Old 05-01-2010, 09:11 AM   #1
gozany OP
Oddometer: 8
My BMW R75/6 Cafe Build
I have been reading this site for about a year. I thought it was about time I posted something. Here are the pics of My BMW R75/6. I purchased the bike for $1200.00. It took me about 2 months to build her. I think I have about $3500.00 invested including purchase price. Lots of time but it was so worth it. I love this bike!
[IMG][/IMG]
The tear down.
[IMG][/IMG]
[IMG][/IMG]
Just started at the front & worked my way back.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I moved the fuse board to a box I built under the seat. You'll see why in a minute.
[IMG][/IMG]
[IMG][/IMG]
Bought a cafe tail & used the foam from the original seat.
[IMG][/IMG]
I made a /5 style headlight. That's why I had to move the Fuse panel.
[IMG][/IMG]
The picture is a little blurry but you can see it's taking shape.
[IMG][/IMG]
Here is the finished product. I used LED's for the idiot lights.
[IMG][/IMG]
Templates for side panels & front fender.
[IMG][/IMG]
Side plates done. Front fender cut. Almost ready for paint.
[IMG][/IMG]
[IMG][/IMG]
Almost finished!
[IMG][/IMG]
[IMG][/IMG]
So here she is all finished.
[IMG][/IMG]
gozany is offline   Reply With Quote
Old 05-01-2010, 09:20 AM   #2
Detroit Steve
Homely Adventurer
Detroit Steve's Avatar
Oddometer: 514
Very Nice!
My Stuff for sale: http://bmwsteve.smugmug.com/Other/For-Sale/i-SRK3jDN
Detroit Steve is online now   Reply With Quote
Old 05-01-2010, 09:31 AM   #3
Speed King
Speed King's Avatar
Oddometer: 1,650
I love it. Great job.
Speed King is offline   Reply With Quote
Old 05-01-2010, 10:11 AM   #4
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,745
Most excellent.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 05-01-2010, 10:47 AM   #5
rkatapt
Indo-Kraut
Oddometer: 261
Love the speedo in the headlight and the blacked out wheels. Did you rattle those?
I want a speedo on mine, but I don't want it to stick above the handlebars.
rkatapt is offline   Reply With Quote
Old 05-01-2010, 02:10 PM   #6
gozany OP
Oddometer: 8
Yep, I rattle canned the wheels & headlight bucket.
I was limited on placement of the speedo by the back of the headlight bulb & the angle of the cable. If you stretch the headlight body a bit you might be able to place it lower in the bucket. You could also use a different (smaller) speedo.
Old 05-04-2010, 09:34 AM   #7
Treadless
seeking adventure
Treadless's Avatar
Oddometer: 5,383
Hey n00b fill out yer profile eh.
Nice to see that all those hours spent harping at you didn't go waste.
Nice job on the bike! I'd like to see it sometime. Same phone number and address.
Treadless is offline   Reply With Quote
Old 05-04-2010, 09:54 AM   #8
wolfy317
Addicted to BMW
wolfy317's Avatar
Oddometer: 3,494
I'm soon to be cafeing my 75/5...did you address yours in a way that you could tilt the seat pan and still have easy access to the underside? Also, where did you get those sweet sweet handlebars?
Loving the looks by the way
'71 BMW R75/5 | 09 GSA
FLICKR
wolfy317 is offline   Reply With Quote
Old 05-04-2010, 10:03 AM   #9
ivantheterrible
Oddometer: 610
great job. I want to do something similar to my r65's speedo/headlight. Do you have anymore pics of that process? If not, could you describe it best you can? thanks
ivantheterrible is offline   Reply With Quote
Old 05-04-2010, 12:43 PM   #10
Curvy
Lost Planet Airman
Curvy's Avatar
Oddometer: 8,014
Sweet.
Memories stalk my dreams and torture my tattered old soul.
Curvy is offline   Reply With Quote
Old 05-04-2010, 05:37 PM   #11
gozany OP
Oddometer: 8
It was not wasted. I may have been though. All jokes aside I learned more from you than anyone. Your one of the finest craftsman i've ever met. Honored to have learned from the master.
Old 05-04-2010, 05:43 PM   #12
gozany OP
Oddometer: 8
The rear tail comes off easy. Just 1 bolt holds it @ the back & it slides in the frame tube @ the front. I welded in a tray to hold a tool roll. You can see it in the pics. I think I got the bars from caferace.com. If I remember right the were only about $20.00. Let me know if I gave you the right site for the bars. I'll check my receipts.
Old 05-04-2010, 06:19 PM   #13
gozany OP
Oddometer: 8
Ok here goes:
1 Remove all the wires & relays from inside the headlight bucket. You will need to lengthen all the wires going to the fuse block. It's the worst part of the job.
2 Cut a big ass hole in the top rear of your headlight bucket. A little bigger than your speedo.
3 Set your speedo in the hole with the cable attached & put the bulb in. This will give you a idea of how far down you can go in the housing & how much you can tilt it.
4 My speedo was in a plastic housing that sat on top of the bars. So If this is the case with yours you need to find a metal cover for it. I used one off a 305 Kawasaki. It fit perfect.
5 Weld the cover to the headlight bucket. I shaped the pieces so it would flow into the headlight bucket.
6 you'll need to make a bracket to hold the speedo in place from the underside. A strip of metal screwed into the headlight bucket.
That's pretty much the bullet points. It's a bit of trial & error.
If you've got time & a welder i'm sure you can pull it off.
Sorry I don't have more pics to share of the process.
Hope this helps. Good luck!
Old 05-04-2010, 08:19 PM   #14
wolfy317
Addicted to BMW
wolfy317's Avatar
Oddometer: 3,494
Caferace did have the handlebar; thanks.
I'm wantin to set up my seat so that I can tilt it. I'm thinking of finding a seat pan and cutting it to fit inside the cafe tail, so that I can use th stock mounting, but I'm not sure it will work out that way.
Love the bike man, looks sweet!
FLICKR
Old 05-05-2010, 06:38 AM   #15
ivantheterrible
Oddometer: 610
thanks for the write up on the Headlights.
Times are GMT -7.   It's 09:16 AM.
