Old 04-28-2010, 01:43 PM   #1
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,615
The Official RT Thread
RT issues, modifications, or whatever- this is the place at ADV dedicated to your BMW RT questions and contributions.
Show us your -
- maintenance projects
- modifications
- custom exhaust systems
- navigation systems & installs
- mechanical failures and observations
- lighting upgrades and additions
- or anything else RT related you want to share or ask about.
To show off your bike, you can do it in this dedicated thread -
http://www.advrider.com/forums/showthread.php?t=13757
The GSpot FAQ -
http://www.advrider.com/forums/showthread.php?t=326162
The RT Model List (LMK if I missed any)
- K75RT...........................
- K100RT.........................
- R65RT..........................
- R80RT..........................
- R100RT........................
- R850RT........................
- R1100RT......................
- R1150RT......................
- R1200RT......................
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo screwed with this post 04-30-2010 at 09:35 PM
Hondo is offline   Reply With Quote
Old 04-28-2010, 05:35 PM   #2
Hondo OP
Hondo's Avatar
Oddometer: 9,615
One of it's internal fog light bulbs my R1150RT failed, so I decided to replace both of the lamps as a pair (age).
That means all of the plastic including the side panels, windscreen and part of the dash have to be removed. Then I had to figure out how to get the speaker assemblies out so that I could access the bulbs themselves.
The RT in a stripped condition -
I decided to replace both of the lamps because I didn't want to do this again. I used Sylvania Silverstar 55 watt bulbs.
Beemer Pat came by to help- I appreciate it Pat!
Hondo screwed with this post 04-29-2010 at 06:14 AM
Old 04-29-2010, 03:44 AM   #3
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,713
A 2003 R1150RT came home with me this past Saturday. This was a move from a Kawasaki Z750s. I was concerned with the difference in weight, the Kawi was just over 400 lbs, the RT over 600. I am very surprised that while under way, it does not feel heavy at all. Not until I tried to put it up on the center stand did it feel heavy . It is also the most comfortable motorbike I have ridden, and it is still quite nimble when the roads get twisty. It was also well planted on some dirt roads that we took. It did start to slide around on some loose gravel, though. I will be doing the 24k mile service this weekend, cleaning it up, and putting up some photos in the RT photo thread. I think this bike is gonna be with me for a while.
There's something kinda sad about, the way that things have come to be. Desensitized to everything, what became of subtlety?
fyrfytr is offline   Reply With Quote
Old 04-30-2010, 08:15 PM   #4
Hondo OP
Hondo's Avatar
Oddometer: 9,615
I did a little work on the R1150RT today.
First thing I did was to install a Kaoko throttle lock.
The stock grip -
And with the easily installed Kaoko -
After I got that done I removed the wheels and then the left side plastics to pull the battery (to be tested) -
I had the battery tested at Checker Auto and the tester said it was ok, so I decided to get a trickle charger and an powerlet male connector to hook to the bike.
I took the wheels over to Woody's Wheel Works and dropped them off with a set of new Bridgestones to be mounted.
Then I stopped by Performance Cycle and bought a Powerlet plug -
I also picked up an inexpensive trickle charger at Wal Mart for $21 -
Then I picked up the wheels at Woodys and headed home to put it all back together.
In2dabluz and Beemer Pat stopped by -
I also changed the oil and filter and put the trickle charger on for the evening.
Old 05-04-2010, 04:00 AM   #5
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,713
Answer me a (possibly) silly question. I do not have a repair manual yet. Is the fuel pump/filter under the gold colored plate just to the right of the fuel fill, or on the bottom side of the tank? Thanks. Also, if it is just to the right of the fuel fill, how is the piece of the fairing over the center of the tank removed? Thanks again.
Old 05-04-2010, 08:57 AM   #6
Hondo OP
Hondo's Avatar
Oddometer: 9,615
I'll have to look at my manual when I get home ( in 4 days) to tell you about the fuel pump/filter-
But the center piece comes off after you remove the fasteners that go through it's edges- the ones that are holding on the side plastics. And I'd remove the fuel cap assy too.
I would plan on removing both side panels to get the center piece off.
Hondo screwed with this post 05-04-2010 at 09:13 AM
Old 05-04-2010, 11:00 AM   #7
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 4,107
I recently did the fork seals on my 1100rt. Pretty straightforward even for a ham-fisted wrench like me. No photos but there's good ones on bmwsporttouring and ukgser.
Everything went well but the speedo does not work.....! The slot in the housing near the wheel turns and I was careful to line up the blade in the cable. Still nothing. I can't really see how the thing could have been damaged while doing the seals, but maybe it was.
I guess I'll fiddle around with it some more and see if it won't work before I get a new cable.
Chris R
Schreckendgust Field, Montana
Kinsman is offline   Reply With Quote
Old 05-04-2010, 07:19 PM   #8
rous44
rous44's Avatar
Oddometer: 1,298
The inner cable may have come out of it's seat at the speedo????
Registered offender
"picking up hookers, instead of a pen, the words of my youth slipped away" Waylon Jennings
MX '06 http://www.advrider.com/forums/showthread.php?t=176637
MX '07
http://www.advrider.com/forums/showthread.php?t=278826
rous44 is offline   Reply With Quote
Old 05-04-2010, 09:29 PM   #9
Kinsman
Kinsman's Avatar
Oddometer: 4,107
Thanks, I'll look at that. I didn't mess with the cable at that end but I did take the handlebars off.
Chris R
Old 05-05-2010, 07:42 AM   #10
74C5
74C5's Avatar
Oddometer: 986
Fuel filter is underneath the tank. PITA
74C5 is offline   Reply With Quote
Old 05-05-2010, 09:04 AM   #11
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,713
Figures. I just filled the tank. Thanks for the input.
Old 05-09-2010, 07:21 PM   #12
Hondo OP
Hondo's Avatar
Oddometer: 9,615
Did a nice day trip today-
http://www.advrider.com/forums/showthread.php?t=577834
Old 05-10-2010, 04:01 AM   #13
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,713
I did my first long-ish trip on Saturday. Just shy of 200 miles. (Hey, NJ's small, OK? ) Headed to a BBQ for a bunch of Inmates. Rain in the morning and very heavy winds riding home. Excellent protection from the elememts, though several gusts from the side caught me by surprise. I like this bike more each time I ride it.
Old 05-10-2010, 04:25 AM   #14
Beemer Bob
Beemer Bob's Avatar
Oddometer: 2,673
1996 R1100rt
The headlight on my RT is weak. I put HID's on my GS and wonder if anyone has put an HID setup on the 1100RT? Does the bulb opening need to be increased in size?
Bad decisions make great stories!
"Often wrong but NEVER in doubt"!
Beemer Bob is offline   Reply With Quote
Old 05-15-2010, 01:58 PM   #15
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,713
Weird
The Twinmax I ordered arrived yesterday, so the rough idle is sorted. Riding today, I noticed the high beam indicator illuminated. Toggled the high/low/pass switch several times did not extinguish it. Checked the headlights, they're not working. Switched on the fog lights and continued on. There is apparently a loose connection, is there a common spot where a connector loosens up, or does the harness rub the fairing somewhere? TIA.
Almost forgot, when I got where I was going, the headlight was working again.
Times are GMT -7.   It's 11:03 PM.
