Old 10-30-2012, 05:38 PM   #1426
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,963
2nd to None
Originally Posted by pizzaboy View Post
today I finally ponied up and purchased a set of Akras ...
BEST Sounding Silencers Made IMHO.
FMF, Wings, Leo etc ain't even close
Quality, Fit & Finish are worth the extra $$
I'd love to see a dyno comparison between akra & fmf.
My bike & a buddies SE's have same mods, same gearing, jetting etc (I did both bikes)
We weigh the same & my akra bike pulls his fmf's pretty good at roll on in any gear
We swapped bikes & same difference with my bike pulling away
Ok, back to regulary scheduled programming
Brown Dog is offline   Reply With Quote
Old 10-31-2012, 05:46 AM   #1427
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,926
Well I'm sitting on the side of the road waiting for my wife........
07'SE which has been running fine just quit. Dead. No electrics at all. Main fuses look good. Would this be the mysterious ignition thing I've read about? Wiggling it did nothing so far. Anything in particular to check when I get home from work?
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 10-31-2012, 05:58 AM   #1428
Brown Dog
Brown Dog's Avatar
Oddometer: 1,963
Shorai or a "weight savings" battery ??
Loose battery cable at either end ??
Not a good time to be broke down
Hope u get er fixed
Old 10-31-2012, 08:40 AM   #1429
mountain eagle
terrorist
Oddometer: 2,926
Standard battery, cables tight. I'll be breaking out the multimeter when I get home.......
mountain eagle
KTM 950SE
my smugmug gallery
Old 10-31-2012, 11:09 AM   #1430
fastdirt505
Oddometer: 70
FMF twins w/o the screens sound awesome. FMF's look to be the smallest too. I can't wait to hear what the Rottweiller sounds like,
Brian
Erzberg SE 950R and a KTM 250SX
http://www.youtube.com/fastdirt505
fastdirt505 is offline   Reply With Quote
Old 10-31-2012, 11:19 AM   #1431
randel
randel's Avatar
Oddometer: 317
Check also wires coming from ignition lock. I had problems with connector behind front mask.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is online now   Reply With Quote
Old 10-31-2012, 01:07 PM   #1432
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
I can't confirm the sound yet, but I HAD to go with a US Forest Service approved set of pipes for my ride. Tis the way in CO and I have heard others that sounded great on on non-se bikes. Aside from the approval I only care about the weight and performance for the most part.
Splisken is offline   Reply With Quote
Old 10-31-2012, 01:15 PM   #1433
Dan950ser
NW Shredder
Oddometer: 497
No complaints on the sound of the fmf titanium q with 2-1 on my se.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR Sale Pending, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 10-31-2012, 03:24 PM   #1434
mountain eagle
terrorist
Oddometer: 2,926
Looks like it was the ignition fuse. Popped a second one to test, lifted the block out and it cleared. No visible damage or short contact. Reassembled and it seems to be fine....... It will now be my first check and I'll be sure to stash a few spares handy.
mountain eagle
KTM 950SE
my smugmug gallery
Old 11-05-2012, 06:20 PM   #1435
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,678
You guys that take your tanks off and on a lot, are you using any kind of quick disconnects for the fuel lines?
Also, are any quick disconnects needed or advantageous with a Safari tank. I hate to spend $800.00 on a gas tank, but I think the Safari is the way to go. With the Rally tank you're still out $700.00.
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Old 11-05-2012, 06:40 PM   #1436
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,852
i done as "powercell" done to his tank sooooooooooo easy now to remove.
i bought my disconnects from ebay
i had a spare tap/petcock to give my mate for a template so he could machine up a pair of stainless (or billet) base plates with the O-ring sealing groove & a female fitting threaded - so the quick disconnect can screw in.
NOTE: when you disconnect them lube the O-rings so they connect easier & not pinch & brake - fuel/chemical rated O-rings are easy to find if you snap/pinch one.
my fuel tap:
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 11-05-2012 at 06:55 PM
veetwo _tls is offline   Reply With Quote
Old 11-05-2012, 07:51 PM   #1437
mountain eagle
terrorist
Oddometer: 2,926
I spoke too soon. Died on the way to work today in rush hour traffic at speed......... unpleasant.
My ignition fuse it blowing. Traced it out to the plug that the headlight area for now.... I'll look into it more when I get time.
As for the quick release fuel, I did the powercell thing too. Quick couplings . net had the best prices I could find. Made the flanges on my buddies mill and lathe. The only change I made was to add a 90 on the left lobe so it didn't stick down so far......
mountain eagle
KTM 950SE
my smugmug gallery
Old 11-05-2012, 07:54 PM   #1438
georgedaman
Oddometer: 123
I took mine off twice yesterday working on the carbs..I also have the Safari tank.
Its not a big deal once you get the hang of it.The OEM set up is fine,The hoses off the tank valves are pretty quick to disconnect,so is the quick connect to the carbs.The fuel pump will slide off the bracket.3 electrical plugs behind the horn cover and you're good to go..
The hardes part seems to be to reinstall the tank and keep the rubber buffers in place...i contact cemented mine and its been through atleast 8-10 removals.
Just a quick thought on the Safari..since i have itand use it. It gives you 5 hours of riding..roughly..Do your friends have Safaries as well? "cause if not,you will have to stop anyway..Can you ride 5 hours straight without stopping?..'cause if not,you'll have to stop anyway..
georgedaman is offline   Reply With Quote
Old 11-05-2012, 09:05 PM   #1439
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,678
I probably don't "have to have" a Safari, but I would like to go out west at some point, and I Think it'd be a requirement for that.
Old 11-05-2012, 09:11 PM   #1440
Splisken
I'm not dead yet...
Splisken's Avatar
Oddometer: 127
Hey Bigbore - if you haven't seen it already check out Ken's (PowerCell) thread on the new larger tank he is making for the SE. Smaller than than the Safari but bigger than stock: http://advrider.com/forums/showthread.php?t=820139 If you just want max range the safari is prolly your ticket but if you want the combo of range and a bit more maneuverability Ken's approach looks golden...and he's making quick disconnects along with Chris from CPR. Granted you can get them elsewhere or craft your own but these guys look to do solid work and Ken rides an SE himself.
Times are GMT -7.   It's 03:40 AM.
