Old 11-06-2012, 11:23 AM   #1441
kanur
cu new er
kanur's Avatar
Oddometer: 753
Originally Posted by bigborefan View Post
I probably don't "have to have" a Safari, but I would like to go out west at some point, and I Think it'd be a requirement for that.
Not just for out west. With the stock tank I found myself way too many times having to turn left when I really wanted to turn right but the small tank wouldn't let me.
Most of my day rides are 200 miles or less so a fill up leaving town and I'm good to go.
Order the Safari and never look back
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 11-06-2012, 12:09 PM   #1442
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,672
I hear you, Where I ride in IL I am never that far from gas, but I know what you mean. Would be nice not to have to worry about it.
How much you got in it? StreetBikeMike
bigborefan is online now   Reply With Quote
Old 11-06-2012, 02:52 PM   #1443
kanur
cu new er
kanur's Avatar
Oddometer: 753
Yep, Never that far away but always in the wrong direction
Old 11-08-2012, 12:54 AM   #1444
CA Stu
CA Stu's Avatar
Oddometer: 47,761
Quick question: Does your SE burn oil?
Edit: Liking it more and more. *roost*
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 11-08-2012, 08:39 AM   #1445
markie_wales
Oddometer: 938
Not really, sometimes 100 - 200 ml top-up between changes at 4,500 miles, depending how I ride it, but usually not even that.
2008 SE with ~12,500 ish miles.
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales is offline   Reply With Quote
Old 11-08-2012, 09:48 AM   #1446
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,665
Yeah. Maybe a half quart between changes. 20K miles on mine.
BENRON is offline   Reply With Quote
Old 11-09-2012, 10:32 AM   #1447
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Nope, at least not in the 2 months I've had it. Have managed a couple of thousand miles thus far. On the other hand, I have managed to run out of gas
07 with 9k miles
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-09-2012, 12:06 PM   #1448
Dan950ser
NW Shredder
Oddometer: 497
Doesn't burn oil. 2007 with 10,000 plus
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR Sale Pending, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 11-09-2012, 07:02 PM   #1449
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,113
Got my Akras today and installed ran around terrorizing neighborhood a little and they sound great !! .....well one at least...see below
Definitely felt some difference
Couple of things; lots of popping on deceleration, and when removing the inserts,
the retaining bolt that holds it in place was slightly spot welded to the exhaust.
They spot weld the flang that holds this bolt and must have slightly got some of the bolt head.
The left one broke loose, the right one didn't, and I striped the bolt.
Got out the dremel and carefully ground/cut off the weld and bolt came out easily.
Then I couldn't get the insert out . So I have one insert in one out. I pulled and tugged and it won't budge.
I had hoped after riding, it might heat up and could get it out...nope. Arrrg ! Not sure what to try next
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy screwed with this post 11-09-2012 at 07:35 PM
pizzaboy is offline   Reply With Quote
Old 11-09-2012, 08:14 PM   #1450
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,750
Not enough to notice between changes... I mean, once in a while I top 'er up a tad, but that's it. 25k on the clock.
traveltoad is offline   Reply With Quote
Old 11-09-2012, 08:50 PM   #1451
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,367
alittle between changes...maybe 1/3 to 1/2 Qt per change,depends how hard its ridden
GO KINGS!!!!(Edit:2 TIME STANLEY CUP CHAMPION KINGS) 00'KX500 (dune wrecker)08'SE ,06'EXC,02'YZF/W,76'04'H-D
92 YJ extreem ,76 CJ 5 sand beast ,07 JK cruiser
dunerat is offline   Reply With Quote
Old 11-10-2012, 05:21 AM   #1452
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Quick Question:
You pull in to a gas station on your SE in the USA. They have non-ethanol 90 octane and ethanol 93 octane, which one do you put in the tank?
Old 11-10-2012, 10:05 AM   #1453
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,926
After you fall over in shock at having found non-ethanol gas I'd be tempted to use that.......
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 11-11-2012, 01:35 AM   #1454
whitehaven
Oddometer: 28
Hey veetwo ,I am interested in setting up the Mik vacuum pump with inline filter and fuel petlock like your system with OEM carbs [950 se] ,however I will be running a Safari tank so do you know if this system will still work as I am thinking the Safari may come down too far and restrict access to the petlock.
I saw somewhere that the Raiddesign system was giving some problems with the Safari.
I am also keen to do the quick disconnect tank fittings as on yours originally described by Powercell but I can not read the letters on the fittings [page 42] what are they and do you still remember exactly where you found them on e-bay.
Any help would be much appreciated as I am planning some desert trips and the vacuum pump seems to be a must do for reliability, or maybe you can also advise me Powercell due to your new large tank design as both of you seem to have this pump and quick disconnect nailed. thanks guys.
whitehaven is offline   Reply With Quote
Old 11-11-2012, 10:22 PM   #1455
CA Stu
CA Stu's Avatar
Oddometer: 47,761
Needlenose vise grips and some leather to grip the insert without scratching it. Try turning it and then pulling.
I did that on my Wings, rode it around the block and immediately put the inserts back in... too damn loud without the inserts by far....
Times are GMT -7.   It's 03:22 AM.
