010, 09:48 PM   #20
GR0NK OP
GR0NK's Avatar
Oddometer: 1,366
Found two ATC 125Ms for cheap, going to pick them up on the weekend.
In the meantime, I decided to take the CT apart and at least see how well the 125cc ATC motor fits.
Pretty good. The mounts line up perfect as well as the sprockets and chain. The recoil case is a few inches thicker than the stock 90cc motor so I'm going to have to use the footpegs from the ATC which is also wider. That just means I'll be able to drag the pegs on the go-kart track!
I've also started taking the chassis apart to assess its condition and decide what to do about paint.
Overall it's very solid. The battery box area is the worst, presumably from battery acid spillage.
And also the swingarm bridge may be a bit soft too.
If it's too far gone I don't mind replacing it. Needs a new taillight assembly as well as new rear shocks.
I'm debating if I should try and get it powdercoated or just paint it. Either way it needs to be sandblasted to get all the rust off and some new metal to beef up around the battery box. I'd also like to make it a different color than the factory yellow. Any suggestions?
Sean
2010 P2D 3rd place
Old 04-29-2010, 09:59 PM   #21
spotch
Oddometer: 390
orange!
or black.
spotch is offline   Reply With Quote
Old 04-29-2010, 10:31 PM   #22
wanna bECO
wanna bECO's Avatar
Oddometer: 720
i've seen a black one with black hubs to match.. that was cool. But... Cammo is cool for a CT too. I myself like the tony the tiger orange and black stripes.. THEY'RE GREAT!!!
current stable
'82 Honda passport
'87 Honda spacy 250
And an E Bike
85 spacy 250
Old 04-29-2010, 11:01 PM   #23
GR0NK OP
GR0NK's Avatar
Oddometer: 1,366
I like orange, but I think I have enough of it in the garage!
Since this is really a resto mod, I would like to eliminate all the chrome. That might be hard to do on the wheels and rear rack though. Maybe I can find some aftermarket hoops I can lace up to the original hubs.
Sean
2010 P2D 3rd place
Old 04-30-2010, 06:00 PM   #24
Speedo66
Oddometer: 4,588
I don't know how durable it is, but they make a flat black auto trim paint that will stick to chrome.
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 04-30-2010, 06:07 PM   #25
WILL_S
110 POWER
WILL_S's Avatar
Oddometer: 1,652
Cool project.I've pm'd you.
Take the green pill or the red pill- the choice is yours;This is your last chance. After this, there is no turning back. You take the blue pill - the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill - you stay in Wonderland and I show you how deep the rabbit-hole goes.
WILL_S is offline   Reply With Quote
Old 05-03-2010, 08:21 PM   #26
GR0NK OP
GR0NK's Avatar
Oddometer: 1,366
Got a couple more donors over the weekend.
The first one doesn't quite look as minty as the one in the brochure but it's complete and runs like a top. But the clutch is smoked.
Not a big deal but now I have to go into it and sort it out.
The second one runs too but smokes quite a bit. I'm hoping a piston and rings will fix it.
The important part is that now I have two pull start assemblies!
Hey what do you guys think about this idea?
It's not quite where it would need to sit. It needs to be a bit higher to clear the carb/air filter but I think it can easily reside in that space and double my fuel capacity.
Sean
2010 P2D 3rd place
Old 05-03-2010, 09:15 PM   #27
tundrawolf
Desert Rat V Star
Oddometer: 313
When you find a pull start motor put it back into the ATC. The ATC is aout 400,000 times more fun (And dangerous ) than the trail 90. I have an ATC 110 and 2 Trail 110s. I love the trails, but the ATC is what gets ridden 90% of the time.
tundrawolf is offline   Reply With Quote
Old 05-03-2010, 09:32 PM   #28
scooteraug02
Dog Rancher
Oddometer: 4,181
Valspar tractor and implement paint is pretty durable and easy to use.
Valspar Tractor & Implement Enamel
http://www.garagejournal.com/forum/s...ad.php?t=28009
Old 05-04-2010, 12:24 AM   #29
WILL_S
110 POWER
WILL_S's Avatar
Oddometer: 1,652
Sean
Looks tough .How much does it hold?
Old 05-04-2010, 05:13 AM   #30
GR0NK OP
GR0NK's Avatar
Oddometer: 1,366
That's the plan. I'm going to assemble two 125cc motors from the three I have and keep a running ATC. It will likely become the bonfire beverage resupply vehicle, what with electric start, a rack that can hold a cooler and the added stability of three wheels! But that's a project that will have to take a number.
Sean
2010 P2D 3rd place
Times are GMT -7.   It's 07:17 PM.
