Old 07-05-2013, 03:28 AM   #616
DirtyADV
DirtyADV's Avatar
Oddometer: 2,234
Originally Posted by mousitsas View Post
Me thinks it is 15Nm the upper and 25Nm the lowers.
Lower is usually a lower torque at least on upside down forks and here is what the manual says:
HH clamp bolts on top triple clamp M8 23 Nm
HH clamp bolts on bottom triple clamp M8 18 Nm
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 07-05-2013, 04:57 AM   #617
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
On my way home from school.
Wil do the clamp control today. Tear it down to move the afm unit.
Gregor; you dont have time to write here...get on with the house. I'm keeping an eye on your efforts at GJ. Looks stunning.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 07-05-2013, 05:10 AM   #618
DirtyADV
DirtyADV's Avatar
Oddometer: 2,234
See you have changed to a high fender, what fork guards are you using?
And can only say that the bike looks AWESOME!
/Johan
Old 07-05-2013, 10:55 AM   #619
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
That would be some old sx85 i had from original bike. Though raised a bit with some fugly iron. Ive since changed the fender with an sm thingy. Still debating if ill keep that
Sendt fra min GT-P5110 med Tapatalk2
KTM 530 EXC-R 08
Old 07-05-2013, 06:41 PM   #620
DirtJack
DirtJack's Avatar
Oddometer: 1,518
17 and 12 (upper - lower) are stamped on my 300 XC triple clamps. Same for my 690 triple clamps.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 07-06-2013, 12:21 AM   #621
mousitsas
mousitsas's Avatar
Oddometer: 2,749
/Johan
Thanks mate.
Old 07-07-2013, 01:35 AM   #622
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
update before vacation next friday.
Bike was torn apart and the hunt for the Afm unit from Bazzaz got me this.
Checked the airfilter how it dealt with this very "open" environment.
closer
Inside
I would say. Perfect.
And at last i dropped the bike off at the tuner.
Should be done Thursday. If im lucky i can skip the Master Sergent parade and head straight home to colect the bike.
That would be, perfect. I have not worked out the issue with the front. Things im preparing to do it:
1- skip the 320 and go for the 300mm standard disc
2- get the right tourqe values on the clamps
3- Mount up some k60 Heidenau 21/18
Have a nice summer OCs.
Regards
KTM 530 EXC-R 08
Old 07-07-2013, 01:39 PM   #623
Balsta
Oddometer: 400
Originally Posted by LocuL View Post
....Things im preparing to do it:
Is it perhaps the relocator bracket that makes the design too soft?
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta screwed with this post 07-12-2013 at 04:11 PM
Balsta is offline   Reply With Quote
Old 07-25-2013, 07:36 PM   #624
Balsta
Oddometer: 400
.......Beside this it has developed an suspension problem. My rear shock is absolute perfect and i love the amount of stroke but the front end is killing me. When i brake, that would be light, medium, heavy. The front reacts with some "shudder, studder". Defined as if the forks cant move freely. A bit like they stick in the stanctions. Im so tired of this. It happens for both the 21 and 17 setup. The brake setup is the 320mm with the standard 2 pot. I have checked that;
1- aligned the forks
2- tightened the wheel at the axel first then worked the forks a bit, tightened the clamps.
Ive been in contact with 2 other owners of the 320mm OTR setup. Where one of them is having the same problem.
This is NOT any kind of flaming of Lyndons ber suspension and i am in contact with him and having a great dialogue with him. Though if any would have some thoughts or the like that could/would help, chime in. Im keeping this suspension, just need to get past this sticktion problem. Seriously, I couldnt back down from this......
I rode about 500 kms today 1st time with the 320 mm disc setup with the oem 2 piston caliper, 17" rims oem fork&shock (in good condition). No fork issues whatsoever. Great brake by the way! It feels like I can do a stoppie @ 165 km/h (but Im too much covard trying). I have a much fatter Braking rotor than yours. Could (stiffer rotor) perhaps explain the difference?
Old 07-26-2013, 06:15 PM   #625
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Nice to hear it works. I can only think that its my lesser skills which have lead to this problem. Bike will be in my hands next week and will try address the problem.
KTM 530 EXC-R 08
Old 07-27-2013, 02:18 PM   #626
jimmibanke
jimmibanke's Avatar
Oddometer: 102
Wicked
Im using the oem 2 piston brake with a galfer wave 300 disc no probs what so ever! Ive tested them for 6000km now and it brakes fine.
jimmibanke is offline   Reply With Quote
Old 07-30-2013, 05:52 AM   #627
Balsta
Oddometer: 400
I guess you mean 320 mm disc? Otherwise, the pope is catholic.
Old 08-21-2013, 11:01 AM   #628
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Well a little update.
Bike has been run in and all is almost well. But(t) there is a bite. The engine isnt performing as wished. I know we all need 1000 bhp, but this is the bottom. At crank i assume the RC8R 09 put out 176bhp, that would be in the ballpark of 140-150 on the rear, am I wrong? The curve is very "stepped" and not linear? Would could any of you knowhow tuners give me your thoughts. Im well aware that my bike will not perform as an standard RC8R though this is far from.
Setup is:
RC8R 09
Straight 2-1, 2.5" akrapovic
Rottweiler airfilter(actually ITG, but same same)
Bazzaz tune box
Run in is made with SuperDuke rear slick tire.
Ive tried to think of what ive changed and cant remember anything significant. Apart from needing the "ram-air" system. Then again, if the Rottweiler system works well on RC8R then i assume its not there.
hmmm
anyone.
Edit:
I have forgotten that i do not have any ballancing pipe as the LC8 have. Would it be "un-ballanced".
On to a another thing. My Aqualine had made a leak at the fuelpump gasket. Pulled the tank and would take it off. The 3 first screws went good but then Murphys law struck me. The recessed part in the fuel tank started to turn around. Before i go apeshit and burn it all, i would like to know if any of you guy have thought of some external fuel pump for this(both 990-1190). Then i could seal up the hole and mount the fuel pump elsewhere.
Regarding my binding front end suspension from Lyndon im working out an solution. Annoying but we got a good conversation going.
Have fun.
KTM 530 EXC-R 08
Old 08-21-2013, 12:15 PM   #629
mousitsas
mousitsas's Avatar
Oddometer: 2,749
Is there any case the timing is gear-related and you are now running a restricted power ignition map?
Old 08-21-2013, 12:35 PM   #630
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Nope and no restriction in the powermap. Or do i misunderstand you?
KTM 530 EXC-R 08
Times are GMT -7.   It's 09:53 AM.
