Old 07-03-2011, 12:09 AM   #631
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
Originally Posted by veetwo _tls View Post
07 950SER
anyone have a wiring PDF of the AU/UK models ?
Q:
i've just noticed my F/Brake switch wires ( 2 pin female plug - Gn/Wh & Bu/Ye ) it's unplugged from when i installed the Raid Rallye kit.
in the loom at the front i have a ( 2 pin male plug - Or & Or/Bl ) would this be it for above to connect too ?
can someone take a look at there's thanks to confirm.
Found it i'm going blind must be old age & fixed
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 07-06-2011, 11:55 AM   #632
markie_wales
Oddometer: 936
headligth not working
FFS if it's not one thing it's the other!!!
Had the rear wheel off for a new tyre (don't the beads break easy compared to the Adv??) and gave it a once over, indicators, brake lights etc all OK. Headlight either low or high beam - nothing. Checked the fuse and that's OK, so before diving in behind the dash any "common known issues"?
Plan is to check wiring for breaks, check bulb but not sure what else it could be as I can't see how the switch could have become knackered.
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales screwed with this post 07-06-2011 at 02:08 PM
markie_wales is offline   Reply With Quote
Old 07-06-2011, 04:10 PM   #633
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,947
Originally Posted by markie_wales
... Headlight either low or high beam - nothing ...
Markie
I've been having bulbs go bad.
They are burning into inside the metal base part - NOT the Filament part inside the glass
Brown Dog is offline   Reply With Quote
Old 07-06-2011, 08:13 PM   #634
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,273
Well I put the 16t sprocket on the front today, feels good around the yard. I'll try it on some real offroad Sunday, so I'll report on it then. Hopefully I'll spend far less time feathering the clutch in the tight stuff.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 07-06-2011, 08:18 PM   #635
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,109
16t
You'll be very happy with the result
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 07-07-2011, 06:53 AM   #636
markie_wales
Oddometer: 936
Thanks BD - I take it it's pretty obvious when I pull the bulb?
cheers
Markie
Old 07-07-2011, 08:18 AM   #637
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,533
Like BD I have the Dirt n' Blood risers that move the bars up and forward .. the forward being the key part. All held together with a nice Scott's damper Perfect
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 07-07-2011, 08:30 AM   #638
Dan Alexander
Oddometer: 7,533
Originally Posted by The Bigfella View Post
G'day guys. I posted up a separate thread about heat treament on the 950SE subframe. 102 views, no replies.
What's driving it is that I'm setting off a month from today on a 20,000km trip which is mostly rough roads (Cape York, East Timor, Indonesia, Malaysia, Thailand, Cambodia, Laos). My subframe isn't cracked... but if it cracks somewhere on this trip, like on the Ho Chi Minh Trail.... the only way of repairing it will be to tie it up with fencing wire.
So - I'm looking to reinforce it before I leave. Trouble is, my son and a couple of mates (mech engineer, fabricator and boat builder) all tell me that welding it will weaken it. The more welding, the softer the 7020 aluminium will get. We don't know what the factory temper is, so we are flying blind if we try and re-temper it.
Current thinking at this end is a bolt-in reinforcement bracket that goes from the rear grabrail/luggage rack mounting point, to the fron mounting points and then to the seat lock brace and exhaust mounting points.
Any thoughts guys?
I ran the Trans Labrador Highway (1500km of gravel and new construction) with the Worlfman / BBriggs racks and saddlebags. All loaded with a top rack and medium Wolfman duffel packed with camping gear and no cracks at all.
I'm sure the racks add a lot of stress relief to the subframe as they triangulate load down to the rear footpegs.
If you're going to carry saddlebags it's an easy and clean option.
http://www.wolfmanluggage.com/Access...side_rack.html
Old 07-07-2011, 10:23 AM   #639
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
Originally Posted by SFKLR View Post
Specs for 2009 Erzberg Edition claim adjustable footpegs. Mine doesn't have 'em. What do they look like? Can they be acquired aftermarket?
Sometimes the adjustment comes from flipping the barrel they hinge on 180 degrees so that the peg has a hi and low position. This is how the Fastway pegs work at least.
Seth S
Seth S is offline   Reply With Quote
Old 07-07-2011, 10:43 AM   #640
Brown Dog
Brown Dog's Avatar
Oddometer: 1,947
...I take it it's pretty obvious when I pull the bulb?
Markie
No, not really.
Sometimes Black is visible from exessive heat around the metal contacts on the end of the bulb, but not always
Old 07-07-2011, 11:18 AM   #641
markie_wales
Oddometer: 936
No, not really.
So this is how it went....
- Open up the head light surround
- Unplug connector, remove rubber surround, pull bulb.
- inspect for ages but not able to see anythign wrong.
- refit everything
- still no joy
- take switch apart
- inspects for ages, all OK, puts back together
- still no joy
- start inspecting wiring, inch by inch
- follow wire fronm switch to the connector behind head light.
- plug connector back in as it's hanging loose
- hands in pockets, looks down, whistles, wander around garage thnking "the boys on Advrider are going to rip the piss out of me"
I have no idea how it came out - lighhts haver been fine and it's been ages since I've been behind the dash - oh well lesson learnt.
cheers
Markie
Old 07-07-2011, 11:08 PM   #642
veetwo _tls
RENOVATIO:
Oddometer: 1,849
is this the one i need for the SE ?
* CAB10 Chain Adjuster Block Kit: KTM Adventure
http://www.touratech-usa.com/Store/P...ck-Kit-KTM-LC8
http://www.ziptyracing.com/products/...px?id=MTU0Mg==
CHEERS: brett
MY07 950 SER
Old 07-08-2011, 05:29 AM   #643
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,109
Thats the exact one I've got still uninstalled in a box of goodies from the PO. So if anyone has some feedback on these that would be great. I was waiting to install when I put on a new back tire in a couple of weeks.
'09 BMW R1200GSA
Old 07-08-2011, 07:54 PM   #644
ct_rider
Oddometer: 77
Spare Clutch and brake levers - options other than OEM?
Looking to pick up a spare set of front brake and clutch levers to pack with me on the trail and the only option I have found is OEM at about $110 for the pair. Are there any lower cost alternatives? I always like the peace of mind of having spare levers even with bark busters and not overly tightend bar mounts.
What do you guys pack for spare levers?
Thanks,
Ken
ct_rider is offline   Reply With Quote
Old 07-08-2011, 08:06 PM   #645
buildit
buildit's Avatar
Oddometer: 14,273
Thanks,
Ken
I have a rear break. I worry more about a clutch lever breaking.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Times are GMT -7.   It's 11:32 PM.
