Old 07-05-2010, 02:48 PM   #31
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
Originally Posted by tommytiger
so you will have 64 liters with you in your 300kg KTM
I should answer that question.
When i do the "long haul" riding. Highway stuff ala Autostrada Germany or likewise. I would like the option of +900km. When riding normal roads and standard gravelroads I will not feel the actually weight. I think i can adapt to weight. Its when it gets technical or twisty the fun starts. Beside that, when it tip over someday fully loaded, im in a great shape and would lift it without big efforts.
But yes i would like to have the options for 64l. Though im not all into how you can stretch the RC8R engine at normal daypace.
Benz:
I dont have interest in working with the 950/990 engine. As a matter of fact i have one sitting in a crate with a lost 6th gear. I could make that a crazyhorse.
If i can get a RC8R around 25.000 Dkr(3600euro) with low milage ithink that project in it own screams for the test. It would probably cost the same to make a 990 insane. And i will not tune the RC8R, reliability is the way. Not that i think the LC8 couldnt take the beating.
RC8R is my choise. If it fails im a way more poor man than before...though a bit more clever.
Regards
Mikael
Ps: As mentioned before it will take months before the first step. Patience.
Keep comming with "your thoughts". Bad and Good.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 07-05-2010, 06:34 PM   #32
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
I was eyeing a wrecked RC8 at the dealer and it looks very doable....
It will definately be a good learning curve trying to make everything fit together nicely and be reliable at the same time.
Kudos for trying and keep us posted man, good luck
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 07-06-2010, 02:44 AM   #33
mtb_man
Unfettered
Oddometer: 171
I love my RC8 and I love my Adventure. However, I doubt I would love a 1148cc Adventure as much.
Why? The engine/throttle response on the RC8 is all wrong for dirt and the adventure chassis shakes its head a bit with 95hp, I can't imagine >150hp pumping through it.
I look forward to reading the rest of this thread, but I'll stick to two separate bikes...
04 KTM 950 ADV
08 KTM RC8
Gone but not forgotten:
06 KTM Super Duke,
05 Kawasaki ZX636, 05 Suzuki DR650
When you are great, candor is often perceived as arrogance.
mtb_man is offline   Reply With Quote
Old 07-06-2010, 02:29 PM   #34
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
The day got even better.
From Robie Peterson:
locul,
The RC8 in the Super Enduro frame has worked well. A very easy, almost bolt in conversion. We are running just methanol currently and putting out as much horsepower as the 950's on 50% nitromethane!! It is less violent than a nitro burner but still puts out big numbers. We have had zero mechanical issues once we got it dialed in.
For your street/dual sport conversion you will only need to fabricate the front motor mount brackets. The rear pivot mount and lower rear motor mount are identical to the 950. We do not run a cooling system, obviously that will be something else you will have to tackle.
GOOD LUCK!!!!!!!!
Kerry
Mikael
KTM 530 EXC-R 08
Old 07-06-2010, 03:07 PM   #35
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
locul,
GOOD LUCK!!!!!!!!
Kerry
Mikael
it's like a blessing from up above...
can't wait to see this beastie
Old 07-07-2010, 07:59 AM   #36
yellowbronco
yellowbronco's Avatar
Oddometer: 212
SUBSCRIBED!!!
Going to watch this very closely because I too have been contemplating this swap. I'm just waiting for my 950 engine to grow old and die which, if all indications are correct, might just be another 50000 to 75000 miles!
I guess I've got some riding to do.
So many people have made mention of how the stock 950 engine is already a great dual sport engine and, if anything, all it needs is more low end.
My opinion...It's a 950cc V-twin! It's got PLENTY of low end! Frankly, the kind of power that the RC8 provides makes me drool. If you're riding technical singletrack, short shift and lug the RC8 in a range where it'll be docile. When you hit the pavement and it's time to disturb the peace, let her sing in the higher rpm's where the full 150 hp is available
Tom
08 KTM 320 SXF, '07 Beta Rev 3,
Frankenberg 501, '96 Husaberg FC600, '68 Yamaha DT1, '74 Bultaco Alpina 250, '84 Husqvarna WR400 - My Dad says I've never seen a motorcycle I didn't want to own...
yellowbronco is offline   Reply With Quote
Old 07-07-2010, 08:50 AM   #37
mousitsas
mousitsas's Avatar
Oddometer: 2,728
Mikael, do you plan to use the FI system of the RC8 or the carbs of your 950?
mousitsas is online now   Reply With Quote
Old 07-07-2010, 12:13 PM   #38
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
And again, easy advriders...
Yep I plan on using the engine as stock as possible.
Tehcnical singletrack will not be on the list when the RC8R is mounted.
Mikael
KTM 530 EXC-R 08
Old 07-08-2010, 03:40 AM   #39
mtb_man
Unfettered
Oddometer: 171
Mikael
Great plan. The RC8 doesn't like to lug, it's meant to be at wide open throttle all the time.
04 KTM 950 ADV
08 KTM RC8
06 KTM Super Duke,
Old 07-08-2010, 12:20 PM   #40
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
Mikael
dood you need to find yourself a wide open desert somewhere
Old 08-03-2010, 02:03 AM   #41
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
For the project i need some pictures. Just to estimate the widenes of the bike.
The need is: Front view with 45l tanks fittet VS a front view with the standard tanks. Well just put up a picture with the 45l if you find any.
Regards
Mikael
Ps: I should have a RC8R engine in the end of Sep(only2-3000km). Maybe start sep if lucky.
Progress is slow but steady.
KTM 530 EXC-R 08
Old 08-03-2010, 06:09 AM   #42
roookie1
Oddometer: 103
Regards
Mikael
Damn it Mikael, Ill come visit you when you get that engine ..
Maybe ill bring the "little one" and we can go for a ride..
/Paw
roookie1 is offline   Reply With Quote
Old 08-03-2010, 06:50 AM   #43
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
You are always welcome.
Actually think the lc8 should be great in the lc4.
Regards
Mikael
KTM 530 EXC-R 08
LocuL screwed with this post 08-03-2010 at 07:49 AM
Old 08-03-2010, 02:30 PM   #44
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,274
Eh?
Well i need some knowledge(again, again and again).
Ive got some thoughts about the higher gearing on the RC8R vs the old LC8. I have a scale were i can calculate external gearing(front and rear).
I know that the secondary gearing on RC8 is 17:37 and the LC8 is 17:42.
If im right I cant just compare those...ehh? I guess i have to know the primary gearing as well to make any reasoneble comparing?
RC8R: Primary - 40:76 Secondary - 17:37
LC8 : Primary - 67:35 Secondary - 17:42
(text is copypasted from KTMs manuals as written)
Could/would anyone help me in this?
Sry for shitty english(29yo and still learning)
Regards
Mikael
KTM 530 EXC-R 08
Old 08-03-2010, 02:37 PM   #45
Rabbitson
Rabbitson's Avatar
Oddometer: 562
Mikael,
Sounds like a pretty cool project, serious work involved but great to have something that you created yourself at the end of it.
Good Luck
David
7500 Great Motorcycle Roads Worldwide on your iPhone / iPad - Android Device and on the good old web
Rabbitson is offline   Reply With Quote
Times are GMT -7.   It's 11:48 PM.
