11-07-2004, 08:41 PM
#16 |
Ken Dodd's dads dogs dead
Oddometer: 530
Sorry mate, the only photo I have is one I took while riding alongside of him, so it does not have much detail at all.
11-07-2004, 09:15 PM
#17 | |
Cheers Andrew
Said by a very brave soul " Lets Roll & Remember To Burn Rubber Not Your Soul " Words of wisdom Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes. Go soothingly on the grease mud, As there lurks the skid demon. Press the brake foot as you roll around the corners, And save the collapse and tie up. F650GS Dakar in Australia
11-07-2004, 09:19 PM
#18 | |
You know I did read your post a while ago & thats where this idea of mine came from, So I thought it was time to start doing something about it finally I will contact you off list & talk about your bike, Always good to hear from someone that already has what your thinging of doing. Cheers Andrew
11-07-2004, 09:20 PM
#19 | |
Cheers Andrew
11-08-2004, 06:39 AM
#20 |
Still a stupid tire guy
Oddometer: 7,279
Hey A K,
I have an old R90/6 that I'm planning to do the same thing with this winter. I haven't found out about where to get the longer swingarm and driveshaft yet, though. Mine's an old dual-shock unit, which will probably be best with my 275-lb. heft. I'm going to contact a place in the Midwest called Forking by Frank to see about getting longer fork tubes made to fit the stock lowers. I figure that'll be less expensive, and I can always upgrade later when money's not a big issue. A buddy of mine ahs a plams cutter and a couple of nice welders and has generously offered to help me brace the frame. I've been told that welding on the subframe and bracing it makes a big difference as well, and some guys have made up new subframes and welded them on in place of the stockers. My wife and I went to the International Motorcycle Show in San Francisco yesterday and I got a copy of Touratech's catalogue. It's beautifully done, and there are some good ideas in it as well. Good luck, and keep us posted as to your progress!!
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
11-08-2004, 06:41 AM
#21 |
Oddometer: 7,279
Sorry about the poor typing. It should be: "A buddy of mine has a plasma cutter and a couple of welders." Kinda tough to get my sausage fingers to type this early in the morning.
11-08-2004, 04:07 PM
#22 |
Planning that trip, again
I have investigated a suitable front end to put on a G/S. I was even very close to purchasing a WR400 walk off front end from Mr Motocross wreckers in Melbourne, bolt in with only minor rework to the head stem.
I have though, optioned for an USD WP set that was fitted to a G/S in Germany. As Greg suggested, I am intending to visit Paul Rooney and have him lengthen the swing arm and harden the frame up a bit. I have done a few mods on the engine and other than that it is fairly standard out of the factory. Greg, Did you have a look at the pics on my web site, a good pic of you and I talking at the fuel bowser at Innamincka.
Mick |
11-08-2004, 04:14 PM
#23 |
Yes,
There is a GS / BM day in Toowoomba on 21st November. There will be a few GSs on display as well a few road bikes. Stu will have his Special there, RTO will have the Enogerra Special there if Rooney gets his rear shocks done. I also have Paul Rooneys number at home. email me at tjaeger@optusnet.com.au and I will pass it on to you.
Mick |
11-08-2004, 04:49 PM
#24 |
Zen Adventurer
Oddometer: 5,244
I built up a G/S a year or so ago. Here are some pics of the frame modes:
Rear shock frame mount The upper tubes:
On a trip around the world.... details here: www.nohorizons.net |
11-09-2004, 08:43 AM
#25 |
+/- V TDSPP
Oddometer: 19,949
Some more notes--- My anecdotal sources say that swingarms do not come in different lenghts. the /6 swingarm is longer by 2 inches than the /5's. You can see where BMW welded more tube to the swingarm to make it longer. So making swingarm longer is no problem. I guess you just do the same on the left hand side, to hold the axle. To make a longer Driveshaft, the best idea I have heard is to cut it in the middle, and weld a longer piece into the middle. I've not seen it done, but it should be possible. It would have to be spin-balanced, so as not to eat itself apart.
The Exhaust pipes can be run Over the cylinders, and routed out the back, for clearance. Of course, these will haveto be custom made. Some have added Frame stiffeners from the swingarm pivot area diagonally up to the steering head area. Also, the R65's had a shorter cylinder head, and it was higher on the crankcase than the other models, so this might be the best starting engine, sothis contributes to high clearance. Front End-- Almost all Dirt bike front ends are longer in the steering head than the BMW's, for the obvious support it provides, and this is where the machining takes place, to make up this distance. My anecdotal source says this procedure is a matter of finding all the parts that fit. Not too harsh a task. Changing the angle of attack on the drive shaft is something I have not heard a good idea for, nor do I have one. Best estimates says 30-40K, before failure. So-- we got to talking, me and my mechanic. He's saying that on the ISDT BMW 1973 bike, which we are using as a sort of model, they got rid of the starter and charging system altogether. He said it would run 4-5 hours on a full battery. That means they removed the starter, shaved off the engine casing that holds it. Removed the Airbox and Diode board and leveled it off above the crankcase. then removed the alternator and front cover, and just made a cute little cover for the front of the crankshaft, and the ignition thing. the Engine is actually Quite compact. Makes it a small little package. For Starting: The only /6 five speed gearbox with a kickstart was made in '74. BMW only continued the kickstart on the four-speeds. Removal of all that stuff would save a lot of weight, and could move the whole engine UP in the frame a few inches. They also saved weight by shaving 10 pounds off the flywheel. With the removal of the airbox, the new custom pipes that go over the cylinders could join in that area. I think it means relocating the battery, somewhere. Dont know where. Didnt get that far. Some of this is a little farther that I would want to go, but It sounds like it would make a crazy bike. I will try to find out more about front end matching. I wonder if anyone has any specifics, if they've done it, yet. Having just paid off the last loan, I now need to buy a new enduro. After That, however, I will be accumulating parts to start building this beast.
What to do... What to do... |
11-09-2004, 08:50 AM
#26 |
+/- V TDSPP
Oddometer: 19,949
The Exhaust pipes can be run Over the cylinders, and routed out the back, for clearance. Of course, these will haveto be custom made. Some have added Frame stiffeners from the swingarm pivot area diagonally up to the steering head area. Around the exhaust pipes. Also, the R65's had a shorter cylinder head, and it was higher on the crankcase than the other models. This contributes to high clearance, so this might be the best starting engine. Front End-- Almost all Dirt bike front ends are longer in the steering head than the BMW's, for the obvious support it provides, and this is where the machining takes place, to make up this distance. My anecdotal source says this procedure is a matter of finding all the parts that fit. Not too harsh a task. Changing the angle of attack on the drive shaft is something I have not heard a good idea for, nor do I have one. Best estimates says 30-40K, before failure. So-- we got to talking, me and my mechanic. He's saying that on the ISDT BMW 1973 bike, which we are using as a sort of model, they got rid of the starter and charging system altogether. He said it would run 4-5 hours on a full battery. That means they removed the starter, shaved off the engine casing that holds it. Removed the Airbox and Diode board and leveled it off above the crankcase. then removed the alternator and front cover, and just made a cute little cover for the front of the crankshaft, and the ignition thing. the Engine is actually Quite compact. Makes it a small little package. For Starting: The only /6 five speed gearbox with a kickstart was made in '74. BMW only continued the kickstart on the four-speeds. Removal of all that stuff would save a lot of weight, and could move the whole engine UP in the frame a few inches. They also saved weight by shaving 10 pounds off the flywheel. With the removal of the airbox, the new custom pipes that go over the cylinders could join in that area. I think it means relocating the battery, somewhere. Dont know where. Didnt get that far. Some of this is a little farther that I would want to go, but It sounds like it would make a crazy bike. I will try to find out more about front end matching. I wonder if anyone has any specifics, if they've done it, yet. Having just paid off the last loan, I now need to buy a new enduro. After That, however, I will be accumulating parts to start building this beast.
11-09-2004, 11:44 AM
#27 | |
Tanami Tourer
Oddometer: 34
contemporary ISDT mods to a g/s
'Ride On I Say' |
11-10-2004, 01:21 AM
#28 | |
Also as Ozadvntr said he almost bough the front end off of a WR400 it really shouldnt be too hard to get that part sorted. Swing arms are the other thing I have been putting more thought into, It really would depend on how you wanted to ride this bike as to how long you would make the swing arm & I also thing that the twin shocks could be better too so the swing arm is kinda balanced rather than having all the weight pivoting on one side like the single shock ones. Does that make any sense to anyone. Cheers Andrew
11-10-2004, 03:23 PM
#29 | |
Tanami Tourer
Oddometer: 34
cheers, stu
'Ride On I Say' |
11-14-2004, 03:26 PM
#30 | |
Your right, I have sent off an email to Paul & will see where we go from there. Thanks for your info too
