Old 09-28-2011, 02:53 AM   #751
1SEinRo
1SEinRo's Avatar
Oddometer: 26
Hi guys,
I have a bit of a problem with a 950 SE. The bike stayed in a garage for some long time (more than 6 month) without running at all and now, there are two issues:
1. I can start it once and after that the starter relay just makes noises but engine will not start until I charge the battery again....
2. I can start the bike with the choke at 1/2 but when I am trying to close the choke (to idle position) it stalls.
Please give me some inputs if you run into this specific behaviors.
1SEinRo is offline   Reply With Quote
Old 09-28-2011, 03:30 AM   #752
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Originally Posted by DangerMoney View Post
Are both of you running the standard size ADV rear tire (150/70-18)? Any problms with the tire rubbing up against the chain/swingarm/etc?
Yes that is the tire. No problems.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 09-28-2011, 03:32 AM   #753
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Originally Posted by 1SEinRo View Post
Hi guys,
Sounds like you might need a new battery.
Old 09-28-2011, 04:05 AM   #754
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,654
+1
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-28-2011, 10:51 AM   #755
1SEinRo
1SEinRo's Avatar
Oddometer: 26
Agree with the battery solution, but what about the other issue. To add some info: when I try to give it some gas after I started it with the choke, it stalls also...
Old 09-28-2011, 10:53 AM   #756
exhaust_nut
exhaust_nut's Avatar
Oddometer: 193
Clogged jet?
exhaust_nut is offline   Reply With Quote
Old 09-28-2011, 12:27 PM   #757
wpbarlow
Oddometer: 11,287
Add some SeaFoam to the gas tank and let it run for a while.
wpbarlow is offline   Reply With Quote
Old 09-28-2011, 04:18 PM   #758
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,963
I'm running the Mefo Super Explorer 150/70-18"
No problems at all, but as mentioned - the narrower rims handles much better offroad.
Brown Dog is offline   Reply With Quote
Old 10-01-2011, 11:00 AM   #759
Thisguy
Hold Fast
Thisguy's Avatar
Oddometer: 2,307
You have to let it warm up. The carbs are picky. May want to get new gas in it. Also, get new battery.
1986 R80RT
2000 Land Cruiser
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over." Hunter S. Thompson
Thisguy is offline   Reply With Quote
Old 10-02-2011, 09:26 AM   #760
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 251
950 SE floods when going through woops
My 950 SE starts flooding out when I go through a bunch of woops. If I stop the bike dies and I can smell gas. Anyone else have this problem and what was the fix?
SE Steve is offline   Reply With Quote
Old 10-02-2011, 06:16 PM   #761
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Does it have a stock fuel pump or something with higher pressure? Have you checked float height?
07 SE
PG007
Old 10-02-2011, 06:40 PM   #762
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,003
Flooding
Mine did the same with the stock fuel pump, floats in spec. Stopped when my stock pump quit and went with to vacuum fuel pump.
dogsslober is offline   Reply With Quote
Old 10-02-2011, 08:40 PM   #763
Crashed Bad
Big man, little bike
Crashed Bad's Avatar
Oddometer: 2,211
Have you bypassed the sidestand switch ?It can kill the bike in whoops and mask as a fueling problem.
Nothing upsets a woman like a man at leisure.
Crashed Bad is offline   Reply With Quote
Old 10-03-2011, 12:17 AM   #764
edgy
edgy's Avatar
Oddometer: 489
Riding my SE yesterday(29000 km) she suddenly started missing terribly and backfiring at any revs with no power! I still on the stock fuel pump...is that the likely problem,she was recently serviced with new plugs etc
www.astonesthrow.co.za
`08 KDX200
`08 SE950R
`11 KTM690
edgy is offline   Reply With Quote
Old 10-03-2011, 05:39 AM   #765
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,503
Did you smell sulfur (rotten eggs) at the same time? If so, your voltage regulator may be going. When my fuel pump went, it was more like I just ran out of gas...the engine died immediately, and it would not restart. When you turn the key on, can you hear the fuel pump cycling?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Times are GMT -7.   It's 01:51 AM.
