Old 09-28-2013, 09:53 AM   #1546
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
Canbus is the motorcycle's self defense against ham-handed farkeling.
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 09-28-2013, 04:10 PM   #1547
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,828
I have not met a farkle I couldn't put on the bike because of the canbus layout. It is just not that hard. However, it does take more than half a brain.
Jim
Old 09-28-2013, 04:36 PM   #1548
ka5ysy
Doug
ka5ysy's Avatar
Oddometer: 830
Trust me on this: CANBUS does nothing for stupid ! Some of the FUBAR wiring I see makes me wonder if the owners are actually trying to set fire to the bike !
Like Jim said, you need at least half a brain to do it correctly.
Doug, KA5YSY
2011 BMW R1200RT
MSF/RidersEdge #127350, NAUI #36288
ka5ysy is offline   Reply With Quote
Old 09-28-2013, 05:31 PM   #1549
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 165
Cantbus
CANTBUS is for you. It is not for me.
I've learned (the hard way) to kill the engine using the key.
I have not learned to plug in the (OEM) battery charger before turning off the engine. CANTBUS not happy, chargie not allowed, bike protected, battery barely able to start the bike three weeks later. Thanks, CANTBUS!
Variation on a theme: ignition key on, charger blessed by CANTBUS, ignition off. Week later, power outage, power restored, CANTBUS not alive to bless (OEM) charger, battery slowly dies. Thanks, CANTBUS!
I wire the few farkles just fine, don't welcome CANTBUS to protect my bike from my wiring. No choice but to wire everything direct to battery, go around CANTBUS. Even the OEM charger?!? Special little pigtail hanging off the bike somewhere, poking through the tupperware gaps? Asinine. Fail.
Whomever owns this bike in 10-20 years may curse the mission-critical failing electronics. I love this bike but wish for simpler systems.
Yukon Ho! is online now   Reply With Quote
Old 09-29-2013, 03:47 AM   #1550
ka5ysy
Doug
ka5ysy's Avatar
Oddometer: 830
Perhaps you need a better charger that talks to the CANBUS ?
http://www.tecmate.com/u_optimate_4_dual.php
Plug it into an accessory socket, it tells the computer it is there and is connected to the battery as necessary to maintain your charge. I've been using one since they came out, and they work fine. None of the problems you complain about. I drive into the garage, park the bike, plug in the charger and forget about it until the next ride. Great product.
Doug, KA5YSY
2011 BMW R1200RT
Old 09-29-2013, 06:38 AM   #1551
mwood7800
Oddometer: 611
Much easier to install a 30 amp 2 prong plug ( un-fused) direct to battery. Let it hang long enough to be able to get to it without removing the seat. You can use for charging or to jump start the bike.
mwood7800 is offline   Reply With Quote
Old 09-29-2013, 07:13 AM   #1552
Firenailer
just passin' thru
Firenailer's Avatar
Oddometer: 266
Maybe I'm confused but I just plug my BMW Smartcharger into the bike and plug it in once in the garage after riding and everything charges up just fine.
I did have some odd charger behavior when I first bought the bike and asked the Dealer about it. They replaced the charger and I haven't had a problem since. You might have a bad charger.
"We were leaving confusion and nonsense behind, performing the one noble function of our time...to move"
On The Road
'12 BMW R1200RT
Firenailer is offline   Reply With Quote
Old 09-29-2013, 10:28 AM   #1553
objectuser
objectuser's Avatar
Oddometer: 242
+1 We have those on all four of our bikes. 2 BMWs, a Victory and a Norton. They work great.
2009 R1200R - Sold
2009 R1200GS
1968 Norton P11A
objectuser is offline   Reply With Quote
Old 09-29-2013, 08:26 PM   #1554
planemanx15
planemanx15's Avatar
Oddometer: 1,009
I think my speedo cable is starting to fray. At a normal cruise today, around 65, my speedo started to climb, to around 110 during any sort of acceleration. Is this a symptom of a broken cable?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 09-29-2013, 08:36 PM   #1555
JimVonBaden
"Cool" Aid!
Oddometer: 53,828
Can be. Does it jump around at low speeds?
Jim
Old 09-30-2013, 06:25 AM   #1556
planemanx15
Oddometer: 1,009
Jim
It does not. It was also wet last night. This morning it was dry and it didn't have an issue
Old 09-30-2013, 06:27 AM   #1557
JimVonBaden
"Cool" Aid!
Oddometer: 53,828
That doesn't sound like a cable to me, but it is easy to check. Pull the cable loose at the wheel end and remove it for inspection. If it is damaged it will be obvious. Odds are you have a speedo going bad.
Jim
Old 09-30-2013, 12:50 PM   #1558
planemanx15
Oddometer: 1,009
Jim
Thanks for the advice, ill take a look
Old 09-30-2013, 03:26 PM   #1559
BERNERBUDDY
BERNERBUDDY's Avatar
Oddometer: 135
Drive
Afternoon,
I have an '01 GS that the speedo was jumping about. I found the dogs on the gear drive worn (nylon if I recall correctly). I replaced the drive unit, problem gone.
Easy fix!!
RC
PS this is the last day of the H/F motorcycle lift half price sale!!!
'12 R1200RT
'01 R1150 GS
'07 TW200
'74 TY250
BERNERBUDDY is offline   Reply With Quote
Old 10-01-2013, 01:38 AM   #1560
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Jim
Good luck with the LC GS. There's a pot of gold awaiting the clever individual who can devise a way to make driving lights switch on with the high beam.
twinrider is offline   Reply With Quote
Times are GMT -7.   It's 05:13 PM.
