Old 07-11-2010, 04:39 PM   #46
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,834
Originally Posted by big adv
If your going to dispense advice on repairs, make sure its correct........
HH bolt on the shift lever (Adventure) M6 Loctite 243 + 10 Nm
There is a big difference between 10 and 25 Nm on a 6mm bolt, as in it will break at 25Nm....
thanks for correcting that 10Nm
loctite 242 i been using for near 15 yrs now on my speedway , mx , enduro , road bikes & our A class pro buggie & B class superlite buggie. never had a problem.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 07-11-2010, 06:22 PM   #47
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,943
Is your Tail Lamp Lens Loose ?
I cut a piece of 3/8" thick heavy foam with adhesive on one side & stuck it to the
underside of the rear fender above the red lens to hold it snug.
Sorry I dont have pic but it works
Brown Dog is offline   Reply With Quote
Old 07-11-2010, 11:59 PM   #48
Conspire
Conspire's Avatar
Oddometer: 57
that was an easy fix, my lever didn't need to be bent, once i took it off and put it back on and lowered it a bit it worked fine. I don't have any loctite, but will try to pick some up soon. I also have the same issue with my brake lights, and not sure how to fix it. slight braking with just the rear brake won't turn the light on. potentially you could slow down pretty fast by downshifting and a bit of rear brake, and the driver behind wouldn't see any brake light. I usually try to use the front as well when in traffic, but I'd like to fix this problem if there is a simple fix.
Conspire is offline   Reply With Quote
Old 07-12-2010, 12:28 AM   #49
veetwo _tls
RENOVATIO:
Oddometer: 1,834
adjust the pushrod.
adjusting one way will make the brake light come on later & the other come on sooner (if too much the brake light & brake will stay on)
950 SUPERENDURO R AUS/UK 2007 > CHASSIS MANUAL > PAGE: 28 > REAR BRAKE CONTROL > FiG:4
if you don't have a manual jump on http://www.bikebandit.com/oem-parts its a free online PDF manual.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 07-12-2010 at 05:26 PM
Old 07-12-2010, 02:26 AM   #50
LukasM
Oddometer: 5,415
You guys actually use a torque wrench to tighten your shift lever bolt? Talk about OCD.....
Yo JJ,
Have I seen a picture of your new steed yet? I am just fixing up an 800 Beemer, I have a feeling that I'll want to trade it in on a SE after the first ride around the block... Less weight, more power!
Old 07-12-2010, 06:31 AM   #51
wpbarlow
Oddometer: 10,640
Originally Posted by pfb
Lots of different versions, but they all look a bit like this:
About $9 here
Or you can even buy a pretty KTM version...
Part U6951172, about $25.
Do both of those work on the SE shock? The reason I'm asking is that they look pretty different in the contact patch area as well as the "open" part that goes around the ring.
wpbarlow is offline   Reply With Quote
Old 07-12-2010, 08:02 AM   #52
mousitsas
mousitsas's Avatar
Oddometer: 2,752
Yo JJ,
It took you some time Lukas to realise, but you're there eventually
Old 07-12-2010, 08:05 AM   #53
LukasM
Oddometer: 5,415
Haha, you are right! Deep inside I always knew but I was too scared... still am in fact.
Old 07-12-2010, 09:35 AM   #54
WARRIORPRINCEJJ OP
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,789
...Yo JJ,
LukasM "slumming" in the humble, little thread I started...To what do I owe this honor?
I don't think you've seen a picture of my SE, yet. I've had the thing quite awhile. However, I didn't start showing it alot of love until it took-over the DR's daily duties...Then, the "fine-tuning" began.
Congrats. on the 800. I think they are great bikes...Rotax, aren't they? Dude, you know you're a KaTooM guy. How in the world did you wind-up with the 800? I think every bike you own has some KTM part integrated. What's the project this time?...WP suspension and a 690E fender on the Beemer?
I'll tell you man...I don't think any bike has the "edge" of the SE. I parked it at a little get-together, this weekend, amidst several "pricey" steeds. There were people around it all day. They were posing and taking pictures with the damn thing!...like it was a porn star at a movie premiere. I thought about charging for the photo ops.
On top of it being edgy, there are some guys, here (in the OC), who can ride it like it's a 200-pound enduro weapon. I can't, but some can. Because of them, I am continually amazed at the beating it is capable of.
Here is a gratuitous "portrait" for your viewing pleasure...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ screwed with this post 07-12-2010 at 09:47 AM
WARRIORPRINCEJJ is offline   Reply With Quote
Old 07-12-2010, 10:31 AM   #55
Chris618
Chris618's Avatar
Oddometer: 828
Awesome helmet, I want one!
Chris618 is offline   Reply With Quote
Old 07-12-2010, 10:41 AM   #56
WARRIORPRINCEJJ OP
Oddometer: 9,789
Viola!...Your wish is granted.
http://www.motovationracing.com/
It is nothing more than a "wrapped", white Arai VX-Pro3.
Old 07-12-2010, 12:06 PM   #57
motomal
motomal's Avatar
Oddometer: 167
Helmet Skinz UK Supplier
And there's a UK supplier too… cool!
Helmet Skinz UK
2007 KTM 950 SM
motomal is offline   Reply With Quote
Old 07-12-2010, 02:04 PM   #58
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,309
Originally Posted by traveltoad
Two SE questions:
How do I keep the front wheel on the ground?
How do I keep myself from laughing while riding?
How many tires im going to change this season
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Old 07-12-2010, 02:18 PM   #59
RedlegDaddy
RedlegDaddy's Avatar
Oddometer: 505
A bunch Javier!
"Above all, we must realize that no arsenal, or no weapon in the arsenals of the world, is so formidable as the will and moral courage of free men and women. It is a weapon our adversaries in today's world do not have." Ronald Reagan
Current bike: something ORANGE!
RedlegDaddy is offline   Reply With Quote
Old 07-12-2010, 04:01 PM   #60
Qwik
Adrenaline Addict
Oddometer: 6,707
Yes they do. I have the Bling KTM one.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Times are GMT -7.   It's 04:14 AM.
