Old 05-01-2013, 03:13 PM   #1726
BENRON
I'm Mr. Crabtree
BENRON's Avatar
Oddometer: 3,593
You did check the fuses already, Right?
BENRON is offline   Reply With Quote
Old 05-01-2013, 03:38 PM   #1727
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
first thing i checked but hey that would be easy.electrical gremlins are supposed to be slippery buggers.
mud... its the new chrome
ststrider is offline   Reply With Quote
Old 05-01-2013, 03:43 PM   #1728
sito
Where the Hell am I?
sito's Avatar
Oddometer: 1,547
Did you turn the bike switch to run not just the key? Don't ask me how I know.
I'm a GPS Wizard follow me?
sito is offline   Reply With Quote
Old 05-01-2013, 04:16 PM   #1729
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
not sure what you mean,i turn the ignition on everything lights up starter turns but once it ran out of fuel(it started and idled with the fuel in the bowls) it was done.you thinking ignition switch?
Old 05-01-2013, 04:32 PM   #1730
max2
max2's Avatar
Oddometer: 217
check voltage with a meter at fuel pump while cranking the starter
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 05-01-2013, 04:33 PM   #1731
wilso122
Oddometer: 183
Some se's have adventure type controls with an agnition kill on off switch, others have push kill like exc's.
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 05-01-2013, 04:42 PM   #1732
max2
max2's Avatar
Oddometer: 217
My manual shows its the middle relay under the seat
Old 05-01-2013, 04:56 PM   #1733
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
middle? there are 4 relays under my seat but i have no idea which one might be the fuel pump.
Old 05-01-2013, 04:57 PM   #1734
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
no juice when cranking.
Old 05-01-2013, 04:58 PM   #1735
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
the kill switch is in the run position.
Old 05-01-2013, 05:19 PM   #1736
CA Stu
CA Stu's Avatar
Oddometer: 47,069
You could easily swap them around...
Here's a link to another SE pump problem (solved) http://www.advrider.com/forums/showthread.php?t=852211
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 05-02-2013, 04:58 PM   #1737
KASUYAHO
Road Hog
Oddometer: 3,573
Glenn, you have PM, respond to that and your wish will be granted
Online parts, not sure about OZ but KTMtwins.com in the states ship all over and I know a dealer in the UK that could probably ship you stuff if you get stuck with anything.
HTH Wilso
Thanks for that Wilso
KASUYAHO is offline   Reply With Quote
Old 05-03-2013, 12:03 PM   #1738
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
for future reference the fuel pump relay is the front one in a row of four under the seat.once i got some help i found i was getting 5-6 volts to the fuel pump during start up cycle and then 5-8 volts while running.no pinches in the wiring so i hope its just a relay but i will have to wait till next week to try one.till then i made up a plug that uses the power cord from my aerostich warmbib and an sae flat connecter which gives me direct power to the fuel pump.
Old 05-06-2013, 12:26 PM   #1739
SpeedyR
SE in the SE
Oddometer: 850
not a question but a point of reference for the SE riders- I asked a few weeks ago about rear brake pads for the SE. Turns out they are the same as the front pads on my 07 450. I ordered a new set, but had a spare set for the 450 and they fit perfect. So if you need 'rear' pads for your 450, check to see if the dealer has any fronts for a 450 in stock.
SpeedyR is offline   Reply With Quote
Old 05-06-2013, 12:50 PM   #1740
wilso122
Oddometer: 183
Aren't they different disc sizes? 260 and 240? Seems odd they fit..
Times are GMT -7.   It's 11:59 PM.
