Old 04-29-2013, 07:14 AM   #1666
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
Originally Posted by Monkey Butt View Post
Hi Guys,
I have recently purchased a SE and are enquiring on the correct way to fit a under bar Scotts Damper to the SE that has a 30ltr Safari fitted. In my opinion it appears that it does not fit, I also have the BRP triple clamps. The frame bracket that attaches the Damper to the frame is where the problem lies. It appears there is not enough clearance between the base plate and the Safari tank.
If you have this set up can you please explain on how to fit and even better if you could send some close up photos of your set up.
Cheers Russ.
Heya Russ
You will have to take a small skim off the top of the front bolt bracket as it is too tight as you have discovered.
Will take a couple of pics this morning for you.
Cheers Andi
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 04-29-2013, 10:26 AM   #1667
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,061
Heya Russ
Sorry for the quality but Ellen took the good camera to school and if these do not show you what you need I will ping some more of tomorrow morning.
Posted a few pics with slightly different angles, sorry bout bein grubby haven't done the housework for a few weeks
Any queries fire away.
Old 04-29-2013, 02:17 PM   #1668
wilso122
Oddometer: 184
cpr rottweiler intake
Interested in hearing 950SE specific good bad n ugly on fitting the CPR Rottweiler air intake on the 950SE. Read quite a bit already but its all mixed in with ADV's, so those who have fitted to the mighty SE can you share your thoughts?
Really interested in whats it like on wet muddy trails as well as desert....
Seems easy enough to fit but have most of you re-jetted?
Have a full 2-1 exhaust system and the blow is fine just need to work through the suck......
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 04-30-2013, 04:47 AM   #1669
Monkey Butt
Rusty
Oddometer: 80
Hi Andi,
Thanks for all your trouble with the photos, I really appreciate it. How did you cut into the steel etc and is it possible to point out which area you shaved off exactly. I am a bit of a dumbass in this area.
Thanks again mate.
Cheers Russ.
Monkey Butt is offline   Reply With Quote
Old 04-30-2013, 08:00 AM   #1670
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,061
Hi Andi,
Thanks again mate.
Cheers Russ.
Heya Russ
This was all done when we got the bike so I cab't honestly tell you.
It would just be a matter of taking your time, marking it out and doing it quietly and properly.
We will have the tank off in a week and a half doing air filter etc so can put so "apart" photos up if this helps.
Old 04-30-2013, 10:14 AM   #1671
bigkuri
bigkuri's Avatar
Oddometer: 842
Any pictures or description of where you run your fuel filter, and how routed to fit with the stock fuel pump and a 30l Safari tank?
I've only seen one post describing a big loop from after the T-junction, out to around the rear cylinder, the filter zip tied to the frame, and then back up to the quick disconnect. Sorry no photo though, hence my ask! Also, that method sounds a bit clunky... :)
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Old 04-30-2013, 02:59 PM   #1672
Monkey Butt
Rusty
Oddometer: 80
No worries, thanks again Andy.
Cheers Russ.
Old 04-30-2013, 03:45 PM   #1673
KASUYAHO
Road Hog
Oddometer: 3,745
A few questions
Hi Guys,
Is there somewhere I can download the proper work shop
manual for the SE ?
Also where is the best place to buy EOM and aftermarket parts online for the SE ?
Cheers
Glenn
KASUYAHO is offline   Reply With Quote
Old 05-01-2013, 04:29 AM   #1674
wilso122
Oddometer: 184
Originally Posted by KASUYAHO View Post
Hi Guys,
manual for the SE ?
Cheers
Glenn
Glenn, you have PM, respond to that and your wish will be granted
Online parts, not sure about OZ but KTMtwins.com in the states ship all over and I know a dealer in the UK that could probably ship you stuff if you get stuck with anything.
HTH Wilso
Old 05-01-2013, 02:10 PM   #1675
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 403
can anyone tell me where the fuel pump relay is located on a 950 se.i was leaving work and she would not start fuel pump dead.swapped the fuel pump with a spare i keep around(facet) and still no go,i figure its the relay or i have to chase down a pinched wire. i wired the pump direct it fires up so its a power supply issue.
mud... its the new chrome
ststrider is offline   Reply With Quote
Old 05-01-2013, 02:13 PM   #1676
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,667
You did check the fuses already, Right?
BENRON is online now   Reply With Quote
Old 05-01-2013, 02:38 PM   #1677
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 403
first thing i checked but hey that would be easy.electrical gremlins are supposed to be slippery buggers.
Old 05-01-2013, 02:43 PM   #1678
sito
Where the Hell am I?
sito's Avatar
Oddometer: 1,555
Did you turn the bike switch to run not just the key? Don't ask me how I know.
I'm a GPS Wizard follow me?
sito is offline   Reply With Quote
Old 05-01-2013, 03:16 PM   #1679
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 403
not sure what you mean,i turn the ignition on everything lights up starter turns but once it ran out of fuel(it started and idled with the fuel in the bowls) it was done.you thinking ignition switch?
Old 05-01-2013, 03:32 PM   #1680
max2
max2's Avatar
Oddometer: 219
check voltage with a meter at fuel pump while cranking the starter
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Times are GMT -7.   It's 01:08 PM.
