Old 07-04-2010, 12:32 PM   #16
Balsta
Oddometer: 400
Originally Posted by Locul@hotmail.com
Not that iŽm any nearer the project but something got aside this day.
It is possible to mount the engine. The images is from Robie Peterson(hillclimber). As you see its a LC8 frame without to much touchup...
This is very good information.
I have exactly the same plans as you for my SE06 after 75000 km. New RC8 engine. Winterproject 20111-2012 perhaps. Im afraid the ground clearance will suffer too much. How many centimeters (inches) do you guess from the photos? My other major concern is space for the radiator. I dont want the FI. Pity the FCRs are only available in max 41 mm. Why not just put the 43 mm vacuum carbs and keep the aftermarket exhaust for the 950? Say less power on full rpms but prob a tremendous bottom force!! And...forget about the "too much for the frame..." Much more (>300 hp) is required to twist these.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 07-04-2010, 12:42 PM   #17
Balsta
Oddometer: 400
Originally Posted by mousitsas
...I also think that 150bhp is not what this frame, suspension, swingarm etc are made for. Just have a look at how different the swingarms between the 950 and RC8 are....
I think the RC8 fat frame and swingarm is more for stability and non-wobbling at +300 km/h. Mechanical sturdyness cant be an issue. Suspension and brakes is for speed, not for power and torque.
Old 07-04-2010, 01:25 PM   #18
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,351
I donŽt think that ground clearance would be to bad for the Adv. Anyway iŽll do the 320 or 300mm suspension. If you are thinking hardcore enduro with a RC8 SE it could probably be a problem, but then you will have many other concerns as controlling 150+ hp on wet logs...
I do agree that the radiator can give some problems. I was hoping i could keep the LC8 radiator and double fan it. But space is tight.
As i said, i dont think clearance would be a problem as long we are talking adventure riding.
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 07-04-2010, 01:39 PM   #19
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Wow, I'm surprised that fits so well. Looks like the stock radiator might fit down low in between the sump and the head, a little further back than stock (depending on routing of the header):
jamesbrown is offline   Reply With Quote
Old 07-04-2010, 01:40 PM   #20
Balsta
Oddometer: 400
Cry
I do agree that the radiator can give some problems...But space is tight.
Mikael
Youre right, ground clearance is not an issue BUT
No way my radiator would fit there
I think they had to tilt the motor forward a little
Ill go for a "hotrod" LC8 990 instead
Old 07-04-2010, 02:31 PM   #21
DirtyADV
DirtyADV's Avatar
Oddometer: 2,360
Maybe the radiator can be mounted they way they had them on old three wheelers?
P.S have a red tecate from -85 =)
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 07-04-2010, 04:16 PM   #22
Benz
Oddometer: 417
The rad will fit. Just can't run a fender.
2014 Yamaha Bolt
Benz is offline   Reply With Quote
Old 07-04-2010, 04:19 PM   #23
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
I'm not so sure under full compression of the front forks with a 21" front wheel; and if Locul's past exploits are anything to go by, it will be used under full compression
Old 07-04-2010, 04:27 PM   #24
Benz
Oddometer: 417
I still think there's plenty of room with no fender, or a modified one anyway. If you mount it right above the sump up against the cylinder head it looks like there will be more clearance than on the RC8. I'm just judging by pics. I really have no idea what I'm talking about.
2014 Yamaha Bolt
Old 07-04-2010, 04:55 PM   #25
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Likewise However, the front header pipe needs to go somewhere....
Old 07-04-2010, 04:59 PM   #26
charlie264
charlie264's Avatar
Oddometer: 8,367
And Peterson run there 950 LC8's on Nitro, only 200bhp. 1190 Nitro in dirt!!! Just mad.
Old 07-04-2010, 05:13 PM   #27
Benz
Oddometer: 417
Why not just take a 990 motor and have a bunch of work done to it? It will handle much better in the chasis and have a better power curve for your type of riding. You can do a lot of stuff I would imagine. Porting and polishing the heads, valve job, forged internals with high compression pistons, balanced and blueprinted. Have a shop make a custom ecu tune for it and that would be a pretty beast motor.
2014 Yamaha Bolt
Old 07-05-2010, 03:30 AM   #28
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,834
950/990 vs whatever
I say go for it - experimenting only improves the breed - hell KTM will do it sooner or later. If a crowd in Austria or thereabouts can put a merc diesel in one than why not the RC8? I like your thinking - now get to work.
What a great way to destroy a nobbie rear......
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-05-2010, 09:01 AM   #29
SSrider
SSrider's Avatar
Oddometer: 121
Originally Posted by HWSNBN
If I was just divorced, I'd not waste my time wrenching when I would pick up a perfectly good 950 and hit South America with a handful of dollars and a boxful of condoms... just sayin'
HERE HERE !!! HIT THE ROAD JACK !!
KTM 990
KTM 640
KTM 520
KTM 380
KAW klx650
Honda xr75
Honda trail 50
SSrider is offline   Reply With Quote
Old 07-05-2010, 09:15 AM   #30
tommytiger
just riding
tommytiger's Avatar
Oddometer: 115
2: Touratech tanks front and 2x10l back.
so you will have 64 liters with you in your 300kg KTM
Tom
_________________________________
- 2005 KTM Adventure 950 S
- 2011 KTM Adventure 990 R
tommytiger is offline   Reply With Quote
Times are GMT -7.   It's 10:35 AM.
