Old 05-29-2013, 07:04 AM   #1741
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,962
Does anyone know where the electrical grounds are located on the 950 SE frame ?
Bruno T . is offline   Reply With Quote
Old 05-29-2013, 04:46 PM   #1742
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,504
Bleeding the rear brake
I had to pull the master and slave cylinders off when I took off my swingarm. As I was putting things back together, I decided to bleed the rear brake.
I like to attach a rubber hose to the slave nipple, attached to a syringe full of brake fluid, open the master cylinder, remove the rubber boot, then push fluid from the slave to the master until the fluid is free of bubbles and clear.
After I flushed the system with fresh DOT4, I put it all together, and now I have no rear brakes whatsoever. I repeated the steps above, and still no activity at the pistons.
Am I doing something wrong here? Is there something magical about these brakes that does not allow you to bleed from slave to master?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 05-29-2013, 05:01 PM   #1743
HickOnACrick
Groovinator
Oddometer: 2,504
Never mind. I put a mity vac on the slave nipple, and sucked 4 or 5 full master cylinder's worth of fluid through, and it works fine. I guess the vacuum is needed on the rear brake.
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 05-29-2013, 05:19 PM   #1744
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 259
If my bike dies in gear I can't restart it by pulling in the clutch I have to put it in neutral first any ideas?
SE Steve is offline   Reply With Quote
Old 05-29-2013, 09:57 PM   #1745
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,739
Clutch switch
v8toilet is offline   Reply With Quote
Old 05-30-2013, 05:06 AM   #1746
markie_wales
Oddometer: 940
Originally Posted by v8toilet View Post
Clutch switch
Or after market lever without the "pin" that activates the clutch switch. Happened to a mate with an SE. We jumped the switch and it worked fine, so initially thought it was the switch but some digging showed a non original lever.
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales is offline   Reply With Quote
Old 06-13-2013, 11:24 PM   #1747
D K
Oddometer: 482
150 rear on the stock rim?
Has anybody tried a 150 rear?
Im gettng a set of road tires for my bike and the only size they have is a 150..
Is the rim wide enough?
David
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
D K is offline   Reply With Quote
Old 06-14-2013, 04:17 AM   #1748
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,971
150 rear is intended for a 4" wide rim.
They will fit the 2.5" rim but it pulls the sidewalls way in, which rounds the treads & don't handle properly.
Buy you a 4" ADVenture rim & lace it up
To your hub like I did.
Note: 2.5" rear rim handles MUCH better off-road.
Brown Dog screwed with this post 06-14-2013 at 04:28 AM
Brown Dog is offline   Reply With Quote
Old 06-14-2013, 07:56 AM   #1749
D K
Oddometer: 482
I dont have an option to do that.
I am mexico bound on a very long asphalt tripand want to know if a 150 is ok on a STOCK rim?
D
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
Old 06-14-2013, 08:04 AM   #1750
wilso122
Oddometer: 184
It will work it is just not ideal and will wear a lot quicker also handling not so good, that's why the suggestion of a re-lace.
So if you have no choice, fit it
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 06-14-2013, 12:56 PM   #1751
Doapie
Oddometer: 5
Slow speed stutter???
Hi guys. I have a 2006 SE and lately have this problem?? Second gear from 35km\hr to 50km\hr it stutters. Help??
Doapie is offline   Reply With Quote
Old 06-14-2013, 01:59 PM   #1752
Brown Dog
Brown Dog's Avatar
Oddometer: 1,971
Welcome aboard
Too little or too much fuel pressure
Stock fuel pump ?
Does it rev up fine n neutral ?
Did it do this after a tip over ?
Old 06-16-2013, 04:37 PM   #1753
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 259
Clutch switch
Exactly right shorter lever doesn't have the protrusion for the clutch switch
Old 06-17-2013, 12:40 AM   #1754
Doapie
Oddometer: 5
Slow speed stutter
Welcome aboard
Stock fuel pump ?
Thanks for reply.
Facet fuel pump? No tip over. What else?
Old 06-17-2013, 03:51 PM   #1755
mathews42
mathews42's Avatar
Oddometer: 338
Where does everyone buy oil filters and oil drain plug washers/gaskets? Ktm 950 SE.
I haven't found a site that carries both.
Beads in the headlight a Flying Aga Tale by Isabel Dyson I met these two travelers on their Journey from the UK to Alaska and through South America on a 1979 BMW R100RS. Their book is now on Amazon for Kindle.
mathews42 is online now   Reply With Quote
Times are GMT -7.   It's 07:08 PM.
