Old 05-12-2010, 10:36 PM   #1
Canada Mike OP
Canada Mike's Avatar
Oddometer: 292
? Installing OEM GSA Driving Lights on a GS
Hello,
Does anyone have any hints on the connection points to the canbus. I purchased used off another inmate here a complete OEM GSA Driving lights off a 2007 GSA (I have a 1200GS 2007). The wiring harness looks simple, two connectors for the lights, switch, and the 4 pin connector for the canbus( power). Well there is also a fuse box and a relay wired in the harness as well but I'm mostly wondering about the canbus connection to the bike.
Anyone done this already?
Cheers,
Mike
2013 F800GS
Canada Mike is offline   Reply With Quote
Old 05-13-2010, 04:50 PM   #2
Canada Mike OP
Oddometer: 292
Seriously Nobody?
Nobody has done this yet?
Originally Posted by Canada Mike
Hello,
Cheers,
Mike
2013 F800GS
Old 05-13-2010, 05:09 PM   #3
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Take the tank off and look for the connector on top of the computer box.
Burnszilla is offline   Reply With Quote
Old 05-13-2010, 09:33 PM   #4
Canada Mike OP
Oddometer: 292
YES Yes YES....Thanks so much... I hadn't even confirmed if it was possible to put these on the GS.
But really thanks a lot!
Mike
2013 F800GS
Old 05-14-2010, 10:19 AM   #5
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Can you post photos of your harness. I'm curious if you could use the BMW harness and switch to install aftermarket lights. A macro shot of the connector into that connector I posted above would be nice too.
Old 05-14-2010, 10:49 AM   #6
Canada Mike OP
Oddometer: 292
Will do...
2013 F800GS
Old 05-14-2010, 11:39 AM   #7
Jolly Roger
Jolly Roger's Avatar
Oddometer: 587
Yes, I'd also be interested in some close-up photos of the harness as a friend of mine is wanting to do exactly the same thing as you. He's a bit of a noob when it comes to anything "electrical" so anything we can do to help him out would be great.
Jolly Roger is offline   Reply With Quote
Old 05-14-2010, 12:22 PM   #8
Pcfly
Dude?! Seriously??
Pcfly's Avatar
Oddometer: 1,124
This might be a dumb question but.... Do you unplug that round placeholder then plug it into that? Is this where the GSA Aux light switch (from the left handgrip) plugs into?
2011 Husqvarna TE-630 The Red Raptor
2012 Yamaha 50th Anniversary Badass-Sounding R1
2008 BMW 1200GS The Blue Rhino (SOLD)
Pcfly is offline   Reply With Quote
Old 05-14-2010, 01:36 PM   #9
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Check out the harness. It looks like the plug on the very right end plugs into the top of the computer plug.
Old 05-21-2010, 11:42 AM   #10
Canada Mike OP
Oddometer: 292
Sorry I took so long with the pictures...Here's what I've done so far...
Remove Tank as per manual. DIS-CONNECT THE BATTERY NOW!!!!!!
This plug on the top right is a dumy plug that will actually come off, and be replaced by the one on the harness. I'll show you later...
This is the close up of the plug on the harness that connects to the bike wiring ( top right on cpu panel.
Open this tray with a small scewdriver to pop up the tabs
Swing this top CPU part out of your way.
Un-plug the bike harness wire from the dumy plug.
Use a small screwdriver on the left of the plug to move the latch and slide it off to the right.
This is the OEM harness plug shown earlier...slide it on
Plug in the OEM bike harness plug to the installed outlet.
Now install the connector for the switch to the other side.
The top item in this picture goes behind the CPU. It can be swug up and tye wrapped to the plastic.
Route the cabling down to the front beak for the driving lights.
Riders right side...Fuse panel mounted to the post on the bike. I have the BMW part on order for this attachment. It is a GSA part number and will let you know if I get the correct one. Tye wrapped and velcro for now.
Reconnect the battery once the lights are connected and check for fault codes.
All is good....I have just received the 2009 left control upper and lower to relocate the switch from the top of the forks to the left hand controls. NICE should work well. I'll send some pics once completed.
Cheers,
Mike
2013 F800GS
Old 05-21-2010, 11:45 AM   #11
Canada Mike OP
Oddometer: 292
Nope do NOT plug into that...Drop me a line if you have any questions...
2013 F800GS
Old 11-04-2012, 07:42 PM   #12
paco fernandez
Mexico
paco fernandez's Avatar
Oddometer: 64
Wicked Nice
Tahank you so much, ery helpfull
paco fernandez is offline   Reply With Quote
Old 12-04-2012, 06:33 AM   #13
dseric
Living for Adventure
dseric's Avatar
Oddometer: 262
Has anyone tapped into this part of the harness for aux light power or as a trigger?
Seems this wire will not power up till after start just like the headlight.
"Modern travel is all about the destination, except with a motorbike."
dseric is offline   Reply With Quote
Old 05-13-2013, 08:05 AM   #14
dseric
dseric's Avatar
Oddometer: 262
Just to update this thread and contribute, I tapped into this harness after testing the wires. The purple/yellow wire adjacent to the brown wire only has 12v after the bike is running just like the headlight. Great spot for AUX light trigger so as not to stress battery before startup. Would make the lights only run until after startup.
On my '09 SE GS the harness was on the top left of the ZFE module. It seems all have this harness if your bike was an '08 or later. Please correct me if I am wrong.
Photos:
Location and removed from holster on ZFE module:
Red trigger wire is Posi-tapped for my Skene Lighting controller and the is harness put back into holster:
Old 08-20-2013, 03:47 PM   #15
Penfold99
Oddometer: 56
This is exactly what I was looking for, great thread...
Does anybody know (before I pull my tank off) if that 4 pin aux connector is on a 2005 1200GS? I have the complete set with this harness (from an 07 GSA). I don't want to pull my tank if I am chasing a dead end...
Hope some of you with pre '06 bikes have been down this road and can help.
Also, can you clarify the fuse box, and relay box mounting locations.
Thanks,
Dave
Atlanta
2005 R1200GS
Penfold99 is offline   Reply With Quote
Times are GMT -7.   It's 12:08 PM.
