Old 09-13-2011, 06:24 AM   #721
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,890
Originally Posted by buildit View Post
Just noticed this today. I am getting a strange clicking noise from the steering. I can't believe the bearing could be bad, no movement in the triple on the stand. Looked for something cracked or showing wear signs. What else could it be?
I would first check throttle cable and brake line shield.
c.vestal screwed with this post 09-14-2011 at 04:53 PM
c.vestal is offline   Reply With Quote
Old 09-13-2011, 02:31 PM   #722
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,107
Originally Posted by LoFlow View Post
I thought about this while riding yesterday. For me, I get to many of those awkward, about to stall moments where I appreciate a quick reacting throttle input. And usually when I stall while standing I end up on the ground. But yes the ass end does step out pretty quickly with the stock cam. Please report back your experience with the new cams.
I know what you mean about the awkward moments. I guess thats what my hesitation is about, changing one of the main characteristics of the bike. I only have the 400 tamer cam and haven't installed yet. Might be my project this evening. Will report back.
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 09-13-2011, 02:36 PM   #723
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,279
Originally Posted by c.vestal View Post
I would first check throttle cable and break line shield.
I checked them again and the tripple. No visible sign of wear or cause for the noise. Clicking does not occur with weight off the front tire. It also only seems to happen near the ends of the turning range. So it's not the triple hitting at the end it's before then. I'm stumped.
It does seem to resonate thru the handle bars from the fork tubes. But the compression from the tubes feels good and there's no fork fluid leaking.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 09-13-2011, 07:48 PM   #724
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,107
G2 throttle tamer
Installation was very easy except for getting grip back on in correct location 20 minutes total. Was using the ProTaper grip glue and it does dry FAST !
Took bike out for a quick spin, first impression was a much smoother throttle. However, I found myself reaching around and grabbing for more.
Felt like lots of play in throttle cable like needed adjustment.
Will take some getting used to...This is a quick first impression so final judgment is still out.
Do they make a 300 cam???
'09 BMW R1200GSA
Old 09-15-2011, 03:19 AM   #725
IDOC
IDOC's Avatar
Oddometer: 27
I needed to top off my hydraulic clutch resevoir today on my 950 SE, and found it only took a specific type of mineral oil made by motorex....I drove a total of 120 miles to pick some up from my nearest dealer....In the future, if I need to 'top' it off, does anyone know of anything that I could use in its place that I could pick up at an automotive store???
IDOC is offline   Reply With Quote
Old 09-15-2011, 03:28 AM   #726
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,954
I used "Mineral Oil" from a Drug Store in my 690 Enduro Hydraulic Clutch
The Lever pull feels stiffer when cold, but it's been working fine for over
a Year just fine
Brown Dog is offline   Reply With Quote
Old 09-15-2011, 06:18 AM   #727
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,740
Fork Oil (lots of guys like 2.5W but you can use any weight the pull just may seem heavier with say 7W)
Honda ATF
Baby Oil
If you had to top it off I would check your clutch slave for weeping/leaking.
v8toilet is offline   Reply With Quote
Old 09-15-2011, 09:26 AM   #728
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
All 6 of my KTM's have been low of hyd cl fluid from the factory
Old 09-15-2011, 09:36 AM   #729
IDOC
IDOC's Avatar
Oddometer: 27
a Year just fine
Thanks to you and V8TOILET, I may just have a few choices next time......Thanks!
Old 09-15-2011, 09:40 AM   #730
IDOC
IDOC's Avatar
Oddometer: 27
BTW, I will never use baby oil in my clutch unit......Do you know HOW MANY babies that they have to squeeze to make just one pint of that stuff!!???
Old 09-19-2011, 02:36 PM   #731
ct_rider
Oddometer: 77
Voltage regulator?
Like many others my voltage regulator just went bad. A call to the local KTM dealer and I found the same as others - it is backordered until November. I was planning a long ride next month - it is BS to wait a couple months for a voltage regulator. I have called around and haven't been able to locate one.
Any idea's where I might be able to find one? KTM World, Munn Racing, and Bike Bandit all came up empty handed.
Are there any other options out there for a non stock replacement?
Thanks for any suggestions!
ct_rider is offline   Reply With Quote
Old 09-19-2011, 05:08 PM   #732
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 936
Voltage regulator
http://www.oregonmotorcycleparts.com/VRRPM.html saw this in a old thread (google it) Thanks to CP modem. I belive this guy can repair yours or build you one
dogsslober is online now   Reply With Quote
Old 09-19-2011, 05:49 PM   #733
jacmac
Oddometer: 32
950 se voltage regulator
I was told by ktm tech that voltage regulator from an adventure or super duke is the same the only difference is the length of the wire leads. Do not know if they are on backorder as well?
jacmac is offline   Reply With Quote
Old 09-19-2011, 05:55 PM   #734
jacmac
Oddometer: 32
I was told by ktm tech that voltage regulator from adventure or super duke will work in the 950 SE, the only difference is the length of the wire leads. Do not know if they are on backorder as well?
Old 09-19-2011, 06:08 PM   #735
dogsslober
dogsslober's Avatar
Oddometer: 936
voltage regulator
Allso they say a yamaha raptor 660 V/R will work.
Times are GMT -7.   It's 07:41 PM.
