Old 04-14-2013, 10:54 AM   #1651
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,925
Rectifier
I think my R/R is gone. Voltage readings at the battery are basically unchanged when running.
Searches here indicate two choices....
Ricksmotorsportelectrics.com
Rodstercycle.com
Both are mosfet versions and not OEM, Any other options out there?
What's the preferred relocation spot?
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 04-14-2013, 11:39 AM   #1652
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
Rodstercycle.com
just gone through the same problem
i was told by 2 well known members here to use this as it is the best.
i just got the The Super Mosfet Kit FH020AA (plug & play) http://www.roadstercycle.com/
from LA to OZ in 7 working days will have it at my door today.
Some info
http://www.advrider.com/forums/showt...7#post21097267
http://www.advrider.com/forums/showt...757934&page=27
VR relocation
left side of airbox:
http://www.advrider.com/forums/showp...postcount=4577
frame on left side: best i seen so far (watch his post for this bracket )
http://advrider.com/forums/showpost....postcount=4686
http://www.advrider.com/forums/showp...postcount=4631
MY BIKE:07 KTM 950 SER With 15K when it fryed
MOTOBATT Battery
OEM
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 04-16-2013 at 01:17 PM
veetwo _tls is offline   Reply With Quote
Old 04-15-2013, 07:39 AM   #1653
JustinT
I will ride my whole life
JustinT's Avatar
Oddometer: 960
Some info
VR relocation
MOTOBATT Battery
OEM
Did the oem VR go out while it was relocated?
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 04-15-2013, 10:50 AM   #1654
veetwo _tls
RENOVATIO:
Oddometer: 1,850
edit
yes it did fry even after relocated for 12 mths approx happened at 15K exactly with summer temps reaching at 43C / 109.4F. we have just gone into winter.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 04-16-2013 at 01:21 PM
Old 04-16-2013, 11:01 AM   #1655
Riddler990
I Suck, You Rule.
Riddler990's Avatar
Oddometer: 537
yes it did fry even after relocated for 12 mths approx.
Just a thought here, Within a group of 5 SE's I know of that had the VR go out, mine included, were running Shoria batteries. In doing research as to what could be happening, I have come to the conclusion (opinion) that the wattage that our bikes put out, and how "clean" or "dirty" the power going to the battery is may actually be part of the problem. It seems that the non lead acid batteries, i.e. LiPo, AGM, have an inability to efficiently absorb and smooth out the power being sent to them from the VR. This power then gets sent back to the system, and the VR, which in turn cooks it. I would suggest going back to a lead acid battery and a mosfet VR and see how that lasts. I have also gone through 3 GM high output 1 wire alternators on my musclecar, which has always had an Optima red top "AGM" battery in it. The reg in the alternator would keep burning out. 4th new alternator and a new lead acid battery and we'll see how she lasts.
Riddler990 is offline   Reply With Quote
Old 04-16-2013, 11:26 AM   #1656
triplenickel
triplenickel's Avatar
Oddometer: 2,430
FWIW 70K stock VR in stock location with a stock battery. I do have a spare at home though after reading these kind of posts just in case, it's also hardly hot up here compared to where some of you Yanks live.
07 SE
PG007
Old 04-16-2013, 02:31 PM   #1657
wpbarlow
Oddometer: 11,267
Fwiw, my SE VR went out at about 24k miles iirc in August 2011 and it had the original stock battery. I installed a Shorai with a new VR and still ok with 32k mikes. VR is still in the stock location. Also fwiw, I have a small TT heat shield over the exhaust header.
wpbarlow is offline   Reply With Quote
Old 04-16-2013, 06:36 PM   #1658
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,746
I am in about the same boat. My stock VR did not fail with about 22k on it. I did, however, go to a LiPo battery about 8k ago. I replaced it preventatively with the MOSFET but left it in the stock location and I also have the TT heat shield.
traveltoad is offline   Reply With Quote
Old 04-17-2013, 10:36 AM   #1659
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 992
Red neck Kiwi
[/URL][/QUOTE]
Didn't know they had red necks down there. LOL good temp fix
dogsslober is offline   Reply With Quote
Old 04-18-2013, 07:04 AM   #1660
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
Yeah man you ain't having the title all to yourselves.
...see if it works now
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 04-18-2013, 08:23 AM   #1661
kanur
cu new er
kanur's Avatar
Oddometer: 753
Originally Posted by JRod152 View Post
***Caution***
It seems my "new-style" brace needs some slight modification. It's rubbing on each side of the radiator, both on the seam and the corner. Sorry for the poor phone pics, but you get the idea. You can see bare aluminum if you look closely. I was actually thinking about calling up to request the old style brace for this reason.
Anyone else with similar experience?
I had to do a lot of tweeking to my new style brace to get it to clear the radiator to my liking.
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 04-23-2013, 12:29 AM   #1662
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,590
Rear Brake Rotor
Will a 950 Adventure Rear Brake Rotor fit a 950Super Enduro ?
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 04-23-2013, 03:26 AM   #1663
Modder
Modder's Avatar
Oddometer: 17
Rear brake rotor
Should be no problem.
I use a complete set of 950 Adv wheels with discs and sprocket.
(removed one front disc)
I shrink bikes
Modder is online now   Reply With Quote
Old 04-24-2013, 12:39 AM   #1664
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,590
Confirmed. Bought a new sold Metalgear rear disc rotor for a 950ADV & it fits like a glove, even used original bolts.
Much cheaper than floating disc @ $129 & will last longer.
Hodgo Spot
Old 04-29-2013, 12:11 AM   #1665
Monkey Butt
Rusty
Oddometer: 80
Hi Guys,
I have recently purchased a SE and are enquiring on the correct way to fit a under bar Scotts Damper to the SE that has a 30ltr Safari fitted. In my opinion it appears that it does not fit, I also have the BRP triple clamps. The frame bracket that attaches the Damper to the frame is where the problem lies. It appears there is not enough clearance between the base plate and the Safari tank.
If you have this set up can you please explain on how to fit and even better if you could send some close up photos of your set up.
Cheers Russ.
Monkey Butt is offline   Reply With Quote
Times are GMT -7.   It's 11:14 PM.
