Old 09-19-2011, 06:10 PM   #736
jacmac
Oddometer: 32
950 se voltage regulator
Was told by KTM tech. that the voltage regulator from an adventur or super duke is the same voltage regulator in the 950 SE, the only difference is the length of the wire leads. Do not know if they are on backorder too?
jacmac is offline   Reply With Quote
Old 09-19-2011, 08:11 PM   #737
ct_rider
Oddometer: 78
VRRPM a no go
Thanks for the advice, I actually found the same site after searching. They do not offer a voltage regulator that will work for the SE.
Anyone have any other suggestions? I was thinking there has got to be another voltage regulator that could be used off another bike. Wouldn't it be easy enough to splice in another high amp/watt voltage regulator from a touring bike or something?
I hate to put the bike away for a month in the fall waiting for a KTM piece.
ct_rider is offline   Reply With Quote
Old 09-19-2011, 08:11 PM   #738
ct_rider
Oddometer: 78
VRRPM a no go
Old 09-19-2011, 08:12 PM   #739
ct_rider
Oddometer: 78
VRRPM a no go
Old 09-20-2011, 06:05 AM   #740
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,298
Quick note about my previous issue with "clicking noise". I know what is doing it now. The bark busters. Not sure why but it appears as the handle bar flexes ever so slightly as I turn it the bark busters are torquing enough to allow them to click as the collar moves ever so slightly. I tightened them down a bit more and it helped but is still not perfect.
2013 Super-10, 2007 KTM950SEr, 2006 KLR650
buildit is offline   Reply With Quote
Old 09-20-2011, 09:48 AM   #741
Schannulleke
Oddometer: 210
Originally Posted by Schannulleke View Post
So the Adv guys can add a second fan on their radiator. The SE already has 2 fans, but they are smaller than the Adv fans. Anyone tried to replace the small SE fans with larger Adv fans to increase cooling performance, or are they just large to fit in there?
Kick. Anyone?
Schannulleke is offline   Reply With Quote
Old 09-22-2011, 09:45 PM   #742
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,463
990 Adventure wheels on a 950 Super Enduro?
Guys,
Will the OEM wheels from a 990 Adventure work on a 950 SE? I know
- the wheel diameters are the same
- the right front rotor *may* have to be removed.
What about axle diameters/lengths and spacers? I think it might work after reading this thread:
http://www.advrider.com/forums/showthread.php?t=621198
Has anybody actually put Adventure wheels on the SE? I have an opportunity to pick up a set cheap.
TIA
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney screwed with this post 09-22-2011 at 10:18 PM
DangerMoney is offline   Reply With Quote
Old 09-22-2011, 10:10 PM   #743
WARRIORPRINCEJJ OP
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 10,001
Originally Posted by DangerMoney View Post
...Has anybody actually put Adventure wheel on the SE? I have an opportunity to pick up a set cheap.
TIA
I'm almost positive that Mike (Brown Dog) has a rear Adventure rim, on his SE.
You know they're soft as shit...right?
They don't even come close to your DirtStars...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 09-22-2011, 10:16 PM   #744
DangerMoney
Oddometer: 1,463
That's OK as I would shod them with tires more street-oriented for street use. My DirtStars are shod with full knobbies.
Old 09-23-2011, 03:28 AM   #745
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
I have adventure rims on my SE with scorpions that I use for the roads. Dirt stars have the knobbies. I have just one front disc installed and use the the SE front wheel spacers. Back tire cost more because it is wider.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 09-23-2011, 05:25 AM   #746
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,972
Originally Posted by Xmoto View Post
I have adventure rims on my SE ...
I have ADVenture Rims laced to my SE hubs.
+1 on the looks
BUT . . . . . . the wide rear catches Everything on the trail with it's Width
I Always keep aired above 34psi to not bend a rim.
The Stock Rims are Mucho better for Off-Roading as JJ mentioned
Brown Dog screwed with this post 09-23-2011 at 05:33 AM
Brown Dog is offline   Reply With Quote
Old 09-23-2011, 06:02 AM   #747
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,084
adv rims
I have a set of adv hubs set up with 19" front, stock 18" rear,converted to tubeliss. just need to run SE spacer's and alls good
dogsslober is offline   Reply With Quote
Old 09-27-2011, 03:09 PM   #748
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
OK this question is for the people who have done the vacuum fuel pump conversion. I put the pump on top of my air box and tee into the crank case breather hose. Everything was fine for about a month then the bike died on me and barely kept running to make it home. I took the pump apart and there was water on the vacuum side of the diagram, I guessed it was condensation from the engine breather. I switched to the rear cylinder and put the fitting with the larger ID on the left and plug the hole on the right with a bolt. The bike runs fine but is hard to start now. In the past in the morning I would pull the choke lever and she would fire right up. Now I have to crank it a lot to get in running. Not as bad when it is warm but still not the same. Anyone have any ideas.
Old 09-27-2011, 05:56 PM   #749
Qwik
Adrenaline Addict
Oddometer: 6,947
I have my Vac pump mounted under the engine (on a 950ADV) and havent had any issues with it. I dont know if the higher mount makes a difference. I would not think so but I could be wrong. You may still have moisture in the line too.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 09-27-2011, 06:44 PM   #750
DangerMoney
Oddometer: 1,463
+1 on the looks
Are both of you running the standard size ADV rear tire (150/70-18)? Any problms with the tire rubbing up against the chain/swingarm/etc?
Times are GMT -7.   It's 04:54 PM.
