Old 11-04-2012, 10:22 PM   #2791
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Originally Posted by FacePalm View Post
Hey Pluric,
New guy here. Really enjoy your posts as you seem like the same sick SOBs I've been blessed (cursed) with working with throughout my career as a grunt/ LEO.
Coupla Q's for you on the new lights...didja happen to photograph how you wired 'em in to the high beams? Would you be able to comment on the differences between the two available versions ( floods vs. the spots)? Is one better for the road? My main concern is getting a good set of lights that will make me more visible without blinding other motorists. I'm really diggin these.
Oh man, here it goes. Backing up a little I started with a power distribution bar so I
wouldn't have to keep coming off the battery. It's also on a relay control so I can't leave
the heated grips on or other outlets.
http://www.electricalconnection.com/...late-02202.htm
Here is the bar installed. 6 fused power outlets.
Relay location for power bar,
Now for the light bar I wanted it controlled by the high/low beam switch. The high beam
wire is yellow. I traced it down to the wiring block just above the battery inside the round
black rubber cover. (circled) I cut back the wrapped wire harness enough to tie into the
yellow wire. I stuck with the same color to avoid confusion. (arrow) That comes back to the
new relay switch for the light bar. Run a power wire from the power outlet under the seat
and a ground wire and you're almost done. Hook them to the relay and from the relay a
light bar wire to the red and ground the other light wire you should be good to go.
Here is where I mounted the relay for the light bar.
pluric is offline   Reply With Quote
Old 11-04-2012, 10:35 PM   #2792
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Hey Pluric,
I've only had just this style of light. I don't know the difference between it and a flood.
The pattern of the driving style is perfect for what I wanted. I have it adjusted so it's more
like low beam and the brightness is amazingly better than stock. I'm really pleased with
the light, how it fits the bike and the ease of using the OEM switch. At first ir was looking
like a real pain to get the high beam trip wire. I just got lucky when found the yellow wire
in the lower harness.
Depending on how you have the light bar adjusted it shouldn't blind anyone much more than the
high beam. I have not stood in front of the bike to test out how bad it is.
Old 11-04-2012, 11:00 PM   #2793
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Originally Posted by ArmyMedic View Post
Was a great day to get out and ride. Pony Express trail in Western Utah
Can't resist posting the pup....
It really was a gorgeous day. Driving home it was in the high 50s and I just kept thinking
if you have to wear gear this is the perfect temp.
"Pup?" If that's a pup don't get it a saddle yet. It will just out grow it.
I thought maybe Budweiser was missing one of it's wagon pullers.
Old 11-05-2012, 05:00 AM   #2794
Tim
Tim's Avatar
Oddometer: 2,361
Originally Posted by jaumev View Post
Hey Jaumev, I'm trying to work out if your photo was taken at the same place as these? (I think it was on the C-462)
If not, I guess that it must be somewhere in the same area.
This is where we were riding this year and last year.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 11-05-2012, 07:24 AM   #2795
jaumev
jaumev's Avatar
Oddometer: 1,498
Hey Tim.
This is exactly the same place!! Small world.
I live in Vic, near Manresa (see your map). We did a wonderful off road trip from near Barcelona to Andorra. In the way back we took this road and stop to do some pictures of the first snow in the Pyrenees.
I’ve got some videos in this place.. Today I’m going to load them to Youtube.
Did you like the area?
This are my colleagues in there
jaumev is offline   Reply With Quote
Old 11-05-2012, 11:10 AM   #2796
FacePalm
D'oh!!!
FacePalm's Avatar
Oddometer: 25
Wow
Ok, I'm thinking this is a little beyond my abilities at the moment, but definitely a project I wanna tackle.
Thanks for the Pics & Info
FacePalm is offline   Reply With Quote
Old 11-05-2012, 12:58 PM   #2797
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Wow
It's really not hard to do. Forget the power bar and just come right off the battery to the relay.
It's only going to provide power when you switch the high beam on. Electrical Pussy.
Old 11-05-2012, 03:02 PM   #2798
White Tenere
Look a moose
White Tenere's Avatar
Oddometer: 723
Oh WOW! I got a chance to try the new LED light bar out tonight.
Drove up to the cottage tonight. Night being the key word. If you
ride at night all you have to get this light! The difference is amazing.
When I had to turn it off for on coming cars it was like I was driving blind.
Very pleased. I knew the OEM lights were kinda marginal, the light bar
makes them look like candle light.
Just got mine in the mail today, thanks for the heads up on this light...
Its very well made, I cant wait to get it on the bike. Even in the day time it was crazy bright when I did a bench test with it.
White Tenere is offline   Reply With Quote
Old 11-05-2012, 03:51 PM   #2799
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
I can't take credit. I'm sure I've seen it on another thread. I'm just not that original.
You will like it though.
Old 11-05-2012, 03:59 PM   #2800
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,179
Electrical Pussy.
Great name for a rock band!!
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 11-05-2012, 04:21 PM   #2801
FacePalm
D'oh!!!
FacePalm's Avatar
Oddometer: 25
Thanks for that. I just happened to take a swig of Pepsi as I was reading your post.
You ever snorted Pepsi before? Dammit if im not gonna be cleaning that crap outa my keyboard for days.
Dammit.
Old 11-05-2012, 04:25 PM   #2802
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Or a girl friend.
Old 11-06-2012, 08:03 AM   #2803
Tim
Tim's Avatar
Oddometer: 2,361
Hey Tim.
Hey jaumev, a question from my wife - did you see this little guy at the view point?
He was there all alone and she was worried that he had been abandoned. We went back the next day to check on him but he was not there.
And to answer your question if I liked it - I loved it and I am planning a return in May next year - you interested
Old 11-06-2012, 11:00 AM   #2804
jaumev
jaumev's Avatar
Oddometer: 1,498
No, it wasn't there...
Of course I am interested... if you need a guide!! :
Old 11-06-2012, 12:35 PM   #2805
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,831
Aww, those black Tenere owners make the cutest couples. (Sniff, sniff, tear wipe)
Times are GMT -7.   It's 10:28 PM.
