Old 10-07-2011, 04:31 PM   #781
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Originally Posted by triplenickel View Post
I don't think there's anything wrong with these subframes
I load the hell out of mine, she has been down numerous times, loaded up through miles of deep sandy whoops, and one very high speed end over end. Maybe I got one of the good ones.
Last inspected a few days ago, no problemo
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 10-07-2011, 04:38 PM   #782
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Originally Posted by ct_rider View Post
Has anyone else run into this?
How tall is the rise? I put 2" pivot risers on mine but ended up disassembling the bike and rerouting all the original cables/controls. They all currently work without stress through the full movement of the bars, any more and cables would have to be replaced.
Old 10-07-2011, 06:00 PM   #783
ct_rider
Oddometer: 77
I'm not sure how much rise there is with the set up as I never saw the stock set up. I would guess the bars are maybe 1-2 inches higher than stock.
Next time I have the tank off I will take a loot at alternate routing - do you remember how you re-routed the choke? From what I remember it was a pretty straight shot with the stock routing.
ct_rider is offline   Reply With Quote
Old 10-07-2011, 06:20 PM   #784
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Dumb question but is it routed through the airbox properly?
07 SE
PG007
Old 10-07-2011, 08:14 PM   #785
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
I haven't put a rise on mine yet but I noticed the choke is really tight.
v8toilet is online now   Reply With Quote
Old 10-08-2011, 08:45 AM   #786
ct_rider
Oddometer: 77
Best I can tell the routing was all stock and proper when I had the carbs apart. I guess the under bar damper is enough to cause a problem. Thanks for the feedback. Next time I have the tank off I will double check the routing and see if there is room for improvement. For the time being I expect the bike to run better without the choke partially engaged.
Old 10-11-2011, 12:50 PM   #787
Remmie
Remmie's Avatar
Oddometer: 96
Raid Design Rally Kit for the 950 SE
Im looking for some pictures of the Raid Design Rally Kit for the 950 SE, but with the Safari 30 ltr. Tank. On the side from Raid Design you can order the kit that fits the Safari Tank. But I have never seen any picture of it.
Remmie
I recycle, I sniff my own farts
Remmie is offline   Reply With Quote
Old 10-11-2011, 01:19 PM   #788
Schannulleke
Oddometer: 210
No pictures unfortunately as far as I know of, but maybe someone has the combination of the rally kit and the safari anyway
About the 2 versions. The standard version fits the stock tank and can be made to fit the Safari. The Safari version will only fit the Safari (side panels are too short to fit stocker).
I think you should also send a PB to David P. directly or send Raid Designs an email with your question. I think they have used an SE with Safari during the creation of the Safari-friendly version of their kit.
Please share the info/pics you find.
Schannulleke is offline   Reply With Quote
Old 10-11-2011, 02:32 PM   #789
v8toilet
v8toilet's Avatar
Oddometer: 1,737
Last I heard they were developing or finalizing the kit, which may explain the lack of images. I believe they've been busy at rallies so communication might be a bit slow.
Old 10-11-2011, 08:39 PM   #790
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,665
Just out of Idle curiosity, Does anyone know how many SE's were sold in the states?
BENRON is offline   Reply With Quote
Old 10-11-2011, 08:45 PM   #791
WARRIORPRINCEJJ OP
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,886
BENRON,
Did you try a Google advanced search on it?...with "ADV" as the site?
The reason, that I ask, is because there is a thread on it, somewhere (I'm like 90% sure.)
EDIT- I looked-around, man, and couldn't find it. But, I am positive that there is a thread that shows exactly how many were exported to different countries.
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ screwed with this post 10-11-2011 at 09:10 PM
WARRIORPRINCEJJ is offline   Reply With Quote
Old 10-12-2011, 07:15 AM   #792
edgy
edgy's Avatar
Oddometer: 489
Originally Posted by edgy View Post
Riding my SE yesterday(29000 km) she suddenly started missing terribly and backfiring at any revs with no power! I still on the stock fuel pump...is that the likely problem,she was recently serviced with new plugs etc
Well after fiddling with the fuel pump and checking electronics I loaded the bike and took her off to the dealer, turns out that the front cylinder plug had actually broke! Thankfull that it was nothing serious,the intake valve were also found to be tight(shims)
www.astonesthrow.co.za
`08 KDX200
`08 SE950R
`11 KTM690
edgy is online now   Reply With Quote
Old 10-15-2011, 08:18 PM   #793
armerjo1
Oddometer: 3
950 Charging Issues ??
Can anyone help?
I have a 950SE that has died a couple times. It seems like when the bike gets hot having the fan on runs the battery down. First time it happened I put the battery on charge and it seemed to work for a few days then died again. Second time I replaced the battery and put a volt meter on the battery engine off (12.5V) and engine on (+13V) and rev'd (~14.5-15V) depending on throttle input.
All was well for about a month with new battery. Today I went for a two hour ride into the Sierra Foot Hills and was on some back roads that turn into dirt, at the top of a look out I shut the bike off and when I started it back up I noticed the bike started but spun over slugishly. At that point I said ok, don't shut the engine off until I get home so I turned around and headed home. Anyways, as luck would have it I was ~30 miles from home when the bike stalled like someone disconnected the battery. When I pulled over the battery was dead, dash was dim, barely enough electricity to see the dash. With help I was able to jump start the bike and got it home without another problem, actually it ran fine all the way home. At home I checked the battery voltage, engine idling (8.5V) engine rev'd (9.5V). After shutting it down and letting it set for about an hour I checked again and the battery read (10.5V). So, now I've put it back on charge but can't figure out what do do next.
Seems like its a charging issue but also seems like charging system is working because the volt meter reads higher with engine revs as I would expect.
Any suggestions?
armerjo1 is offline   Reply With Quote
Old 10-15-2011, 08:39 PM   #794
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,468
You might try
http://www.electrosport.com/media/pd...ng-diagram.pdf
http://www.electrosport.com/technica...-finding-guide
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 10-16-2011, 05:58 AM   #795
Crowley
Crowley's Avatar
Oddometer: 56
Originally Posted by armerjo1 View Post
Can anyone help?
Any suggestions?
1 Where is your volt meter connected to?
2 What is the voltage between your battery + and the frame with the bike running? Should be the same as your volt meter assuming you have another point that you are using for your voltmeter.
3 Have a look at the start relay connection to your battery if the voltages dont correspond.
Crowley is offline   Reply With Quote
Times are GMT -7.   It's 11:57 PM.
