Old 05-18-2012, 05:14 AM   #271
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Just as i posted this i thought the location maybe would cause some heat troubles. Good thought there Lukas. When exhaust is done it will be ceramic coated inside/outside. I don´t 100% understand the vaporlock could/would you explain?
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 05-18-2012, 07:44 AM   #272
LukasM
Oddometer: 5,427
Basically the header might heat up the fuel enough that it causes it to change from liquid to gas form, which the engine can't burn. No fuel pressure, no power, stalling, etc.
Is there enough room to mount it further left near the oil heat exchanger thing (if that's what it is) or a bit further up? A heat shield with some reflective material would also help a lot and be easy to make with an aluminum sheet.
Old 05-18-2012, 07:45 AM   #273
Geek
oot & aboot
Geek's Avatar
Oddometer: 32,070
Mikael
It occurs when the liquid fuel changes state from liquid to gas (or vapor) while still in the fuel delivery system. This is caused by heat.
In your case, the heat from the exhaust header being so close to the fuel pump could cause the gasoline in the fuel lines to become a gas (vapor).. causing the fuel pump to not be able to pump (because it pumps fluids.. not vapors); i.e. loss of feed pressure to the carburetor or fuel injection system.
Hope this helps.
p.s. the boiling point of gasoline is anywhere from 100-400 degrees F .. depending on pressure (altitude, etc).
edit: looks like Lukas and I were typing at the same time
Old 05-18-2012, 04:45 PM   #274
K2m
....58....
K2m's Avatar
Oddometer: 2,238
This is what a ceramic coating looks like after a while. Maybe I was just unlucky
Stainless ceramic coated Before use/After use
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m screwed with this post 05-20-2012 at 11:58 PM
K2m is offline   Reply With Quote
Old 05-18-2012, 04:56 PM   #275
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,151
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 05-20-2012, 12:44 AM   #276
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Update
Blinkers attached
Headlight LC8 headlight to RC8R wire harness.
Dont know the english word for this. I mounted up perfect here.
All this while Søren blasted down the road. The frame should be from a 99 LC4 ex Dakar bike.
Regarding the Vapor lock talk, i´m fiddling with a new place for the fuel pump. Update will follow.
Mikael
KTM 530 EXC-R 08
Old 05-20-2012, 02:39 PM   #277
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Anyone know what this is?
UnOB
KTM 530 EXC-R 08
Old 05-20-2012, 03:16 PM   #278
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,920
it looks like a pipe to feed water to your fridge,for cold drinks/ice etc
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd screwed with this post 06-01-2012 at 03:31 PM
mickd is offline   Reply With Quote
Old 05-20-2012, 04:25 PM   #279
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Chain oiler......... ??
Old 05-20-2012, 04:28 PM   #280
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,894
Bubble wrap!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 05-20-2012, 07:36 PM   #281
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
UnOB
Something from Australia??
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 05-20-2012, 09:17 PM   #282
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Unobtanium.
Welding rod for the dreaded aqualines.
KTM 530 EXC-R 08
Old 05-21-2012, 12:09 AM   #283
K2m
....58....
K2m's Avatar
Oddometer: 2,238
It is good to see your bike with the engine in it. It's really taking shape
Try to get photos of your mate welding them. That would be very interesting to see.
It's time for me to start thinking about a dash. Inspired by yours I will do something very similar.
I love the look of this Dakar Mini dash. I am getting ideas from it to combine with your shape and fitment.
My last dash was very basic. This time I want to excel......
Functional but very basic
And later....... That is realy a very usefull place to have the tacko. You loose a lot of time hitting the rev limmiter. It is in your vision while looking ahead at the road. It makes a huge difference
K2m screwed with this post 05-21-2012 at 01:50 AM
Old 05-21-2012, 12:29 AM   #284
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
Yes it's an old rallye from 98-99. I've build in a new 640 engine as the old one was finished...as in really finished! New mikuni flat slide carb and a sxc exhaust and it's pretty much rideable. Clocked 140kmph on gravel yesterday so the old thing still works!
Now we are waiting for a playmate...
Søren
SorenSand is offline   Reply With Quote
Old 05-21-2012, 02:00 AM   #285
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,894
If u want to see a dash check out the new ducati pannigale(???). LCD brilliance. Better then my laptop screen. Not sure how it would hold up in a spill tho???
Pete
Times are GMT -7.   It's 12:17 AM.
