Old 11-07-2012, 01:12 AM   #181
Slimie
Oddometer: 1,080
Laugh
Originally Posted by creaky View Post
engine has a surprising amount of grunt for a 250 as long you keep the revs up. Definitely a keeper.
Got to second that, I think I had a pleasant surprise at least once on every ride where the "little" 250 would simply drag itself up a hill while I was wondering where to change down!
Have even had riders following who passed on their astonishment at how tractable the bike was.
-Simon
Slimie is offline   Reply With Quote
Old 11-15-2012, 04:34 AM   #182
Tachedoutoffroad
Mr. Parrish
Tachedoutoffroad's Avatar
Oddometer: 646
All my dirty bikes run about $12-14 a month. Old or new.
'00 KTM 400EXC --plated!
'89 Honda Transalp
Sikorsky UH-60L
Support your local know-it-all gear guy and give your money to Brian at https://www.atomic-moto.com/
Tachedoutoffroad is offline   Reply With Quote
Old 11-15-2012, 11:51 AM   #183
jxg
Oddometer: 602
Originally Posted by sunset_ryder View Post
Wow, I got taken. Live and learn. Thanks for the response.
i think there are a lot factors, you can't just say you got taken. your age, where you are located and driving record are huge factors. that said, mine is actually a little cheaper than stated above for a '10 TE250
2010 Husqvarna TE250
jxg is offline   Reply With Quote
Old 11-19-2012, 07:30 AM   #184
Smithers
Arilia Rider
Oddometer: 11
Hard to resist such a great all around package with a classy color scheme. Great looking bike. And of course it will do anything you want which is most important. Surprising how fast these bikes are when you are up to it.
Smithers is offline   Reply With Quote
Old 11-21-2012, 03:12 PM   #185
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 674
Originally Posted by Tachedoutoffroad View Post
Well see how 5 days of camping does her.......
Small pack for 5 days! How'd she do?
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 11-26-2012, 07:26 AM   #186
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 421
A buddy of mine picked up a 2010 TE 250 early this fall and has had nothing but problems keeping the bike running. Soon after acquiring the bike if began to occasionally fail to start. When you turned on the key switch sometimes the fuel pump would spin up, some times it would not. They bought a new Shorai battery and everything seemed fine....for a while. Sometimes it would start and run for a while, sputter and die, then refuse to start. Again sometimes the fuel pump would spin up, sometimes not.
They then decided the problem might be the temp sensor so they bought one and sure enough if fired right up and ran fine for about an hour. Then began to exhibit the same symptoms. Bought yet another temp sensor, this time it had no effect. They have pulled the fuel pump and tested it with a 12V source. It seems to work properly when energized. These symptoms occur on both the kicker and the magic button.
He was able (somehow) to drift start it the other day, and it ran just fine for about a mile before it once again sputtered to death and refused to restart.
I know next to nothing about modern FI X-Lite Huskys. Can someone please point me in the right direction here?
Thanks,
Shawn
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 11-26-2012, 07:39 AM   #187
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,615
Thanks,
Shawn
Some people have had trouble with the wiring harness on the 2010 X-lites chafing and causing this sort of trouble. There is an updated harness available from the dealer.
More info is available at Cafe Husky - LINK
TaterHarry is offline   Reply With Quote
Old 11-26-2012, 08:41 AM   #188
jxg
Oddometer: 602
let us know if this works, which harness you get, and how much it costs. my '10 TE250 has what i think is the same issue right now. 12V applied directly to the pump spins up, but not when key turns or kick starter engaged. just get FAIL on the display.
Old 11-26-2012, 08:58 AM   #189
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,615
Chasing Gremlins
I read the symptoms more carefully and this may not be electrical per-se. The fuel pump may be going bad and tricking you by spinning up when cooled down, but then seizing up as it warms up (and overheats).
You can test this by energizing the pump with +12V and running it for an extended period to see if it overheats and/or seizes. Be sure to do this with the pump immersed in fuel or you will most certainly burn up the pump
If the pump passes the stress test then you are left chasing electrical gremlins: wiring harness, fuel pump relay, kill switch being your most likely causes.
Good luck!
EDIT - if you are getting FAIL on the dash (other poster), the dealer may be able to diagnose the problem with the iBeat software..
Old 11-26-2012, 09:24 AM   #190
jxg
Oddometer: 602
yeah, i know, but my "dealer" is over 2 hours away, and basically useless. it is probably time for me to pony up and buy ibeat. i suspect a faulty relay though.
Old 11-29-2012, 04:18 AM   #191
Tachedoutoffroad
Mr. Parrish
Oddometer: 646
I had major issues with mine as well. Woulnt e-start and replaced the relay and it worked, then later the connector on the relay failed and it wounldt run at all, or just maybe kick and run for 5 seconds.
Ended up taking apart jsu about every connection on the bike, cleaning, recrimping them, scraping up the male and female ends, coating in the electrode grease, and it worked after that.
I wasn't impressed with the non-waterproofness/ non-dustproofness/ non-bumpproofness
But, yes, the main starter relay and plug right next to the battery will fuk up your world if it's even slighty not right.
'89 Honda Transalp
Sikorsky UH-60L
Old 11-29-2012, 07:22 PM   #192
WVa Dualsport
Oddometer: 421
Thanks for the input and advise. I have passed the info on, and will report back with the next round of tests/findings.
Shawn
2010 450 EXC
2012 DL1000 V-Strom
Old 12-09-2012, 08:19 AM   #193
sparrow
sparrow's Avatar
Oddometer: 1,196
Because you have to ride in the upper rpm's all the time to have decent power what is the piston/ring replacement schedule on the 250?
sparrow is offline   Reply With Quote
Old 12-11-2012, 05:38 PM   #194
MotorcycleWriter
MotorcycleWriter's Avatar
Oddometer: 1,225
New to me '07 TE250
Should be picking it up on Friday. Trading it for my Montesa Cota 315R. Had fun with trials but am looking forward to having a seat again! I hear these are great bikes and plan on doing some dual-sporting with some local buddies.
MotorcycleWriter is online now   Reply With Quote
Old 12-12-2012, 06:45 AM   #195
Tachedoutoffroad
Mr. Parrish
Oddometer: 646
Get registered here.
http://bamarides.com/ride/index.php
There is a big group all around BHam that ride.
'89 Honda Transalp
Sikorsky UH-60L
Times are GMT -7.   It's 07:00 PM.
