Old 10-16-2011, 08:50 PM   #796
armerjo1
Oddometer: 3
I've been measuring everything between the (+) and (-) terminals on the battery.
armerjo1 is offline   Reply With Quote
Old 10-16-2011, 10:13 PM   #797
Crowley
Crowley's Avatar
Oddometer: 56
I think that your charging system is on its way out. Either regulator or generator. Take to an auto-electrician or dealer that knows something about the electrical system.
Crowley is offline   Reply With Quote
Old 10-17-2011, 07:17 AM   #798
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,715
Put a good battery in the bike and check the charging. you should see 13v to 14.6v. A dead battery can throw a bike charging system out of wack sometimes. If the charging is below the above numbers with a healthy battery then its time to determine if your stator is going or if your voltage regulator is going. To do this you will need to measure the AC voltage from the stator leads while the bike is running. I think you can also measure the resistance of the stator windings with the bike off to see if you have a shorted winding.
Seth S
Seth S is offline   Reply With Quote
Old 10-17-2011, 09:28 AM   #799
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,183
Leak from the Neutral switch
Hello All.
My SE recently started leaking from the "Neutral" switch in the bottom of the left side on the case. Right below the counter shaft sprocket.
About a teaspoon a day - when sitting.
So I removed the black electrical part from the outside, and cleaned the surfaces. The O-ring inside appeared to be OK an din the right spot.
I also cleaned out the inside of the area.
There are two silver "nubs" that obviously rotate and open / close the connection to the electrical switch.
But there is a consistent weeping of oil, and the O-ring does not seem to stop it.
What's going on?
Is there supposed to be a bit of oil in there?
Is the O-ring supposed to keep the oil in, or is it there to keep water out?
I cleaned everything, and put it all back together, and the darn thing is still leaking.
(I've read other threads on this, and replacing the O-ring should have fixed the problem...)
Any help would be appreciated.
Thanks.
Q~
UPDATE:
Well I've done a lot more research, and apparently I need to buy new O-rings.
I would have thought that cleaning and reinstalling the old ones would have been sufficient.
I'll order the parts tomorrow when my local shop opens.
Q~
Questor screwed with this post 10-17-2011 at 10:57 AM
Old 10-18-2011, 11:03 PM   #800
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
Not so much SE related but I installed some Dual Star heated grips on the SE. I used the accessory leads which maybe the problem. Anyway the grips work but the heat output is dismal even on high and even on the throttle side where its insulated from the bars by the throttle tube.
Every other heated grip I've had became uncomfortable on high after a few minutes. I bought the dual stars based on glowing reviews here in Advrider.
Is it the grounding or what?
v8toilet is offline   Reply With Quote
Old 10-18-2011, 11:24 PM   #801
mousitsas
mousitsas's Avatar
Oddometer: 2,948
I guess you have to connect it directly to the battery for a test. However, I think the acc cabling is really thin, so I'm not surprised.
mousitsas is online now   Reply With Quote
Old 10-19-2011, 06:33 AM   #802
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
As did I, they totally suck. I wired mine straight back to the battery, they worked brilliantly for about 2 weeks last winter. Troubleshooting results show good fuse, all wiring still ziptied to the frame and in tact, rocker switch still functioning.
I only purchased them because I'm not fond of bulky gloves.
The heat failed so I bought THESE and got used to the size.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 10-19-2011, 06:18 PM   #803
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,960
Skinny Slim Stock Grips for me
Originally Posted by HOT DAMN!
... I'm not fond of bulky gloves.
... THESE ...
Im not fond of bulky gloves either & Sure Not Fond of Bulky Grips
But . . . . . . .
I wanna set of Heated Gloves like these as I'll never own a bike with heated
grips
I dont really ride below 40 degrees
Brown Dog is offline   Reply With Quote
Old 10-20-2011, 08:57 AM   #804
mousitsas
mousitsas's Avatar
Oddometer: 2,948
SE steering dampener
Is there one in the powerparts catalogue?
Does it fit on the stock triple tree?
Is there any other option (if the answer on the above is negative) that does not require a change of said triples?
Otherwise, what are my options???
many thanks in advance
Old 10-20-2011, 05:37 PM   #805
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,468
SE steering damper
This is the only one that seems to exist (and I'd love to be proven wrong). I put one on the SE about six months ago.
http://www.scottsperformance.com/Sta...ro&BI_ID=17015
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 10-20-2011, 05:58 PM   #806
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,895
I am not aware of a bolt on without having to replace the triple.
http://www.brpmoto.com/products?page...tegory_id=1784
c.vestal screwed with this post 10-20-2011 at 06:06 PM
c.vestal is offline   Reply With Quote
Old 10-20-2011, 06:57 PM   #807
WARRIORPRINCEJJ OP
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,886
...Is there any other option (if the answer on the above is negative) that does not require a change of said triples?...
Originally Posted by DangerMoney View Post
This is the only one that seems to exist (and I'd love to be proven wrong)...
Originally Posted by c.vestal View Post
I am not aware of a bolt on without having to replace the triple...
http://www.rallemoto.com/contents/en-us/d41.html
First paragraph...
With another first for Ralle-Moto we have raised the bar (well we didnt actually raise the bar at all!!) with design and innovation in our new LC8 steering damper, after hours of development we now have a great steering damper concept for the KTM LC8 990/950 ADV - SE - SM - SMT to comply with a very specific design brief to fit onto the standard triple clamp.... Yes that's right no need for a new top triple clamp!
Y'all are welcome. I'll be here all week...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 10-20-2011, 07:43 PM   #808
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,895
Old 10-21-2011, 04:32 AM   #809
mousitsas
mousitsas's Avatar
Oddometer: 2,948
steering dampener
....ask and thy shall find out, they say
Many thanks!
Old 10-21-2011, 05:24 AM   #810
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,590
They are not sure if it will fit an SE with a Safari Tank. I will be finding out early Nov when I drop in there to get them to fit the Dampner with the Safari Tank on.
First paragraph...
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Times are GMT -7.   It's 01:08 PM.
