Old 04-14-2012, 10:04 PM   #1711
beergut
Thumper
beergut's Avatar
Oddometer: 418
So the stock suspension sucks?
My KLR
beergut is offline   Reply With Quote
Old 04-14-2012, 10:05 PM   #1712
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,995
Bluhduh Geez...
No.
Dallara
p.s. - and it's light-years better than a KLR, and I own both...
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 04-14-2012, 11:00 PM   #1713
Firefight911
Firefight911's Avatar
Oddometer: 997
No, it does not "suck." It has some pretty good stuff in it. It suffers from the same problem that all mass produced motorcycles suffer from, trying to bring a motorcycle to the masses with a suspension that some how balances the light, the heavy, the dirt minded, the sport minded, et. al. Kind of a one bike fits all. This requires a compromise all the way around which shows itself somewhere.
Many people find most suspensions very good. In fact, I would wager that the majority of people never give suspension any thought whatsoever. They focus elsewhere. Not a knock, though I have no doubt several here will run with it as such.
Learning suspension basics and then adjusting it is not difficult but pays dividends far beyond the latest ECU flash, pipe, blah, blah, blah. It's just not something that gets its due attention.
Ride Safe, Ride Often, RIDE!!!!
Firefight911 is offline   Reply With Quote
Old 04-15-2012, 03:36 AM   #1714
Dirt_Dad
Dirt_Dad's Avatar
Oddometer: 537
Guilty as charged.
2012 Yamaha Super Tenere Blue
2012 Yamaha Super Tenere Raven
2012 Yamaha XT250
2013 Suzuki DR650SE
Dirt_Dad is offline   Reply With Quote
Old 04-15-2012, 04:04 AM   #1715
creggur
There are no curves here.
creggur's Avatar
Location: Jacksonville, Fl. aka Flatandstraightsandistan...
Oddometer: 277
Is there any STOCK suspension on ANY mass-produced ADV bike that wouldn't be getting a workout in a like-picture? Two-up, with (I'm guessing) loaded panniers since there are items strapped to the top of said panniers, going through a curve with pretty decent banking at speed? Not one I know of...
My Tenere handles two up rides with my wife (combined fully geared weight of about 310 pounds) with no adverse handling issues at all. Could it be better with aftermarket suspenders tuned for such? Sure, but it does just fine. Then again, I admittedly don't push things with a pillion on the back of a bike.
_________________________
Blue '12 Tenere
Originally Posted by scottie boy View Post
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
creggur is offline   Reply With Quote
Old 04-15-2012, 05:00 AM   #1716
bloodline
Oddometer: 293
Wow. Uh, yes, US 129. Front and rear preload cranked to about 3/4 hard. Not sure about the comments. It's nowhere near bottomed or maxed out and the adjustability of the factory suspension is great.
bloodline is offline   Reply With Quote
Old 04-15-2012, 06:14 AM   #1717
avc8130
Oddometer: 1,559
Not "bottomed" or "maxed out" doesn't mean functioning perfectly or properly.
Suspension is very difficult to explain to others. It is truly a case of "the best you know (understand) is the best you've ridden".
I have ridden full aftermarket suspension. It was THE BEST motorcycle experience I have ever had. I still think about it. It gets me giddy just to type about it. I ran to the top of a mountain and professed my enjoyment to all the villagers below. The amount of TRACTION and FEEDBACK was unbelievable. I could FEEL the rear tire donate rubber to the road as I twisted the throttle leaned over on a bumpy road. Leaned over, floating the front wheel, skimming the rear across the pavement? SURE!
I CAN'T WAIT for Penske to finish developing their suspension offering for the S10. I'm 250 without gear. I run a light tail bag. My rear preload is set full "hard". My rear sag is 20mm TOO MUCH. I had to drop the front triple trees 10mm just to get the bike back to "neutral" handling so the front wheel felt more like motorcycle than a boat rudder. When my wife got on for a 2-up ride, we had to return home pretty quick as the bike was borderline DANGEROUS with the resulting geometry. There was simply NO weight on the front end and I couldn't get any feel out of the front end turning.
ac
avc8130 is offline   Reply With Quote
Old 04-15-2012, 08:00 AM   #1718
bloodline
Oddometer: 293
I was referring to the comments made by others in this thread. I'm 185 and my wife is 130. I have no problem dialing up enough preload with full camping gear and 2 up. I still have a fair amount of adjustment left.
bloodline screwed with this post 04-15-2012 at 08:12 AM
Old 04-15-2012, 08:11 AM   #1719
bloodline
Oddometer: 293
I do increase the tire pressure for that load.
Old 04-15-2012, 11:35 AM   #1720
Guateadventure
DreamRider
Guateadventure's Avatar
Oddometer: 18
Mine in Guatemala going to Mexican Border !!!!
Guateadventure is offline   Reply With Quote
Old 04-15-2012, 11:51 AM   #1721
Guateadventure
DreamRider
Oddometer: 18
In Guatemala!!!
Old 04-15-2012, 12:04 PM   #1722
bmac
Oddometer: 372
+1
Even though a couple of folks on this forum would tell you that you live in a fantasy world if you think the stock spring is acceptable for anyone over 175 pounds.
Time to get back to the regularly scheduled program of posting pictures. Great picture by the way..
bmac is offline   Reply With Quote
Old 04-15-2012, 12:56 PM   #1723
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,453
Manual says put 42 psi (2.9bar) in the rear if loaded over 90kg (200lbs). But also says do not load bike with over 209kgs all in.
The rear tyres (69V) are rated to take 325kg (715lbs).
It may be worth thinking about it if you are constantly riding loaded.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 04-15-2012, 01:29 PM   #1724
beergut
Thumper
beergut's Avatar
Oddometer: 418
Originally Posted by Dallara View Post
No.
Dallara
Geeze, did I walk into the wrong neighborhood basketball court? You Tenere guys are quite the feisty bunch. I was just saying it looked awfully close to the ground in the picture. It was a simple question, glad you all feel the way to you. At some point in time, this KLR will leave more to be desired and I am watching the Tenere closely.
p.s. the suspension was one of the first things I changed when I got my bike. Everyone I talk to about getting a KLR, I tell them to plan on a suspension swap. You should too, its well worth it. I recommend the Cogent/Race-tech set-up.
My KLR
Old 04-15-2012, 01:36 PM   #1725
1reddawg
1reddawg's Avatar
Oddometer: 2,295
Da Blu Mule @ The St.Johns River
Current ride
2012 BMW Triple Black GSA
1reddawg is offline   Reply With Quote
Times are GMT -7.   It's 01:13 AM.
