06-14-2010, 04:17 PM
#46 |
Oddometer: 2,399
O'Hooligan,
Nice looking Transalp in the background.
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
06-14-2010, 05:39 PM
#47 | |
Despair & Repair Garage
Oddometer: 2,039
2001 HD XL1200S 1977 Vespa + 1985 Honda Elite CB550K project. "Man whoever came up with Ronald McDonald was dropping some serious acid.." - SpoonKiller / tiotalruckus.com |
06-14-2010, 05:43 PM
#48 | |
Ken Dodd's dads dogs dead
Oddometer: 531
06-15-2010, 10:47 PM
#49 |
WeeBeastie
Oddometer: 18,211
rack time
So I went to the local metal shop.
Picked up some 5052 aluminum ![]() bit of card board for template ![]() I am going to make a rack for when I don't want the top box mounted. I got a sweet 1450 in the FM so that went on the GS and the smaller box is going on the beastie. ![]() Time to cut, dremel scroll saw and some fork oil only had a 15 tooth blade, but it cut the softer 5052 without much trouble. ![]() ![]() first cut so it has space around the back bar. ![]() bit more cutting ![]() Now some tie down spots, drilled then cut out with the scroll saw again. ![]() ![]() Ran the sander over the plate and filed a few sharp corners. Washed with water then wiped clean with some paint thinner to get ride of any grease before painting. Now some primer, self-etching did a great job on the last rack I made and it had just enough left in the can. ![]() 2 coat on the top and 1 underneath. Styling paint booth huh ![]() It dries pretty quick so first couple of coats of the finish. ![]() Picked these stainless steel cushion clamps, they worked great on the GS so they will be more than ample for the zuma ![]() This should hold it steady ![]() oh while it was drying I mounted the other box on the GS ![]() going to have some fun wiring this up with some electrics ![]() then some reflective tape for visibility. ![]() OK, back to the zuma Still needs to dry over night before drilling the mount holes, I wanted to take advantage of the sun so I painted first. ![]() looks pretty good if I say so myself ![]() ![]() will mount the smaller pelican on top more to come.....
⊕R1200GS⊕ ⊕Zuma 125⊕ Save $5 on Smugmug "so9RUAXlMm0bE" |
06-16-2010, 07:12 AM
#50 |
Scootarazzi
Oddometer: 1,243
Way cool!
I see you have cut outs on the sides - can you bungie stuff to the top or is the aluminum too thin to do that? BTW - I am cursing you daily since your blog makes me really want to run out and get a Zuma! Keep the posts coming! |
06-16-2010, 08:53 AM
#51 |
Ronin
Oddometer: 1,838
NICE job on the rack!
06-16-2010, 09:05 AM
#52 |
Charismatic Megafauna
Oddometer: 46,039
![]() Well done!!!
Only an XR1200 owner knows why Cthulhu hangs its head out a car window. Like I like. Yep. |
06-16-2010, 09:43 AM
#53 | |||
WeeBeastie
Oddometer: 18,211
Once it is finished I will load it up, the only thing is the rack is probably stronger than the amount of load the rack will carry ![]() Quote:
06-16-2010, 09:50 AM
#54 | |
Oddometer: 46,039
06-17-2010, 10:37 AM
#55 |
Oddometer: 65
How tall are you folks riding these Zumas (125)? I am 6'1" and weigh about 200 and am curious if anyone around my size has one and what they think. I have a feeling I would have the "monkey screwing a football" look!
06-17-2010, 10:54 AM
#56 | |
WeeBeastie
Oddometer: 18,211
06-17-2010, 11:12 AM
#57 | |
WeeBeastie
Oddometer: 18,211
stage 2
![]() So I got a few nice stainless steel fasteners and rubber backed washers to complete the deal: ![]() and it is almost done. Might mount my fav rubber diamond plate to prevent scratching and moving around of items while traveling on the rack. ![]()
⊕R1200GS⊕ ⊕Zuma 125⊕ Save $5 on Smugmug "so9RUAXlMm0bE" AngryScot screwed with this post 06-17-2010 at 01:14 PM |
06-17-2010, 11:24 AM
#58 |
WeeBeastie
Oddometer: 18,211
Beaten again
![]() Just as I was getting into the power band! ![]() views from the road: I thought I was a safety nut? ![]()
06-17-2010, 11:12 PM
#59 |
Minimalist adventurer
I think it is so funny when a car or truck shows you up and all you can do is say " I'M A SCOOTER, WHAT'S THE POINT" " I'M A SCOOTER".I've had cars rev their engine at me and it is just making them so small. Once you get an exhaust the fun begins with other people. |
06-18-2010, 07:06 AM
#60 | |
Oddometer: 511
Honi Soit Qui Mal Y Pense. |
