Old 05-04-2013, 12:28 PM   #526
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
According to both the RC8 service manual and the Adventure service manual both bikes require 48 - 54 psi (3.3 - 3.7 bar) for the fuel pumps.
There is a special KTM diagnostic tool to test this but it's computer controlled, password protected, blah blah blah. Sounds like you'd just have to take it into the KTM dealer. Looks like, based on the pictures, that they connect the tool to both the tank and an empty fuel jug. The computer tool actuates the fuel pump to pump fuel through the line from the tank into the jug while a pressure gauge is attached to visually show the pressure. All the computer does, likely, is turn the fuel pump on at a set point (like full throttle or 50% throttle).
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 05-04-2013, 11:24 PM   #527
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,289
Good info there KATOOM119
Maybe there is to much lifting for the pump. Mine is installed as per standard in the Safari and vvill have to go through 40cm hose up to the EFI bridge. hmm. If i recall right the RC8s have the tank on top and the pump right above or at niveau vvith the EFI bridge.
After searching around for some numbers to get the correct fuelpump i found this:
Hp * .38
That vvould be
176 * .38 = 67L per hour. That is a minimum an hour.
hmmmm
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 05-04-2013, 11:41 PM   #528
randel
randel's Avatar
Oddometer: 316
I don't think height is an issue. 3,3bar pressure means it can lift fuel ca 40 meters (according to fuel density). 40cm is only 1% of that.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 05-05-2013, 09:09 AM   #529
DirtJack
DirtJack's Avatar
Oddometer: 1,576
Hp * .38
That vvould be
hmmmm
What do the fuel filters look like? Having been through a similar problem with my 990, changing the filters brought it back to normal. Might be worth checking.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 05-05-2013, 09:59 AM   #530
Katoom119
Katoom119's Avatar
Oddometer: 1,836
I pulled the part numbers on the fiche and the pumps look different.
Old 05-05-2013, 10:35 AM   #531
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,289
hmmm i thought i looked that part up back then. Thanks for the vvork KATOOM119
Edit:
I´ll empty the left tank and pull out the fuel pump next vveek. If the problem only should be a clogged filter, i vvouldbe happy.
Let you knovv
KTM 530 EXC-R 08
LocuL screwed with this post 05-05-2013 at 11:50 AM
Old 05-05-2013, 12:29 PM   #532
Katoom119
Katoom119's Avatar
Oddometer: 1,836
The only other issue I can think of is if the hose running from the fuel pump to the engine stretches then you would be losing some of your pressure there.
Hope you figure it out. Bike looks killer!
Old 05-05-2013, 02:34 PM   #533
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Should it end up being a faulty pump I have a 990 pump laying around you can have for cheap, well whatever you feel like paying for it, all the money would go to my attempt to raise some money for charity.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 05-09-2013, 02:06 PM   #534
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,289
Well i got into the fuelpump today and tore it apart.
Filters looked like this when i opened them up. What are your thoughts?
Filters are on the way from Champ Gefr.
KTM 530 EXC-R 08
Old 05-09-2013, 03:55 PM   #535
DirtJack
DirtJack's Avatar
Oddometer: 1,576
The pump filter input doesn't look too bad, however, the paper filter on the pump output looks pretty gummed up. Similar to the one I took out of my 990 last week. It wouldn't rev above 4500 and acted like fuel starvation. Gefr's filters solved my problem. Bet it will solve yours.
2008 KTM 690 Enduro
DirtJack screwed with this post 05-09-2013 at 05:21 PM
Old 05-09-2013, 05:11 PM   #536
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,980
O.K. guys, here is my thoughts on the locul project.
Of course there is some envy on exploring new territory like locul did. Needs great courage, bravery and imagination I don't have. After having accomplished this titanic project, here comes a production bike in the "same" lines with the "housemade" project. So there is competition. Apart from the internal mental wondering, there is the moment of logical comparison of two products: the industrial and the household application of similar targets. The household product moves in more personal options like more suspension travel and ground clearance while the industrial should have a more thought through compact design. My question refers to the comparison of the final product of a cold blooded tester. What virtues each bike has and how do they unroll through everyday life with each of these two niche bikes...well obviously this cannot happen so I asked if locu has taken a test ride with the new breed.
Cheers.
Old 05-09-2013, 05:46 PM   #537
bigkuri
bigkuri's Avatar
Oddometer: 742
Kay?
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 05-09-2013, 05:49 PM   #538
bigkuri
bigkuri's Avatar
Oddometer: 742
Well new filters are never a bad thing. For what it is worth though those ones you peeled open are WAAAAY better than those I took from my 17k mile Adventure.... They actually look pretty good.
Old 05-09-2013, 08:13 PM   #539
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
put new filters in it, you will be glad you did...
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-09-2013, 10:50 PM   #540
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,980
The previous filter photo is deceiving...
The tea bag is a drainage suction filter. Dirt and grim is supposed to stay outside, so the inside we see is immaculate as it should be. On the contrary the paper pressure filter inside is displayed correctly and seems there is a cover with greyish color?
Times are GMT -7.   It's 08:03 PM.
