Old 10-04-2010, 06:42 PM   #181
mookymoo
Mookish Mook
Oddometer: 4,392
Originally Posted by David P.
And remember that the centre stand is very heavy! I wouldn't want one on my bike!
Yeah, Id prefer mine didnt have one.
Its a right b*&^d changing a tyre without one though... (unless youre lucky enough to find something to prop the bike up on... and it doesnt fall off)
mookymoo is offline   Reply With Quote
Old 10-04-2010, 09:58 PM   #182
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,870
this will save you 12lbs....works like a charm....drilled a small hole in the front of my skid plate for a front tire lift....
http://www.advrider.com/forums/showt...ght=jack+stand
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-05-2010, 05:08 PM   #183
mookymoo
Mookish Mook
Oddometer: 4,392
Now thats interesting. Thanks.
(is it really 12lb? 6kg? I didnt think the CS was that heavy...)
Old 10-05-2010, 07:46 PM   #184
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,870
no it is eight pounds....but I like to exaggerate...I have done it a million times....
Old 10-06-2010, 01:31 AM   #185
mousitsas
mousitsas's Avatar
Oddometer: 2,750
You never feel the weight of the centerstand, it is so lowly placed its like its not there.
mousitsas screwed with this post 10-06-2010 at 04:03 AM
Old 10-06-2010, 01:48 AM   #186
markie_wales
Oddometer: 933
The truth of the matter is that, for me, 8lbs one way or the other will make no difference to my ability to ride this beast! And on a personal note, I could probably do with losing 8lbs off my stomach anyway
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
- Only bikers understand why dogs like to stick their heads out of car windows.
markie_wales is offline   Reply With Quote
Old 10-06-2010, 04:06 AM   #187
mousitsas
mousitsas's Avatar
Oddometer: 2,750
somebody, maybe in this thread said that SAS removal creates a hesitation off the idle. Well, I hadn't have it removed, but I had blocked the SAS tube exiting the airbox. I removed the blockage and I can confirm that the bikes is smoother off the idle. From now on, I am keeping SAS alive.
ps I have akras with inserts, 3rd clip and 2turns out on the fuel screws.
Old 10-06-2010, 11:11 AM   #188
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,942
Thumb
My SAS is removed, Akra's, stock jets. Needle Clip in 3rd from top & it RUNS GREAT
& Much Much Better at every RPM
Brown Dog is offline   Reply With Quote
Old 10-06-2010, 12:03 PM   #189
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,870
My SE....runs like a top...right until you ride it in the whoops....then it loads up and sputters...
anyone ever get this issue resolved...
Old 10-06-2010, 12:09 PM   #190
David P.
David P.'s Avatar
Oddometer: 356
Easy peasy, either a fuel pressure regulator or a fuel pump that doesn't drain the engine as soon as it gets the chance(we've used the Mikuni DF53-136).
KTM 525 - 2007, Raid Designs MRS Ed.
www.RaidDesigns.com
David P. is offline   Reply With Quote
Old 10-06-2010, 01:09 PM   #191
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 19,632
Have you checked the float levels? I had that problem on my Adventure a few years ago and found that the rear carb float level was set a bit too low. Also, which fuel pump are you using?
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 10-06-2010, 01:27 PM   #192
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,707
+1
Mixing gas and haulin' ass.
Matchmaker of Homes and People
traveltoad is offline   Reply With Quote
Old 10-06-2010, 01:30 PM   #193
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,309
I have the same set up us you ,but im running a diferent fuel pump df-52
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Old 10-06-2010, 01:44 PM   #194
unaweep
unaweep's Avatar
Oddometer: 19,632
Javier- it was great to meet you and ride with you (even though it was only for a few seconds ) KotW was a blast. Thanks for all your hospitality
NICO
Old 10-06-2010, 01:52 PM   #195
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 377
Fuel pressure builds up too high on the SE, if you're running in low gears (1st, 2nd) and not being able to gas it a lot for a while.
Fuel pressure regulator is the final answer. You'll want to aim at 0.08bar pressure in the fuel line with the regulator in place. Either that, or gas it more on the low gears ;)
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Times are GMT -7.   It's 12:44 AM.
