Old 07-13-2010, 12:28 PM   #91
malott442
Loud, yet refreshing
malott442's Avatar
Oddometer: 633
Hey everyone, just introducing myself as a soon to be new-to-me RT owner. Trading my r1200st for a 96 r1100rt....
It has 110k miles on it,
K1200rs rear rim (17")
dual spark heads
I had one quick question: Will the K1200rs front rim fit?
I'm hoping through vigilant maintenance and a hard head I can break 200k on this bike.
Rear diff shows no play, but I will def. consider buying a spare just so.
malott442 is offline   Reply With Quote
Old 07-14-2010, 06:01 AM   #92
GoFar
My butt hurts.
GoFar's Avatar
Oddometer: 1,003
Originally Posted by fyrfytr
No ABS light, just the flashing brake failure light that goes off at 4 or 5 mph. I'll have to wait till I get home from work to test voltage at the battery. I have had to keep it on the charger while working on it due to the repeated cranking. I'm certain that it's not long for this earth.
The telltale sign for a low voltage situation tends to be an abs fault. Go ahead and check it regardless.
So, just so I'm sure:
  • Valves in spec
  • Throttle bodies synched
  • Cables are riding in on the cams and the sleeves
  • Compression is acceptable
Pissed Off American
GoFar is offline   Reply With Quote
Old 07-14-2010, 07:03 AM   #93
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,694
  • Valves in spec
All that has been done. The problem is intermittent spark. When it does run, it runs very well. The problem is getting it to start and start when it 's hot.
There's something kinda sad about, the way that things have come to be. Desensitized to everything, what became of subtlety?
fyrfytr is offline   Reply With Quote
Old 07-14-2010, 08:18 AM   #94
jbull
jbull
jbull's Avatar
Oddometer: 72
Nice - an RT forum
Just checking in - one more RT owner glad to see a forum on Advrider to add to the list of things that keeps me from being productive at work.
The first ride report I ever read was sent to me by an inmate. I cant remember the title, but it was written by a guy from Nebraska riding a R1100RT to Alaska - been hooked on Advrider ever since.
thanks for starting the thread
Jeff
2011 R1200GS Adv
jbull is offline   Reply With Quote
Old 07-14-2010, 04:44 PM   #95
Sox Fan
SoxFan
Sox Fan's Avatar
Oddometer: 898
Here's my RT - bought new in 2007. Has 28,000 miles on it - love the blue color.
2004 R1150 GSA
2005 MV Agusta F41000S
2011 335i
1989 911
Sox Fan is offline   Reply With Quote
Old 07-15-2010, 06:34 PM   #96
GoFar
My butt hurts.
GoFar's Avatar
Oddometer: 1,003
Sorry, I hadn't read the whole thread and you probably posted it.
I'm familiar with the early 259's and the '04's...by any chance is it a twin spark OR does it have the stick coil/sender arrangement? I'm just fishing a little as stick coils are a continuing issue...
If it's not, that's an issue that I haven't encountered before. I think you said you've done wires..????
Pissed Off American
Old 07-16-2010, 02:51 AM   #97
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,694
It's a single spark 2003 1150. I have read about the stick coil issues though.
As of yesterday, I picked up new battery, installed it and it was in worse shape than the battery it is replacing. After initial charge of 2 hours or so, it would not turn the starter, even when the charger was still connected. With volt meter in place, voltage dropped to 4.5 volts when starter button was pressed. Probably won't have another until Tuesday or Wednesday. Another weekend without a motorbike.
And Monday afternoon I get to remove the rear drive and replace the bearings. While the bike was on the center stand I checked for play and noticed a bit of side to side and up and down movement.
It seems I am getting the complete BMW experience.
Old 07-16-2010, 07:27 AM   #98
XTrooper
XTrooper's Avatar
Oddometer: 191
Looks great! That blue is one of the best colors BMW came out with in my book.
Steve
NJ State Trooper #3936 (retired 4/1/1991)
2011 BMW F800GS - Alpine White
2009 BMW R1200RT - sapphire black metallic (sold)
XTrooper is offline   Reply With Quote
Old 07-16-2010, 08:24 AM   #99
GoFar
My butt hurts.
GoFar's Avatar
Oddometer: 1,003
Arrrrrrggggghhh! That happens...If your starter is turning slower, it might be going...it's common. So does the '03 have a stick coil, is it the earlier (and seemingly more reliable) conventional coil set up? If it IS a stick coil arrangement, I'm betting that's the issue. Again, if it's not...that's a new one on me.
Pissed Off American
Old 07-16-2010, 09:51 AM   #100
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,694
Regular type of coil. The primary side
was showing higher resistance than called for. Not
much, but maybe enough.
Old 07-16-2010, 11:02 AM   #101
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,694
...If your starter is turning slower, it might be going...it's common. .
Please don't say that...
With the old battery on the charger, it turned over very well. With the new battery, it struggled past TDC and then just clicked. Voltage dropped to about 4.5 volts under load. Hoping it's a bad battery. It doesn't happen all the time, but it happens. Lucky me.
Old 07-16-2010, 11:22 AM   #102
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 8,987
Everyone and their new stuff. HA!
Marc
84 R100RS LE, 14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is offline   Reply With Quote
Old 07-16-2010, 05:27 PM   #103
XTrooper
XTrooper's Avatar
Oddometer: 191
Very cool, Marc. I like the "Samsonite" look of the side bags.
Steve
Old 07-16-2010, 06:33 PM   #104
(none)
poser
(none)'s Avatar
Oddometer: 2,620
Marc
beautiful air head.
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 07-16-2010, 06:40 PM   #105
D-Mac
D-Mac's Avatar
Oddometer: 613
Nice bike Marc!
Looks like we both have an '07 FZ6 for sale too....I'm lusting for an RT.
D-Mac is offline   Reply With Quote
Times are GMT -7.   It's 02:02 AM.
