Old 03-03-2013, 05:03 AM   #421
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
As per standard slow progress. But hey ive bought a new(ish) notebook. Then im able to communicate with normal letters again. Heyhooo
Regarding the bike its still at the dealer. I have no idea if its good or bad, I assume its not good, but maybe its just KTM scandinavia or Austria whom is a bit slow in respoding. Thursday im back at normal workpace and will have a chat with him.
In the mean time the mailman has been here a couple of times.
Teaser.
Peg "enhancer"
Australia??
New HID system, i cant make it work with the original headlight assembly. Will be creative and make my own system.
Looks good but in my opinion i cant make it offroad worthy. To much vibration will kill the mounting points.
Heat protective selfadhesive stuff for the tanks.
Will be testing the 320mm mount. Im still hunting the single setup.
Trying a cheap 320mm disc for start and ill work from there.
Loads of 300mm discs not needed anymore...
A little decorative help in the garage.
Second fan mounting stuff and ITG air filter oil.
Got the added fan wired to the original cable. Thanks Svane.
Behold the beautyness....
Ive been trying to renovate the old standard 21/18 setup. The rear is good enough and ready to go tubeless, but the front is just super smashed up. Hmmm looking for options. Then again im not in a hurry as ive got plenty of wheels on hands. Still waiting for CJs 17/17 spacers and brake converter.
Thats it for now.
A little look into the future.
Beside bike need to get the ECU/immo solved, stuff needed to be done is:
1 - Safaritanks welding. Ive got a connection which is ready to jump the tanks when needed be.
2 - The exhaust needs to be done and my contact should be ready within a week to do this.
3 - My HID conversion should also be done, but i need to build the plate where the projectors should fit in. For that I need the bike...
4 - Lots of small details im not aware of will also be popping up, but that is small stuff compared to what ive seen so far.
Denmark is bathed in the most beautyful weather right now and im sure the last stuff will get sorted. I may even have a bike to ride within a month or so.
I would like to thank Pete640 for being insanely kind. Story is that i he contacted me and offered the reartanks in carbon/kevlar. Thank you Peter, not only have you been very kind and most of all patient, but you build some extremely beautyful stuff. Looking forward to test these tank.
Theantipaul has provided the HDB setup in the early start of the project, but the he also shipped free of charge a schotts submount he had laying around at no charge at all. Thank you.
Svane has been the greatest help of them all. Patiently he has been showing up everytime when needed.
I fucking love this place. Advrider really is a great place to wander.
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 03-03-2013, 04:48 PM   #422
Martynho
No more Chilegringo.
Oddometer: 408
Immobilizer woes
Locul,
Heres my own experience of dealing with an immobiliser that shat itself, FWIW not a full solution as your hardware is different but I hope it can help you
My 2010 990R immobilizer went, and no amount of reprogramming etc would sort it. KTM were as useful as a glass hammer, and suggested I change the lot....barrel, RFID antennae, ECU, keys, fuel flaps, under seat key barrell, I didnt even ask the price. Oh, plus it meant I would get a new immobiliser ready to go belly up in Bolivia. Bollox to that
We figured the pre 2008 models had no immobiliser. So we fitted a 2007 ECU we got cheap. Then loaded up 2007 map (this wont look for an immobiliser signal, not sure if there is a RC8 model with no immo that you can do the same trick with.
We got it running, had some issues with the TPS`s so we changed those also.
Now we just used tuneECU to copy and paste the 2010 map tables into the 2007 map file, reaload back up, and bingo!
Good luck mate!
Martynho is offline   Reply With Quote
Old 03-04-2013, 07:59 AM   #423
Bootsy
Bootsy's Avatar
Oddometer: 103
Locul....those rear tanks drive me crazy!!
www.sandandust.com
KTM
990 ADV R 09
KTM 950 SE 06
Bootsy is offline   Reply With Quote
Old 03-04-2013, 10:12 AM   #424
Fr8trn
Oddometer: 18
Subscribed. Keep up the good fight!
Fr8trn is offline   Reply With Quote
Old 03-10-2013, 12:30 PM   #425
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Well looks like the fight will be over. The dealer called me while I was at work. Told me that he had connected the ECU and the Immo. They paired up good and the bike didnt throw any faults anymore. GREAT, but he just couldnt get it to turn over. We debated what ever it could be. He said he absolute couldnt do anything anymore, because of the projects scale. He could tear it down and install a complete new harness and start from there, but it would be EXPENSIVE. I said drop it, ill pick it up when time is. Got the bike home and Svane and i looked it through. And correct it behaved very well though nothing happened when pushing the starter. It made the startup procedure and lights where good, but no turning? We were fooking lost, I tell you gents. This is the first time ive been a bit dissapointed because ive made all the steps correct and i have taken my time at doing the stuff well. Especially the electrical pieces, which i was scared working at because of my lack of knowledge.
Svane brought some beers and we discussed the further move. We agreed to strip the pieces one by one. We started at the starter interlock because it still threw the green "neutral" switch while we would engage the gear. hmmm... The neutral switch and sidestand switch was bought from new as i didnt want to mess with it, like these problems. But hey, we f...king are...
Just trying to clean up the bike and dismounted the Bazzaz unit and mounted the sidestand switch and gear selector in the original harness. Cleared some other stuff. We turned the key and the engine turned as an normal RC8R would......................................
HAHAAAHHAHA, we went insane for a couple of minutes. I dont recall drinking 2-3-4 beers that fast ever...unholy mother of all batcave shit. I just wished my dad could have seen this. AAAAAHhhhhhhhhhhhh what a feeling.
Im sitting here the night after and trying to look into what to do.
My initial thoughts are to dismount the bazzaz unit, but the unit lit up from the start and shouldnt be a problem. hmmm. Would call the danish Bazzaz supplier and try get a new wiring. Regarding the manual ive done it right. But hey Svane says im good at faults
Ill keep you posted when stuff gets hairy. Ive allready booked a holeshot contest with Svane on his KTM 505 against my Behemoth on a sandtrack.
Fuck me. I love this forum.
KTM 530 EXC-R 08
Old 03-10-2013, 12:38 PM   #426
ixab
just Aaron, really
ixab's Avatar
Oddometer: 376
IT'S ALIVE!!!!!!!!
-- sent via mobile
Youtube - Death, Death, Everywhere!
ixab is offline   Reply With Quote
Old 03-10-2013, 01:07 PM   #427
Dan950ser
NW Shredder
Oddometer: 521
Awesome work man can't wait to hear it run.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR Sale Pending, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 03-10-2013, 02:25 PM   #428
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 235
awesome
"saddle up or shut up"
KaTooM North
AJ990R is offline   Reply With Quote
Old 03-10-2013, 09:27 PM   #429
L.B.S.
Oddometer: 1,469
I'm so happy for you!
Just a random internet stranger who doesn't even own a KTM, but I've been following along with this thread from the start, and really enjoying your cool project.
Cheers
L.B.S. is offline   Reply With Quote
Old 03-10-2013, 11:36 PM   #430
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
Good stuff , now we want some video of the beast !!!
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 03-11-2013, 01:09 AM   #431
JensEskildsen
Oddometer: 1,077
Fedt!
2003 xt600e 155.000km
1986 xt350 100.000km (now sold)
JensEskildsen is offline   Reply With Quote
Old 03-11-2013, 03:18 AM   #432
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
AAh, so good! Cant wait for the rest of this project's photo's!
Why the bazzas btw? You can perfectly tune the stock ecu with tunecu. Or does it do autotune?
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 03-11-2013, 06:42 AM   #433
roookie1
Oddometer: 126
LIKE
Get those pipes made and fitted, then You can ride the fokker
roookie1 is offline   Reply With Quote
Old 03-11-2013, 08:19 AM   #434
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,311
Originally Posted by HappyGoLucky View Post
Fucking B.
Soon. We'll be back to Fucking A!
BOING!
Upgraded again to Fucking 'A' Man!
Be true....to yourself
HappyGoLucky is offline   Reply With Quote
Old 03-11-2013, 03:02 PM   #435
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Went to the shed and dismounted the Bazzaz unit complete.
Me and electrics...jeebus
Advanced mode: ON
Made my first attempt on some documentation of the work. Much more to come when i get comfortable with the video/audio editing.
Took some day of from work later in the week to catch up on the project. I need this to be good inside out. Ill start protect every cable as possible and adventurize/Starbuckize it. Booking some exhaust work for the week.
Out
KTM 530 EXC-R 08
Times are GMT -7.   It's 06:26 AM.
