Old 01-16-2013, 04:31 PM   #391
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
The dealer that I talked to had only ever sold one RC8 and a few 990 Adventures. I'm going to call a bigger one tomorrow that I know of where they sell a lot of RC8's.
That being said...
He didn't think that you could do anything with the orange key to "de-activate" and then "activate" the black keys; apparently it's not set up the same way the Ducati's are. He said the orange key was designed to reset the immobilizer.
I asked him what about the reset procedure? He replied that he'd only done it a couple of times but it was listed in the service manual in detail. He remembered having to press and hold the mode button (he thought) and that there was more to it, it wasn't just a "Insert the orange key and turn it off and on 5x".
So I asked him what about if I blow the engine on my RC8 and just buy a used engine, what do I do? The immobilizer and the ignition barrel would not be all on the same "key". He said, ok, this I know about. What he did was he had to call KTM North America, give them the VIN numbers for the engine and the bike and explain what he was doing, so that way KTM wouldn't think the engine was stolen. They then recut a black key for the ignition barrel but had it "activated" for the new engine, so everything worked just fine.
I told him you were in Europe and he said fire an email of to KTM Europe and explain what you're doing. If they ignore you then find a KTM dealer and have them talk to KTM for you; it may be that they think you're just trying to use stolen parts and would believe a dealer more. If that doesn't work, he said he'd be happy to be the liaison between you and KTM and he'd do whatever he could to get you a working key.
So, at least now you have a direction. You'll have to talk to KTM themselves, explain what's going on, and see if they'll give you a key that will work with that immobilizer. BUT you need to know the engine number the immobilizer came off of, which could pose a problem.
I'll call the other dealership tomorrow and see if they can confirm this since they sell a lot more RC8's and 990's.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-17-2013, 01:06 AM   #392
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,356
Hi
Im at work right now and i dont have much time for the project. I will just let you know that im listening carefully to what you are doing and I appreciate your help. I can only state how difficult it is to in touch with the ktm people. Dealers in Denmark vary in quality and the lust for helping me outin this project. I can understand that the project isn't straight on and the challenge seems to turn them off. It's just like they are not skilled enough to handle "out of the box" problems.
I will try the ktm Europe at first and return.
Regards and thx in advance.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 01-18-2013, 01:47 AM   #393
mookymoo
Mookish Mook
Oddometer: 4,396
Originally Posted by LocuL View Post
Hi
Try pop Bikers Jersey an email (or phone) http://www.bikersjersey.com. They are quite helpful. (Or PM Pebble
If you can prise Owen away from the Dakar thread ... )
mookymoo is offline   Reply With Quote
Old 01-18-2013, 11:18 AM   #394
Katoom119
Katoom119's Avatar
Oddometer: 1,837
Mikael-
Just bought the RC8 service manual. Should be here within two days so soon as it does I'll pull the info about the immobilizer and the keys for you.
Old 01-23-2013, 08:14 AM   #395
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,356
Some hardcore reading from Svane:
Prøv lige og se om det her kan bruges til noget :)
Hi.
As most of you know, we’re having a bit of a struggle getting this projekt up and running (lately the small part about the engine and getting it to crank)…
Me and Mikael had to troubleshoot A LOT, but I’ll try to give you an update to the starter interlock case. From earlier I knew that the starter was fine, so I needed to go further backwards. The starter relay (K4 I believe) did however, not receive any current from relay K5 when the button was pressed. Dismantled the starter button in order to measure current on one of the wires/leads and at the same time, try to bypass the button. 12v, but nothing happened when I bypassed it. Back to the “wiring harness overview” and tracked down the relay K5 by the wire colours. Back with the voltmeter and 12v all the places where it should be. However, there was no connection to ground. Then I took another wire into the ground connection on the relay and directly to – on the battery. Then it worked!! But still no noise from the 1190 exhaust :/ Back to the “wiring harness overview” and located the wire in/out of the starter interlock. Measured resistance in the wire, just to be sure that it wasn’t broken- but it was fine.
Tried to explain it to Mikael, but he just looked at me and did basically the same as Homer Simpson does in the church in The movie ;) We agreed that there had to be a fault in the starter interlock, but unfortunately nothing happened when a new one arrived from one of you guys in Holland.
Thx a lot for the help you provide out there, keep it coming
KTM 530 EXC-R 08
Old 01-23-2013, 07:01 PM   #396
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,171
Mikael,
just wanted to check with you quickly if you bought the RC8 radiator from your dealer paying new prices (500+ USD) ?
I'm looking at buying one but cant find prices lower than that anywhere. Except e-bay of course.... but even those on e-bay are expensive at 400USD
cheers and looking forward to see/hear the beast run...
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 01-23-2013, 09:20 PM   #397
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,356
Bought it from ebay. Crazy expensive, be patient and you can find some cheaper ones.
KTM 530 EXC-R 08
Old 01-24-2013, 10:29 AM   #398
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,412
Originally Posted by Vicks View Post
Mikael,
Available new on Cheap Cycle Parts for $402...
http://www.cheapcycleparts.com/model...cooling-system
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 01-24-2013, 06:48 PM   #399
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Mikael,
Checking in just to say: Holly Shit...! this is a hell of a "projekt"! Congrats!
Can't wait to see/hear she running!
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 01-24-2013, 07:10 PM   #400
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
Have looked in to the tip over sensor if your using the standard ECU you will need to run the tip over sensor or bridge it out with a resistor ? This will stop the fuel pump and possibly
injector from working
Just a thought
Mudguts is online now   Reply With Quote
Old 01-24-2013, 07:53 PM   #401
Mudguts
Mudguts's Avatar
Oddometer: 2,128
If I read the tread you state a bazzas ECU , but is it a piggy back or replacement
Old 01-24-2013, 09:01 PM   #402
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,171
Thanks guys. PC, that cheapcycleparts link.... Wow !! used RC8 radiators on e-bay are like 400$ and this one's NEW !! thanks again for that.
I just went around looking for coolant capacity numbers and understand that the RC8 cooling system takes roughly 2.6ltr and my 990 takes 2.1ltrs right ?. With that, i don't feel like throwing away 400+ $ anymore at 500ml more or coolant , so i'll stick to a second cooling fan i guess, or when i find a cheap one, i'm thinking of using a second adv/duke radiator to cut up (two radiators) and join them to create a larger one with 20-30% more capacity. A used 990 rad should cost closer to 100-150$ and another 50$ for the work. Of course i'll have to relocate the oil tank, which will be part of a underseat oil tank + fairing mounted oil cooler project.
cheers
Old 01-24-2013, 09:30 PM   #403
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,356
Sounds like a great ay to increase cooling. Hovv you vvill merge the 2 parts i don´t knovv but if you go vvith ´something like the RC8 size you have to modify your tanks. And my experience is that it can´t be done vvith the original tanks.
Regards
ps: Safaritanks though is another story, can tell about that in a month...
KTM 530 EXC-R 08
Old 02-24-2013, 02:29 AM   #404
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,356
Not much from this side, yet. Next vveek i should have some more info.
Bike is at a nevv dealer to try connect ECU vvith immobilizer.
Before take off(in a van...again).
have fun
KTM 530 EXC-R 08
Old 02-24-2013, 08:23 AM   #405
elephant man
Oddometer: 60
now that is porn!
elephant man is offline   Reply With Quote
Times are GMT -7.   It's 04:01 PM.
