Old 12-15-2012, 10:14 AM   #361
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,119
Originally Posted by LocuL View Post
Here is microfiche view.
990 efi
1190 RC8R
BUT sheees the price from new is insane...
4,600.00 SEK = 688.953 USD
wow. Ebay here we come.
There are some threads around here about people switching to an external FI pump, I think CJ was looking into making an adapter plate for the tanks that have a FI pump hole. There are adjustable pressure regulators that may let you use a FI pump from another vehicle on the KTM. But yeah, the simple solution is to use a LC8/RC8 fuel pump in there, and I'm guessing they'll be fairly pricey on ebay, since there are plenty of people that want a spare.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 12-15-2012, 05:09 PM   #362
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,779
Hey Mikael,
I had the same issue with the suspension/swingarm/rear exh header/sidestand relocator. I cut a notch in the bar between the 2 mount points and it was no problem. Sure its very tight but it works and Im still keeping the 2 mounting points.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 12-16-2012, 12:14 AM   #363
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
uhhh...pete you shouldnŽt have a picture or 2 of that? IŽm not in a hurry, but could be helpful visualizing how to make it.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 12-16-2012, 04:54 AM   #364
tileman
tileman's Avatar
Oddometer: 875
Speaking to safari tanks a while back about fuel pumps they told me some of the dakar riders were using a fuel pump and reg from a suzuki quad racer 450lt or something like that. The pumps and reg were available on ebay or the like pretty often when I looked and the price was about right. Might be an idea if you plan to mount it outside. I looked at it for my suzuki project and found that the post reg pressure was pretty similar to most bikes i found details on suzuki/honda etc.
If ignorance is bliss, why arenŽt more people happy?????
tileman is offline   Reply With Quote
Old 12-16-2012, 09:46 AM   #365
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
Thanks for advice Tileman, but the 1190/990 fuel pump looks the way.
As i maybe have a running engine this comming week iŽve been working on tidying up cable and loose bolts hereŽn there.
I admit this have been some free styling.
Need to mount the EFI bridge stable and correct. It went fairly well without to much work. One problem that i now, for the first time could see the baseplate from the ITG airfilter would clash with my frame. Hey...i suck at this...
you can tell by the picture that this is way to the right. God Da..... Cost me a new baseplate(27Ł).
Frame rubbing.
Something that went ok was the mounting of the temp sensor in the airbox which doesnŽt matter now.
I have been looking into cooling options and what solution might be the best. I have no idea how hot this engine will be, but if i could double the cooling factor(2 x fans) it would be great. The size of the fans does have something to say in this. More on this later with some pictures.
KTM 530 EXC-R 08
Old 12-16-2012, 09:50 AM   #366
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
ohh...the butterflies went off as i was working there. Some claim 1 hp gain in this mod.
This got out
1 hp for this...
But that might the 1 hp that i need to get above 150 rear wheel ponies. SOoooo VERY important.
KTM 530 EXC-R 08
Old 12-17-2012, 12:49 AM   #367
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Those MAPs (Manifold Absolute Pressure) are one for each cylinder, they send a home signal to the ECU so that it knows which cylinder is inducting and which is exhausting. They work different to a car MAP in that they work as a switch. A car will inject fuel based on the MAP reading. The bike cannot do this as unlike a car that uses a plenum chamber to dampen the (4,6,8,) pulses the bikes single cylinder pulses to much for such a device to function. The tooth wheel on the crank gives degrease before top dead centre (TDC).... the third is atmospheric pressure. It will tell the ECU what to compensate for altitude and temperature along with the temp sensor.
This is just for your knowlege.... That fuel pump was.... interesting
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 12-17-2012, 12:54 AM   #368
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Michael that air filter base plate looks back to front....
Old 12-17-2012, 06:00 AM   #369
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
Mr K2M i stand corrected and thanks for the MAP efi knowledge.
Holy m..... There is a steep learning curve in this project. Even when an airfilter baseplate is troublesome to mount. wow. But then again the baseplate is ordered with some other bits. My temp sensor will not fit were i put it when i place it right.
KTM 530 EXC-R 08
Old 12-19-2012, 06:15 AM   #370
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,973
I have these plates back in stock. We made another small batch. They bolt to the Aqualine tanks and have 2 pipe thread fittings so you can hook up a pull and return line or plug as needed. Plus no more Rubber gasket that leaks so bad.
We use these on our carbed bikes and get rid of the main petcock. This is a great tap to get fuel for your camp stove, drain your tanks, or transfer fuel to another bike.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 12-19-2012, 07:51 AM   #371
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
It would be really cool if you had that plate with a large filter sock fixed to the inside over the fittings. And if there was an attainable, affordable external fi pump + regulator. Or did i miss something?
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 12-22-2012, 05:01 PM   #372
ktmr32
Oddometer: 15
rc8 engine
hmm thats a great project sorry to hi jack this thread i wanted to say that i am having an rc8 engine for sale and i am willing to ship it to USA if anyone is intersted just pm me
thanks
ktmr32 is offline   Reply With Quote
Old 01-03-2013, 02:36 PM   #373
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,328
Merry x-mas and a happy new year. And with these small happenings aside we can focus on the matters in life.
Dakar and AMA SX the 5 jan. YAY
Happy new year. From our street, it was a super windy evening.
With holidays in the books iŽve been able to agree with a KTM mechanic about a meeting. We will try look into these immobiliser woes. More about that in 24 hours. I collected some stuff and manuals for having answers to most of my problem. Box of luck...
Took some weight measures of the 2 pumps.
just so you know.
Made the seat lock work again. Will make some neat arrangement on it when Petes rear tanks gets to me.
Running with the lower front guard and the 320mm suspension have caused a problem. Not big but will need to address it because it hits the 48mm sealing lip and the alu is über soft.
I needed to get the Bazzaz speedo sensor and it worried me a bit to drill holes in the caliper mount. I did 2 small holes(3mm) and mountes the speedo sensor on that. Looks fairly ok, weŽll see in real life and muddy conditions.
All the ziptyes and black plastic tube looks stupid but the sensor cable is soft like butter. This was my best way(for now) to protect it against debris and such.
Some generel cable protection/clean up around the bike.
The original LC8 fan is mounted with some through-the-radiator cable ties. Very sturdy and easy to fix. Give me your thoughts on this. It is rock solid.
Will cut of the studs later.
Working on some new HID lights. IŽll try to make a better cut off with some integrated projectors. But the heating process was a bit tough on the light...
The yellow dusty something in the bottom is created from the 50HID. Not bye oven heat.
Ohh...and iŽm maybe picking up an Yamaha XT 250 tomorrow. It will be my daily driver and such. It just occured to me that J. Rambo in First blood made a get away on this type of bike. YEAH. I need a big knife and some long curly hair...safety 8th or something.
Exciting day tomorrow. Will keep you posted.
::cla p...
KTM 530 EXC-R 08
Old 01-03-2013, 06:16 PM   #374
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
All the best with the KTM mechanic!
snowhawk jockey is offline   Reply With Quote
Old 01-04-2013, 02:44 AM   #375
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
I wish i was any nearer to your location :)
Would like to take a shot at it. It is now successfully removed from my wiring tree.
Times are GMT -7.   It's 07:08 PM.
