Old 07-01-2011, 09:31 PM   #226
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
i wrap the headers of the old bikes i pick up that are rusty. i just prefer its look to rust. when i tried to remove the factory heatshield the bolts snapped off so i just left it off and wrapped the whole thing. it does insulate the pipe and act as a heatshield also. its just a last ditch effort before a new pipe is bought. i noticed factory header still available for around $150. maybe one day. it just developed a base gasket leak i need to worry about next...
'90 honda cb-1
'85 suzuki sp600
stussels screwed with this post 07-01-2011 at 09:41 PM
stussels is offline   Reply With Quote
Old 07-10-2011, 03:21 PM   #227
tdrrally OP
tdrrally's Avatar
Oddometer: 2,863
has any one wrapped the muffler?
mrs tdrrally has issue with the heat from the muffler
2002 DRZ250 what it lacks in horse power it makes up for with traction for sale
2000 DRZ400e tagged
1980 TS125 project in the corner
200? zuma 50/70 the wifes bike
tdrrally is online now   Reply With Quote
Old 07-11-2011, 10:28 AM   #228
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
have never went any further than the header myself. i dont think it would make enough difference to be worthwhile on the muffler, but i do not know. ceramic coating may be better for that?
'90 honda cb-1
'85 suzuki sp600
Old 07-14-2011, 06:06 PM   #229
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
new old stuff
found an uncut oem muffler to get it back to stock noise levels. of course it doesnt sound as good as with the open pipe but i find i prefer it quiet. fits better too than my rigged up muffler. found some fork reflectors that were missing just because. changed her oil and filter today and adjusted the balancer chain while it was drained. it appeared to never have been done by the amount of slack in it. also repurposed my oem honda cb-1 mirrors on this bike. much better quality than the cheapo chinese ones i had bought for it. even got some cheapy ebay double row footpegs for it. getting better still.
'90 honda cb-1
'85 suzuki sp600
Old 07-14-2011, 06:10 PM   #230
tdrrally OP
tdrrally's Avatar
Oddometer: 2,863
looking good!!!
2000 DRZ400e tagged
Old 08-29-2011, 09:09 PM   #231
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
more power!
rejetted the carb saturday. even with the stock muffler it really pepped it up. ended up raising the needle one position and a larger main. im still fiddling with idle settings. problem that arises now is my clutch is slipping. if i adjust the other way it drags too much. im looking at a barnett kit now. just havent pulled the trigger yet.
'90 honda cb-1
'85 suzuki sp600
Old 09-10-2011, 09:12 AM   #232
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
lonely sp600
well ill just keep posting to myself. itll be my online log of what and when i did stuff to the bike. last weekend i replaced the clutch with a barnett kit. no probs til i snapped off the last bolt to tighten on the cover. grrrr, ive got a new bolt ordered and after fixing that i should be in good shape i think. everything dry except the base gasket weep. thats for winter.
'90 honda cb-1
'85 suzuki sp600
Old 09-10-2011, 05:17 PM   #233
brucifer
brucifer's Avatar
Oddometer: 1,625
Just because we're not saying much doesn't mean we aren't looking.
You've got that baby looking really good. Nice work, man.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 09-13-2011, 05:33 PM   #234
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
Thumb
thanks man. i took the cam cover off and helicoiled a stripped bolt hole that was causing a leak. also replaced the seal for the auto decomp as it was wet too. sealed it back up with some toyota cam cover sealant. checked and adjusted valves on the way out. two were tight but not by much. once i get the clutch cover bolt worked out itll be pretty well dried up
'90 honda cb-1
'85 suzuki sp600
stussels screwed with this post 09-13-2011 at 05:56 PM
Old 09-17-2011, 02:01 PM   #235
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
ok, now its ready
extracted the broken bolt and sealed the sidecover back up. all good now. got the idle under some control now. no more weird hiccups. now ive got a new starting routine to learn though, hehe. i think its gonna be best to not even use the choke now. need more time with it and its new jetting, but its running strong. woohoo!
'90 honda cb-1
'85 suzuki sp600
Old 09-17-2011, 06:10 PM   #236
tdrrally OP
tdrrally's Avatar
Oddometer: 2,863
here's a pic or two
at last
2000 DRZ400e tagged
Old 09-17-2011, 08:18 PM   #237
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
hard to make out what wires do what in this pic. what color are the wires that just go to the tach? i should just compare schematics maybe. thank you for posting-
'90 honda cb-1
'85 suzuki sp600
Old 09-18-2011, 05:24 AM   #238
tdrrally OP
tdrrally's Avatar
Oddometer: 2,863
i'll scan and post the diagram i have
2000 DRZ400e tagged
Old 09-18-2011, 09:30 AM   #239
tdrrally OP
tdrrally's Avatar
Oddometer: 2,863
i hope this helps
2000 DRZ400e tagged
Old 09-18-2011, 01:37 PM   #240
stussels
chupacabra!
stussels's Avatar
Oddometer: 133
pics!
ah yes, thanks for that tdr. should be able to figure something out there. now today a friend and i rode down to wayne nat'l forest. i jumped in the woods and he went off to explore backroads on his honda hawk gt.
i havent been off road on two wheels since in my teens and i must say it was quite challenging. first off, the bike is geared way too tall. even in first there was way too much clutch work required. my arms were pumped in minimal time as it was greasy out there. i shouldve started at a higher, drier point but oh well.
did about 170 miles total and never filled up or hit reserve. started with a full tank. overall a great though humbling day
on the way:
this way to mud and rock strewn water crossing:
cliff face:
thump deville:
mug with new econo vega flip up:
'90 honda cb-1
'85 suzuki sp600
Times are GMT -7.   It's 02:45 PM.
