Old 06-21-2010, 07:43 AM   #1
mgman269 OP
Oddometer: 31
Question US R100GS and Euro ignition switch?
Last year I purchased a euro-spec ignition switch so I could run just the pilot light in the daytime if I wanted, or at least turn off the headlight at my command as opposed to having it "on" all of the time. But when I went to install it, I could not make sense of the wiring, which way to plug in, etc. I tried a couple of combinations, but nothing seemed to work when I operated the switch. Anyone here put one of these switches in a US spec bike? How did you plug the wiring in?
Anybody? Anybody? Beuhler? Any suggestions and I am all ears!
mgman269 is offline   Reply With Quote
Old 06-21-2010, 07:55 AM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,122
When I had a GS, I bought one, unplugged the US version and plugged the Euro right in...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 06-21-2010, 09:31 AM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,888
What year is your gs?
88-90 the colours are
red = 30
green = 15
grey =58
White/yellow =56
exactly the same as the us switch. As solo says there shouldn't be any other differences.
1990 on the lights are switched on using the right hand switchgear - the ignition switches are identical.
Rob Farmer screwed with this post 06-21-2010 at 09:52 AM
Rob Farmer is offline   Reply With Quote
Old 06-21-2010, 09:33 AM   #4
mgman269 OP
Oddometer: 31
1988`
It is a 1988 Blue & White. Thanks.
Old 06-21-2010, 09:58 AM   #5
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,888
The wirings identical to the US switch so it should be plug and play
Old 06-21-2010, 10:17 AM   #6
mgman269 OP
Oddometer: 31
red = 30
green = 15
grey =58
White/yellow =56
Right, that is why I purchased the ignition switch as opposed to the right hand switchgear. Hopefully one night this week I can pull the headlight shell apart (to install my new headlight) and can review why I was confused and report back here.
Old 06-21-2010, 10:20 AM   #7
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,122
Ahhh... I purchased the headlight swich, and not the Euro ignition. For the GS's I thought the switch gear was the standard for Europe, where the G/S's has a different ignition switch?
R65LazaruS
Old 06-21-2010, 11:17 AM   #8
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 1,030
You've got 5 positions on the European ignition switch and it's a real PITA to switch postions while in motion. Much easier to just get the European handle bar switch.
Europeans allow for side lights for parking, no front lights but fog lights, etc. Droive me nuts whenever I drive a car over there. And the Euro ignition switch does the same thing for the bike...way overkill for the States.
Actually on yours, keep the same US ignition switch and swap the green and gray wires..does the same thing.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 06-21-2010, 11:20 AM   #9
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,317
Does that work? My understanding is that it will plug into the GS harness but won't actually do anything because the GS is wired to perform these functions from the key.
Old 06-21-2010, 11:56 AM   #10
mgman269 OP
Oddometer: 31
5 positions?
Can you tell me what the 5 positions are on the Euro switch? They aren't marked and I was unable to get a Euro bezel with the printed marks.
1988 BMW R100GS Blue & White, (now for sale)
1973 Honda CL350 Scrambler mine 6-21-2009 - SOLD Christmas 2013
1964 BMW R50/2 mine since early 1990s, - SOLD
2002 Ural 750 Patrol 2WD - Wow! What fun!
Old 06-21-2010, 12:53 PM   #11
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,122
If it is the case as Anton says above, and the Euro switch does not work on R100GS's, let me know if you want to sell it as it is correct for the R80G/S's for certain.
SL
R65LazaruS
Old 06-21-2010, 01:11 PM   #12
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,888
The 5 positions are:-
1- Off
2 - Parking Lights
3 - Ignition On
4 - Ignition + Side lights
5 - Ignition + Side lights + Main Lights
The Euro early 88-90 Paralever (with the Mono style headlight Pod) has the same switch gear as the US bike but has the 5 position switch.
The later Paralever 91 onwards (with the roo bar) has the same ignition switch as the US bike but has the light off/Side/Main switch on the right hand switch gear on the Euro bikes.
Old 06-21-2010, 01:13 PM   #13
Beemerguru
Beemerguru's Avatar
Oddometer: 1,030
Anton's right on the Euro handle bar switch. They work on later GSs and K bikes only. I confused early and later model G/Ss..when BMW opted for the K bike switch gear for the GS in '91?, then the handle bar swap will work.
I have the Euro ignition switch on the G/S in NC..will be there over the 4th and will post what happens in each position. Thought it would be cool to have it..not true as experience happened.
Just switch the 2 wires
Greg Hutchinson
Old 06-21-2010, 01:18 PM   #14
AntonLargiader
Oddometer: 4,317
...I confused early and later model G/Ss..
Errr, G/Ses with GSes. :)
So is it safe to say:
G/S - uses the euro switch on the handlebar
GS 88-90 - uses 5-position key or swap gray and green wires
GS 91-on - K-style euro switch on handlebar
EDIT: no, this is wrong
AntonLargiader screwed with this post 06-21-2010 at 05:34 PM
Old 06-21-2010, 01:57 PM   #15
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,888
The Euro g/s uses uses the same 5 position switch as the 88-90 GS but there are wiring differences that are shown in the later Haynes manual.
Times are GMT -7.   It's 05:39 PM.
