Old 05-21-2012, 03:17 AM   #286
K2m
....58....
K2m's Avatar
Oddometer: 2,239
www.1199panigale.ducati.com/Cached
You +1'd this publicly. Undo
Ducati 1199 Panigale: new 195 hp Superquadro engine, incredible weight of 164 kg,
Wow. So much power so little weight
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 05-25-2012, 04:29 AM   #287
K2m
....58....
K2m's Avatar
Oddometer: 2,239
In another thread it was pointed out to me the limitations of not having a sealed air box especially in river crossings. So I got to thinking about it and realised that it was possible to modify the tank into a sealed air box.
There were two options available. The first was to join the top of the air filter area to the top of the tank. The beauty of this was the FCR roar would not be muffled by the fuel. An attractive proposition indeed.....
The second was to run tubes to the front of the tank, then flex tube into the faring where air scoops would catch the air..... pressurising the air box which from a performance point of view is preferred. It's like turbo charging, but much less. The effect is to lessen/overcome, power losses in the intake. A well known trick to car modifiers.
Although I love the FCR Raaaawwwwwwww...... I went as usual for power.
My air scoops will look like the 450 Rallies........... Perfect as my new screen is copied from the 450. It all should match up.
With the LC8 the fresh air comes through the grill. On the 450 the oil cooler lives there so there are two scoops directing fresh air towards the air box. Also worth noting is the position of the regulator/rectifier in the bottom photo. In the air stream !!!!
Old 05-25-2012, 08:13 PM   #288
K2m
....58....
K2m's Avatar
Oddometer: 2,239
As I was about to finish off the tank building the air box was presenting problems. I had not designed for an air box so space and sealing was going to be difficult to retro design. So I opened the tank again and....
I made the tubes by wrapping some PVC pipe with 2 layers of Carbon. Then cut it both sides down the middle, popped the carbon, then wrapped with Darnell cloth. Darnell has a good finished texture holding a layer of Vinalester.
K2m screwed with this post 04-04-2015 at 12:33 PM
Old 05-25-2012, 09:27 PM   #289
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
viola-tor is offline   Reply With Quote
Old 05-25-2012, 11:37 PM   #290
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,132
Originally Posted by SorenSand View Post
Yes it's an old rallye from 98-99. I've build in a new 640 engine as the old one was finished...as in really finished! New mikuni flat slide carb and a sxc exhaust and it's pretty much rideable. Clocked 140kmph on gravel yesterday so the old thing still works!
Now we are waiting for a playmate...
Love this bike
Are the 50mm extreme forks original to the rally bike? That bike looks like the real deal adventure bike. And it gets me looking at my 99 LC4-E and thinking "maybe a little fairing wouldn't look so bad"
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-29-2012, 06:40 AM   #291
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
As it was born...54 litres of fuel, a kickstart engine and a noisy exhaust....just a bike for Locul!
Søren
SorenSand is offline   Reply With Quote
Old 05-29-2012, 04:51 PM   #292
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Is this the playmate??? for the other bike........... We don't get many rallys in Oz.
Or is this what it looked like originaly?
Old 05-30-2012, 01:07 AM   #293
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
It's the look of my Rallye when I bought it 6 years ago. I have taken of the rear fuel tanks and changed the front one to a paintable one.
When the 1190 is finished we are going to the beach...
How long must we wait?
Søren
Old 06-01-2012, 01:21 AM   #294
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Big projects can take forever. I started mine last November. A group of us were planning a 2 week trip in the Bulldust (FeshFesh) of outback Oz. I wanted to remove weight from the front wheel. The trip was in April this year ....... I will be lucky to be ready for April next year. Fortunately wet weather has postponed this trip for a year.
I think you should safely put away your rally exhaust and rear tanks. These things are treasures for many people around the world who do not have access to them.
Old 06-01-2012, 04:38 AM   #295
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
Nothing has happened on the bike. Work has taken my time, i have tried to cut my old tanks and made the countersinks were the radiator sits. I made it 50% succesful. The other went bad. To much curved details made it to difficult to get the layers sit tight. Process of learning. Though it isn´t my primary tanks(original) that i will use. I just tried to learn something about my limits around this wet layering. No more sharp corners. More thought to the primary cuts so the layering will meet less sharp corners.
As some of you know the aqualines is the primary choice. Safaritanks have not been super helpful, they shipped the welding rod. Kind if them but if they just have passed the plasticcode on to me right away, it would have been way easyer. Yesterday i took the trip to our plastc welder again. He laughed and asked if they(safaritank)have been more helpful. I said no. I showed him the welding rod and he tried to weld a small spot. Glued perfectly on. He mentioned that we still would need some more material when making the room for the radiator and oilcooler. He cut cm´s of the weldingrod and send it of to some plastic analyzer. They will determine the "code" and we buy our own raw material.
Yes this is taking some time and the learning curve is steep some times. Next week i will try get the exhaust and the rest of the electrical wiring done.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 06-01-2012, 12:35 PM   #296
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Ahh nothing may have happened but you're trying something that most of us never would have even attempted. Do you realize that you're closer to being done than not? Fix the tanks, slap them on, and fire it up. May not be perfect but it'll be close enough for the time being.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 06-01-2012, 10:15 PM   #297
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
Katoom119: Thanks for the kind words.
Some pictures from the past week with the good and bad stuff.
I may have done some wrong stuff here. It cured SO fast that it heated up and begun smoking. Ofcourse some of you clever heads understands the process, i didn´t. Placed it outside and never used glass anymore.
Not for the beauty, but i could make the rear panels strong and way more resistant for tear and abuse.
FYI: It was the big hole that went good. It pissed out of the smaller one. Needless to say that the cornering was bad for my skillset. Though it CAN be done. Just have to take it off again. Then use some of this fine chopped strand mat. My thoughts are it will take the corners way better. The glass i used here was some leftovers, 350gr i think a bit to heavy as it won´t sit tight in the corners. But no matter what my fail and will be better next time. It is very skill-sharpening to fool around with these tanks and the epoxy. No turning back as the cut has been made. Actually Søren(640 rally) made a pretty succes full weld with two tank parts i´ve cut out of mine. Didn´t look nice but the bound was strong. But impossible to do in the tight areas.
Have a nice weekend.
Mikael out
KTM 530 EXC-R 08
Old 06-04-2012, 04:41 AM   #298
K2m
....58....
K2m's Avatar
Oddometer: 2,239
The resin's curing process develops heat, because it is deep in the cup it sets of a chain reaction of heat > cure which makes more heat> more cure> more more heat> more more cure until it smokes
You might have added a little to much MEKP..... Probably
If that cup is made of glass you are lucky it did not explode in your hand taking it out If you
Old 06-05-2012, 11:28 PM   #299
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,793
Hi Mikael,
Im guessing your using epoxy due to the clarity which will give off a higher exotherm when it cures, especially in a tight mass like in the glass. If you had the same amount in a wider container like an ice cream tub then it would go off slower as there isnt as concentrated a mass as there is in the glass. Same amount just stored differently.
General rule of thumb is to mix 2 x the weight in resin as the glass you are using. (You need to weigh the glass of course). 2:1 is the general amount of resin you will need to wet out the glass in a hand layed laminate. If you want to slow the geltime you can also cool the resin in a fridge or snow in your case but not too much so you cannot use it because it becomes too thick.
Bikes looking good - great project. I think a set of black tanks at the back would look good........
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 06-09-2012, 07:07 PM   #300
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
Pete: Thanks for the info. The 2 x 1 is spot on.
Some steps from the last couple of days.
Well had a "chance" to redo the fail from before.
I have recieved my order at a German company regarding new fibres and resins. 80 gr is pretty light weight but will give some fantastic detailing when wet working.
Crossing my fingers that this will work. A bit more brain to the details this time.
The air bubbles did get out...
Last layer. Waited 2 hours for this one. I was sure to get a perfect fit when the resin is super "taggy".
Approx. 8 layers of the 80 gr.
Testfit.
It fecking FITS. I´ve put gas in it this night to test it. So far so good.
Oh did some testing to see how much the other would be needing...sheeskebab.
No adjustment needed any more.
LOTS needed.
uhhh
Got a package this day.
Motorstuff...yeah
My NEW airfilter. ITG Airfilters, I of course went with the "sausage" model on the baseplate JC30.
The coolness about this is that you can choose a baseplate to customize for your self. Perfect in this project.
Packed with RC8R
If the tank keeps tight untill tomorrow i have solution with my original tanks. A bit of trackday, sundayblast bike. And furthere more, only exhaust keeps me from fitting the lambdas...oh the lambda( Bazzaz kit neglects the 2 original and only use 1). And we are closer to engine test start.
KTM 530 EXC-R 08
Times are GMT -7.   It's 04:41 AM.
