01-11-2013, 06:20 PM
#1576 | |
Oddometer: 43
I dielectric greased every connection below tank and seat but not under the headlight. (oops) fuel pump electrics was replaced with Bean's I don't know how reliable they are and if I should suspect failure from them? I haven't read of failures. Ugh...I HATE electrical Grimlins because I feel like I'm blindfolded diagnosing those problems!. thanks for the input. |
01-11-2013, 11:56 PM
#1577 | |
Oddometer: 69
In the Winter i use Trelleborg studded tire With 7mm studs. This tires are only in 110 wide. standard MX tiresize. Works great, no problem.
Why I love Offroad bikes? Because 99,999% of the earth, are not pavement.
01-12-2013, 12:57 PM
#1578 |
Oddometer: 28
camel toe
I have fitted a Camel Toe sidestand plate but now the extra weight incurred on the end of the sidestand makes it bounce around at a unacceptable level,has anyone had similar problem and found a fix?
If I cant solve this I will remove it and count my losses and revert back to my tried and proven sidestand plate-a squashed coke can carried on me and placed under the sidestand as needed. On the subject of tyre width a mate has a 2010 990 Adventure [comes with a 150 tyre and has more weight and more power than a SE] he has done 2 trips into the outback using narrower than standard rear tyres and these are the results. Trip 1 Dunlop 606 130 x 90 rear on standard 4.25 inch rim he got 4000 klms. Trip 2 Dunlop 606 130 x 90 rear on replacement 2.5 inch rim he got 3000 klms. Both trips to same place,same tyre pressures[30 psi] and carrying same gear [weight] and no punctures. So a 130 rear will even fit on a wide 4.25 rim let alone the 2.5 rim on a SE and the narrower the rim the more the tyre wears,this is why I have a 3.5 excel which will be fitted on the rear of my SE in the next 3 weeks. I am not out to start a tyre thread just answering a question with an example as to weather a 130 can be used on a 2.5 inch rim to keep the cost down. |
01-13-2013, 01:06 AM
#1579 |
Oddometer: 277
I welded 3mm steel plate onto sidestand to increase footpint. Costed maybe 25 including sandblasting and powdercoating sidestand again. No problems since with soft terrain nor sidestand springs.
01-13-2013, 10:02 AM
#1580 |
Oddometer: 118
ok thanks guys for the answers (tires size)
KTM SE.R 2008 |
01-13-2013, 10:28 AM
#1581 |
Oddometer: 43
For you that have had contamination of coolant in oil. .. how "wavy" do you expect the oil filter to be vs just swelling from oil?
01-13-2013, 12:43 PM
#1582 |
Don't mean sheeit. .
Oddometer: 2,549
That's way too wavy for a normal oil filter. You've got some water/coolant in there. There's some possibility the moisture is coming from condensation, since it's winter especially, but my guess is the waterpump.
Zak ktm old bmw others |
01-13-2013, 02:32 PM
#1583 | |
Oddometer: 43
Edit: new seal on the way and Impeller in case I break mine removing it. GoinRidin screwed with this post 01-13-2013 at 03:25 PM |
01-13-2013, 09:52 PM
#1584 | |
Oddometer: 2,549
01-14-2013, 05:12 AM
#1585 |
Oddometer: 27
And don't forget to ride them...
Mine haven't been ridden for a month or two.....
MichaelmyLondon & Somerset 10 990 ADV R,08 SE, 06 HP2, 12 Freeride +67 Honda Monkey (since new!) Supporting Big Bike Rally Challenge at www.rallymoto.co.uk & Long Distance trials www.themotorcyclingclub.org.uk & http://www.eventdirectory.org.uk/ |
01-21-2013, 06:28 AM
#1586 | |
Oddometer: 43
BUT my main question. I was PLANNING on laying bike on side (have fresh oil and filter) and remove cover of water pump and try to change JUST seal since bearings and shaft are ~1200miles old. and assume I nicked the seal on install. Question is here; Has Anyone removed the seal alone from the outside without removing the pump and using the shaft and c-clip to press it out as I did when replacing EVERYTHING? I hope this is a simple $8 repair only. I don't want more down time. But I'll fix it right if necessary. Thanks JT |
01-22-2013, 11:31 AM
#1587 | |
Keyboard Adventurer
-jw
My Reports AMA Member ---------------------------------------------------------- AMCA Member Minnesota North Shore Shindig -----------------Minnesota North Shore Adventure Riders |
01-27-2013, 06:50 AM
#1588 |
RibRoy
Oddometer: 19
Front fender
Hi, Anyone that can help in identifying this fender?
http://www.ktmtwins.com/brembo-march...conversion-kit Thanks. |
01-27-2013, 07:39 AM
#1589 | |
Oddometer: 5,036
It can be done, I saw a photo of someone putting two self tappers in and using the heads to pull it out, dont go to deep as you will damage the bearing seal. Id be tempted to make 4 small holes with an owl and thread some wire though and out, so two loops and pull it out. |
01-27-2013, 09:27 AM
#1590 | |
Oddometer: 70
http://www.google.co.uk/search?q=ktm...w=1024&bih=673
950superenduro.com For those who own the best bike! |
