Old 10-06-2010, 12:58 PM   #196
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,964
Originally Posted by FinnDuro
Fuel pressure builds up too high on the SE ...
Fuel pressure regulator is the final answer...
OR, use the #40177 1-2.0 psi / #40252 1-1.5 psi pump
The 40171 is TOO much pressure at 2.0 - 3.5 psi
Brown Dog is offline   Reply With Quote
Old 10-07-2010, 08:30 AM   #197
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Interesting.....
So why are most folks running the 40171?
ktm950se
ktm950se is offline   Reply With Quote
Old 10-07-2010, 09:30 AM   #198
mousitsas
mousitsas's Avatar
Oddometer: 2,975
I would really appreciate if a knowledgeable gentleman explains how pump pressure affects running!
Old 10-07-2010, 12:13 PM   #199
Brown Dog
Brown Dog's Avatar
Oddometer: 1,964
im no moto head, so help me out guys
Too much Fuel Pressure puts TOO MUCH Fuel into the fuel bowls causing the
bike to Flood and / or run rich.
The needle and seats on the bowl floats, will NOT shut the fuel OFF when the pressure is too high.
I think this is right . . . . . Guys chime in.
I dont know who came up with the #40171 for this application
I THINK gravity flow is fine, cause many people have stated 'the bike ran fine with a FULL tank of fuel
when the pump goes out'
I dont mean to sound like a know it all. Im simply expressing my thoughts, which are not always correct.
Brown Dog screwed with this post 10-07-2010 at 12:18 PM
Old 10-07-2010, 02:03 PM   #200
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,667
Mine didn't run fine with a full Safari tank.
I haven't checked the others yet but I know the 40171 has a shutoff valve so the bike won't keep letting fuel in and hydro lock when parked overnight DAMHIK
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 10-07-2010, 04:12 PM   #201
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Greetings,
It would seem that the #40252, as listed below, would be the perfect pump for our bikes. We must be missing something...
(Another website lists the #40252 as NOT having a Built-in Check Valve, yet still having a Positive Shut-off / Anti-Siphon Valve.)
12 VOLT FACET CUBE FUEL PUMPS
PART #
MAX-MIN
GPH
POSITIVE
NEGATIVE
INLET/OUTLET
CHECK
POSITIVE
PSI
LEAD CONNECTOR
LEAD CONNECTOR
THREAD SIZE
VALVE
SHUT-OFF
40104
4. - 1.5
25
N/A
.25 RING
1/8-27 INT
12
N
N
40105
4.5 - 3
30
N/A
.25 RING
1/8-27 INT
12
N
N
40106
7. - 4
32
N/A
.25 RING
1/8-27 INT
12
N
N
40107
10. - 7
38
N/A
.25 RING
1/8-27 INT
12
N
N
40108
6 - 4.5
32
.25 BLADE
.25 RING
3/8 FLARE
12
N
N
40109
7 - 4.0
32
N/A
.25 RING
3/8-18 INT
24
Y
N
40135
7 - 4.
32
PACKARD
.25 RING
1/8-27 INT
12
N
N
40136
7 - 4.
32
PACKARD
.25 RING
1/8-27 INT
12
N
N
40137
7 - 4.
32
PACKARD
.25 RING
3/8-18 INT
24
Y
N
40138
7 - 4.0
32
PACKARD
.25 RING
1/8-27 INT
24
Y
N
40147
9 - 4.5
32
.25 BLADE
.25 RING
1/8-27 INT
24
Y
N
40148
4.5 - 2
24
.25 BLADE
.25 RING
1/8-27 INT
24
Y
N
40163
2.5 - 1.5
17
.25 BLADE
.25 RING
1/8-27 INT
24
Y
N
40166
39 -25
9
175 BULLET
1/8-27 INT
Y
N
40171
3.5 - 2
15
PACKARD
.25 RING
1/8-27 INT
12
Y
Y
40176
5 - 3.5
19
N/A
.25 RING
1/8-27 INT
36
Y
Y
40177
2. - 1
7
N/A
.25 RING
1/8-27 INT
24
Y
Y
40178
3.5 - 2
15
N/A
.25 RING
1/8-27 INT
36
Y
Y
40185
11.5 - 9
32
N/A
.25 RING
1/8-27 INT
36
Y
N
40189
5 - 3.5
15
AMP
.25 RING
1/8-27 INT
36
Y
Y
40217
3.5 - 2
15
.156 BULLET
.25 RING
1/8-27 INT
36
Y
Y
40229
6 - 4.5
32
PACKARD
1/8-27 INT
12
N
N
40232
10. - 7
34
PACKARD
1/8-27 INT
12
N
N
40241
3.5 - 2
15
.157 BULLET
.25 RING
FEMALE FLARE
36
Y
Y
40252
1.5 - 1
6.5
PACKARD
1/8-27 INT
24
Y
Y
http://www.facet-purolator.com/index...d=16&Itemid=31
ktm950se
ktm950se screwed with this post 10-07-2010 at 04:22 PM
Old 10-07-2010, 04:17 PM   #202
Brown Dog
Brown Dog's Avatar
Oddometer: 1,964
I've been saying this for months.
The 40252 would be perfect & also has the check valve
Old 10-07-2010, 05:08 PM   #203
Dan Alexander
Oddometer: 7,667
And then people recommend a pressure regulator ...duh.
How about just use the one with the proper psi and gph rating in the first place
Old 10-08-2010, 01:05 AM   #204
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 380
Well, that 40252 Facet has been pretty darn hard to find available, for starters, and costs more. 40171 plus regulator has been promoted, readily available and pretty cheap, so people buy them. And if you're not doing a lot of prolonged slow technical & whoops riding, you may never experience the flooding symptoms in the first place. So, yeah, duh.
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 10-08-2010, 06:25 AM   #205
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,665
Eh?
I saw a SE last night with a F'n bicycle and rack on the back!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 10-08-2010, 06:42 AM   #206
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,862
Originally Posted by ktm950se
Interesting.....
The Adventure needs extra pressure as the pump is under the motor and has to push the fuel uphill?
Old 10-08-2010, 06:59 AM   #207
Dan Alexander
Oddometer: 7,667
Maybe not ... from that chart the 40171 has a dry lift of 12" while the 40252 has a lift of 24"
Maybe it's the gph rating ... the 171 is 15 while the 252 is 6.5 but in an hour of riding you wouldn't need even 6.5 ... unless you were really flying.
Old 10-08-2010, 07:01 AM   #208
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,862
It was just a guess.
I've been running the 171 and have had no issues
Old 10-08-2010, 07:03 AM   #209
Dan Alexander
Oddometer: 7,667
Never get that slow speed bogging thing?
I know, you never go slow
Old 10-08-2010, 07:44 AM   #210
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,862
No bogging that I've noticed .
It's silky smooth all through the range (unless I'm over 12,000ft).
Times are GMT -7.   It's 04:59 PM.
