Old 05-31-2010, 07:14 AM   #31
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 7,722
Sounds like the clutch is slipping.
Put it in 5th or 6th gear and load the engine at a lower RPM, like 2,500 - 3,000 RPM, and roll on the throttle.
LC8World.com - KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is online now   Reply With Quote
Old 05-31-2010, 11:49 AM   #32
hoagy
wanna be :(
Oddometer: 67
Send a message via MSN to hoagy
I just tried this and she jsut grunted out no problem, no slipping. Just like normal.
Hoagy
Originally Posted by fyrfytr View Post
A clean motorcycle is a dirty shame.
hoagy is offline   Reply With Quote
Old 05-31-2010, 08:15 PM   #33
Hondo OP
Hondo's Avatar
Oddometer: 7,722
Try it in a low gear too.
Maybe you were in between gears?
Old 06-05-2010, 09:12 PM   #34
mikeprod92211
Desert Rat
mikeprod92211's Avatar
Oddometer: 585
Lomax,
I have a 2003 1150 rt and had the same problem. I am 5ft 10, ride a stock seat with Alaska Leather butt pad.
Replaced shorter windscreen with an 16 in version.
Could not get the buffeting away from my helmet.
Finally, got a Laminar lip and put it on the 16 in windshield. What a difference.
I can adjust the windshield to have some air hit the helmet, or raise it all the way up, and have a wind-free pocket to ride in. Not even ear plugs.
For my money, best $ spent.
It forces the air from the top of the shield to curve further up over the head. Looks a bit homely, but I got used to the looks. Comfort wins!
LC4 Rider
mikeprod92211 is offline   Reply With Quote
Old 06-07-2010, 06:50 PM   #35
longjt
Oddometer: 64
Tool-less tire mounting?
I've seen the thread about how to mount your tires with straps that hold the beads together, but I'm wondering if anyone here has tried that with the 1200RT and the big rear tire? It would be cool to not have to drive to the local shop and pay $20/wheel for mounting. And balancing could be done with DynaBeads.
longjt is offline   Reply With Quote
Old 06-08-2010, 03:34 AM   #36
Beemer Bob
Beemer Bob's Avatar
Oddometer: 1,805
I just tried to mount a 200/50ZR17 on my Vulcan. Got the bead broken but could not get the bead over the rim with the tools I had. Need a 3 ft. tire iron for that radial tire, Metzler 210/50ZR17. Anyway, I then took it to the local automotive tire store and he did it for $10, off and on. Get the biggest tools you can find and try.
"I am the shit that happens!"
"Often wrong but NEVER in doubt"!
Beemer Bob is offline   Reply With Quote
Old 06-14-2010, 03:53 AM   #37
Beemer Bob
Beemer Bob's Avatar
Oddometer: 1,805
Reliability
I have been bitten by BMW's legendary reliability. 1100RT quit on me in a driving rain 1.5 hours from home.......Classic Hall device failure.
I have ordered the components to build the timing box and 2 hall switches.
I will report back and I am using the Wisdom article to diagnose and repair.
Thank you for the Wisdom article.
Old 06-14-2010, 10:03 AM   #38
KneeDrachen
MORE COWBELL!!!
KneeDrachen's Avatar
Oddometer: 1,089
Send a message via AIM to KneeDrachen
Used RT nuances/problems
Afternoon All,
Looking at a used 2000 RT-P and a 2003 1150 RT-P. The 2000 has 94k and change on it with a rebuilt driveshaft at 88k. The 1150 has 72k and has had no work done to it other than routine maintenance.
Is there anything I should be looking for? I know the 1100 is due for a timing belt and the PO doesn't know of a previous spline lube in 32k miles of ownership according to PO but beyond that do either of these bikes have any issues that may need sorting and can be detected through an inspection?
The 1100 is a previous CHP bike, no known origins of the 1150.
Thanks in advance.
Breathe, keep breathing, I can't do this alone
KneeDrachen is offline   Reply With Quote
Old 06-14-2010, 06:10 PM   #39
Zerk
DILLIGAF
Zerk's Avatar
Oddometer: 3,063
I've been thinking about a RT. One thing I am apprehensive about, is maint. I don't let people work on my bikes, partially cause I am cheap, partially cause its a hassle bringing it in, and getting ride back.
I figure oil changes are probably easy. I understands they need valve adjustments. I am fairly mechanically inclined, if I got good instructions. Can I do this myself?
I also hear you need to bring it in for ABS to be adjusted. How often? Can you buy the tools to do it yourself?
What about electronic diagnosis, can I buy a scanner?
How good are the BMW manuals?
Berserker
In my travelling heart, there's an urge to see
foreign lands and alien birds, hear stories that no ones heard-D.A.D.
Helmets are like rubbers, you know you should wear one, but its so much better when you don't-Me.
Zerk is offline   Reply With Quote
Old 06-14-2010, 07:10 PM   #40
cpallen
Nearly Adventurer
cpallen's Avatar
Oddometer: 624
Originally Posted by Zerk
I've been thinking about a RT. [snippage]
surf around JVB's site for awhile and you will know the 1200 better anyway
http://www.jimvonbaden.com/JVB_Productions.html
Courtney in Seattle
'04 Moto Guzzi California EV Touring
'04 Moto Guzzi V11 Sport Ballabio
cpallen is offline   Reply With Quote
Old 06-14-2010, 07:15 PM   #41
longjt
Oddometer: 64
911 gs gives you the electro diagnosis: http://www.gs911usa.com/gs-911-compare.php
Jvb gives you a maintenance dvd: http://www.jimvonbaden.com/JVB_Productions.html
Most of the maintenance is a piece of cake.
'05 R1200RT
Old 06-15-2010, 04:51 AM   #42
Zerk
DILLIGAF
Zerk's Avatar
Oddometer: 3,063
Do you ever need to bring it back to a dealer? I am a cheapskate, plus theres just not alot of dealers. Does the ABS need to adjusted or calibrated?
Berserker
Old 06-16-2010, 04:38 AM   #43
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,334
Biggest issue that I am aware of is the fluid is supposed to be changed annually. To do so the fuel tank needs to be removed, I believe. This is still on my to-do list, along with the fuel filter. Beemer Boneyard sells the tool for the fluid change for about $35.
But the speed was power, and the speed was joy, and the speed was pure beauty.
fyrfytr is offline   Reply With Quote
Old 06-16-2010, 07:12 AM   #44
Spat
Spat's Avatar
Oddometer: 814
Zerk my 2003 RT is the best (worst) of the best linked ABS braking. I have tried independant shop to do the annual brake flush and they all tell me special equipment is needed for that model and suggested going to the dealer. re: brake control pack $$$
Spat
FLHGSSXDR.Patrol
Red Green: You ever see one of these? It's called a GPS, this thing uses satellites to tell you where you are, which means that every man can have a five-hundred-dollar reason not to ask for directions.
Spat is offline   Reply With Quote
Old 06-16-2010, 03:21 PM   #45
XTrooper
XTrooper's Avatar
Oddometer: 191
My first BMW motorcycle, it's a 2009 R1200RT.
Here's a list of mods and accessories I've added on it since I bought it new last October.
Fuzeblock FZ-1 fuse block
Ilium Works shift lever extension
Ilium Works side stand foot
Suburban Machinery rider foot peg lowering kit
Touratech brake lever extension
Touratech cylinder head guards
Touratech/Kahedo rider and passenger heated seats
West Tool & Design windshield support arms
ZTechnik VStream windshield
RKA pannier liners
Remus HexaCone titanium slip-on muffler
Steve
NJ State Trooper #3936 (retired 4/1/1991)
2011 BMW F800GS - Alpine White
2009 BMW R1200RT - sapphire black metallic (sold)
XTrooper is offline   Reply With Quote
Times are GMT -7.   It's 08:51 PM.
