Old 08-03-2010, 01:46 PM   #46
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
thankyou...time will tell
And beside that i´m found this thread.
http://www.advrider.com/forums/showthread.php?t=606350
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 09-18-2010, 01:20 PM   #47
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
Well I came upon a new question in this labyrinth. When i get the engine would there be any problems pairing it with another ECU unit? I´m thinking it would be locked or anything?
regards
Mikael
KTM 530 EXC-R 08
Old 09-18-2010, 01:34 PM   #48
Qwik
Two Wheeled Addict
Oddometer: 5,231
You will need an RC8 ECU I would think. (Dont know for sure )
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 09-18-2010, 01:35 PM   #49
natedog39
New Sheriff in town
natedog39's Avatar
Oddometer: 5,408
Don't let the naysayers get you down,,,If you have the will and the way,,,,,go for it.
When I started my project in shiny things people were saying you should do this and you should do that and It's a shame your cutting this thing up,,,,,,now that it's going back together it a different tune.
This project sounds awesome I'm in.
People say I'm not a people person, I say how can I be a people person when I hate people. -Joe R
09 FE 570
11 990 ADV
natedog39 is offline   Reply With Quote
Old 09-18-2010, 07:09 PM   #50
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 645
Talking
F*** the bullshit. Just turbo or twin turbo your existing austrian vibrator and you'll get more explosive power than you'll know what do with. It's cheap when compaired to your build plans and if you keep the boost pressures low then your motor will last a bit longer.
Or if ur mr. Moneybags then import a Eva track 8 from the Netherlands and have a turbo diesel 3 cyl that gets insane has milage. Just be willing to shell out like 26k plus import tax etc.
-Chrome don't getcha home, but carbon fiber sure is fancy
My real name is Chris to stop the cornfusion at the RTE's
MrSandman818 is offline   Reply With Quote
Old 11-03-2010, 02:40 PM   #51
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
Hi again
Sorting the brakes and would like to upgrade.
Would the 950 adv 04 legs WP USD 4860 MXMA accept the "feets" from the superduke. I plan on mounting the radial brakes for more power for the added weight and specialness....
Regards
Mikael
ps: The SD legs are WP USD 4860 ROMA
KTM 530 EXC-R 08
Old 11-03-2010, 11:48 PM   #52
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
Dunno if the SD or Adv lower lug is removable(edit: doesn't show seperate part number in parts fiche). They are on the KTM450sm and xc suspension, which I have swapped before.
I am running the 950SM. It is modified: the radial 4piston caliper on one side with the extended mounting bolts and bushings for the SD, and a single 320mm rotor from the KTM450 SM(same size as SD) on an Adv hub and 19" rim. Still one finger stopping with the remote resevoir Mastercyl and lever I matched up, but easier to modulate than with the factory mastercyl pushing both big calipers and 310 rotors.
Caution:
I don't think you will be able to fit the radial mount calipers with 21" wheels. They are large and wide.
I had to grind the casting seam on the back of the caliper to clear the stainless Buchanan spokes with my 19" wheel.
You are talking about building a stable gravel blaster, however, and should consider the 19" front, like a flat tracker, an option for your design. The added road handling would be priceless with the right suspension.
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good!
justin@giantloopmoto.com
www.giantloopmoto.com
snowhawk jockey screwed with this post 11-03-2010 at 11:54 PM
snowhawk jockey is offline   Reply With Quote
Old 12-11-2010, 07:50 AM   #53
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
I will wake this one up. It will sadly not be the RC8 engine.
But an RC8R
Closed a deal the other day on this 09 RC8R 2300km engine. Crated and on my way. Pictures will follow.
Finally things are happening.
Mikael
KTM 530 EXC-R 08
Old 12-11-2010, 08:07 AM   #54
mookymoo
Mookish Mook
Oddometer: 4,286
Originally Posted by Locul@hotmail.com View Post
RC8R
mookymoo is offline   Reply With Quote
Old 12-11-2010, 08:23 AM   #55
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,514
tuned in
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 12-11-2010, 11:14 AM   #56
Balsta
Oddometer: 340
I will wake this one up. It will sadly not be the RC8 engine. But an RC8R
Mikael
Did you buy it on ebay germany? I saw the ad for the RC8 motor was gone. I also just bought a new engine there, 2009 SD 990-R though so I can't keep up with your acceleration.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 12-11-2010, 11:19 AM   #57
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
Pictures before shipping to my door.
This was the easy part. Now the real deal starts, though it should be a good learning curve. Timings are max 6 months from now. Plan is a virgin adventure to Northcape before i return to Afghanistan.
I hope you all will be helpfull through this process(as you always have been). I hope i can stay in this forum or the moderator should throw the thread elsewhere. I just thought this is closest to the 950´s.
Mikael
KTM 530 EXC-R 08
Old 12-11-2010, 11:26 AM   #58
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 870
Njaa...both jay and nay.
I discovered the add per ebay.de, but it didn´t sell. I contacted him on a english ktm forum(www.ktmforum.co.uk) and got it there. Its actually a long story ´cause we have been hagling with the price for almost 4months. Funny to look through the mailstory. I think some of the RC8R engines on ebay are pretty pricy. 5200euro is alot of money(half a bike).
oh...its not a RC8, but a RC8R.
KTM 530 EXC-R 08
Old 12-11-2010, 01:03 PM   #59
natedog39
New Sheriff in town
natedog39's Avatar
Oddometer: 5,408
I'm really looking forward to this,,,good luck man!
09 FE 570
11 990 ADV
Old 12-11-2010, 09:58 PM   #60
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
am in just for kicks
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Times are GMT -7.   It's 07:27 AM.
