Old 05-08-2014, 07:35 PM   #1876
roadboxer
roadboxer's Avatar
Oddometer: 47
Clearwater Lights
Just curious, has anyone mounted any clearwater lights under the oil cooler on an 1100Rt? If so have pics?
roadboxer is offline   Reply With Quote
Old 06-05-2014, 07:47 PM   #1877
MotorcycleWriter
MotorcycleWriter's Avatar
Oddometer: 1,125
First Brake Bleeding Saga
Hey,
Been pretty active over in the Airheads group while doing a partial resto on an '89R100GS. Now that it's mostly sorted out I'm going to be riding it during the hot months while I go over my '02R1150RT. Mostly I want to bleed the ABS brakes since it hasn't been done in a few years. Probably wouldn't hurt to lube the splines as well, but first things first. The bike has 28K miles on the odo and hasn't shown me any problems during the 10K I've put on it over last few years. Can anyone here direct me to a good online procedure for doing the brakes? I've got the funnel from Beemer Boneyard that someone recommended and a couple of manuals, but I'd like to look at a FAQ or a DIY as well, if there's one out there. My mechanic skills are good and I'm not fearful of trying things, just short on time like the rest of you.
MotorcycleWriter is offline   Reply With Quote
Old 06-05-2014, 07:51 PM   #1878
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
Originally Posted by MotorcycleWriter View Post
Hey,
Try this: http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf
Old 06-05-2014, 09:11 PM   #1879
Cameleer
Worldcrzer
Cameleer's Avatar
Oddometer: 98
Hi to all, I installed auxiliary rear view mirrors on my '01 1150RT (mounted on the unused holes on the handlebar) but now they vibrate like crazy, especially the left one. Any ideas on how to dampen the vibration? (rubber or something?) thanks
"People don't change... they just get older"
Cameleer is offline   Reply With Quote
Old 06-05-2014, 10:48 PM   #1880
cpallen
Nearly Adventurer
cpallen's Avatar
Oddometer: 977
Sync the throttle bodies?
Courtney in Seattle
'13 BMW F800GT, '07 G650X Challenge
'09 Aprilia Scarabeo 500ie
cpallen is offline   Reply With Quote
Old 06-06-2014, 02:15 AM   #1881
Cameleer
Worldcrzer
Cameleer's Avatar
Oddometer: 98
I feel really ignorant... How do I do that??
Old 06-06-2014, 10:07 AM   #1882
Roadscum
Oddometer: 2,368
It's probably best that you let the dealer make that adjustment for you.
Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 06-06-2014, 12:31 PM   #1883
Cameleer
Worldcrzer
Cameleer's Avatar
Oddometer: 98
Paul
I definitely will check with them on the next service, thanks Paul
Old 06-06-2014, 06:11 PM   #1884
MotorcycleWriter
Oddometer: 1,125
Does the vibration vary with engine speed, sort of changing in magnitude with engine rpm, or does it start about 40 mph and get progressively worse as your speed increases? If it is the former, the engine may be out of tune. If the latter, there may be vortices detaching from the complex windshield/fairing shape and hitting the mirrors. That will be a lot tougher to fix without changing the geometry of the front end.
Old 06-07-2014, 09:38 AM   #1885
catchina
138 miles to go...
catchina's Avatar
Oddometer: 507
Heard a rumor that BMW is about to recall all 2014 r1200rt with ESA and warning owners not to ride!
2011 R1200R
1996 Virago XV 750
catchina is offline   Reply With Quote
Old 06-07-2014, 10:01 AM   #1886
bradatlarge
Insha'Allah
bradatlarge's Avatar
Oddometer: 12,191
Not a rumor.
You have been warned.
bradatlarge is offline   Reply With Quote
Old 06-07-2014, 10:10 AM   #1887
Roadscum
Oddometer: 2,368
That's ancient history now with speed of the interweb at our finger tips..
Take a look here:
http://www.motorcyclenews.com/MCN/Ne...514-BMWrecall/
Paul
Old 06-07-2014, 12:25 PM   #1888
dmottv
Take the Long Way Home
dmottv's Avatar
Oddometer: 415
I added K12RS mirrors on mine and vibration is only an issue over 70 +/-. I have bar ends that help dampen vibes.
Dave - NH Seacoast; RT-NH1; AMA; MVTR; NETRA;
'07 KLR650; '02 R1150RT-P; '01 R12C Montana; '00 KDX200;
Gone: '05 450EXC; '99 K12LTC; '94 KDX250; '92 R100GS; '77 R75/7; a few others...
dmottv is offline   Reply With Quote
Old 06-07-2014, 05:43 PM   #1889
Mirider
Oddometer: 19
I have mirrors that I got from the Beemer Boneyard and have had no issues up to 80mph on my 96 1100rt. I also have bar ends.
Mirider is offline   Reply With Quote
Old 06-07-2014, 10:22 PM   #1890
Cameleer
Worldcrzer
Cameleer's Avatar
Oddometer: 98
Also have bar ends, vibration is irrespective of speed. Any thoughts on re-installing the mirrors with rubber dampers on the bases or something like that?
Times are GMT -7.   It's 09:29 PM.
