Old 12-16-2012, 10:09 AM   #3391
Desert Dave
Enjoying the moment
Desert Dave's Avatar
Oddometer: 2,737
Originally Posted by pluric View Post
I don't even attempt to get it to
float on top. Do you know how bad that would hurt?
That's the problem I have on this bike, whether it's floating on sand or sideways on a fireroad the Tenere just works so much better on the gas, but highsiding a 600# bike at those speeds is going to be nasty. Hence I often ride like a wuss when I should be on it leading to stupid tip overs. I hear ya.
See what I've been up to! Ongoing Ride Report
Desert Dave is offline   Reply With Quote
Old 12-16-2012, 10:19 AM   #3392
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,794
Originally Posted by Dallara View Post
Looks like white sand...
Dallara
It's almost worse. I don't ski. I do have some snowmobiles, but I'm not a that into them.
Strom hated it....
Quad didn't do a whole lot better,
The good news is it will melt and you can float stuff on it!
And for you Tenere photo Nazis there's a dry docked one in here somewhere.
pluric is offline   Reply With Quote
Old 12-16-2012, 11:37 AM   #3393
true grip
true grip's Avatar
Oddometer: 235
Dallara be careful, Pluric will pull out the bones sticking out of the skin pics. Here is a safe one
This ain't no coon hunt
true grip is offline   Reply With Quote
Old 12-16-2012, 04:28 PM   #3394
simmons1
simmons1's Avatar
Oddometer: 1,512
Right color, wrong bike! LOL
Went out and terrorized the locals with the sounds and smells of yesteryear this afternoon.
Sent from my Droid
Please excuse any typos
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is online now   Reply With Quote
Old 12-16-2012, 04:50 PM   #3395
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,939
Thumb In-Friggin'-Credible!!!
OK... Now you've gone and done it! Pretty much trumped anything in the thread recently.
Kawasaki H2 750 Triple, and a first year one, no less... What appear to be Morris mag wheels, drilled discs with the calipers located behind the fork legs, stainless steel brake lines... and what are those - Denco chambers? Or maybe Spec II?
(edit correction: now that I look closer it appears more like you have a set of Z1R forks on there, along with Z1R wheels, discs, and calipers)
Outstanding, Simmons1. Simply outstanding.
And obviously no stay-at-home garage-queen, but something you ride and no doubt enjoy immensely!
My hat's off to ya'!
Dallara
p.s. - I only wish I could one day hope to ride it... I had an early H1 500, but that was "back in the day"...
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara screwed with this post 12-16-2012 at 05:59 PM
Dallara is offline   Reply With Quote
Old 12-16-2012, 04:55 PM   #3396
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,794
I was going to leave it as it certainly is a beast.
Nice intro Dallara.
Also it's clean and in front of a garage so it fits that criteria as well.
Old 12-16-2012, 05:52 PM   #3397
eemsreno
Oddometer: 961
Missouri Ozark camping trip.
On the bank of the Current River.
eemsreno is offline   Reply With Quote
Old 12-16-2012, 06:03 PM   #3398
simmons1
simmons1's Avatar
Oddometer: 1,512
Dallara
Thanks! I have owned H2's since the late 70's. Most of the one in the photo was bought for $600 in 1985. When it was time to freshen up the old girl I decided that besides the engine, I wanted better brakes and a stock paint job. It was Eddie Lawson Replica lime green previously. After doing some research I found that there were cheap period Kawasaki parts out there that would fit with minor mods so that is what I went with. I wanted the bike to still look like a 70's bike. Although I don't ride it much compared to my modern bikes, it is far from perfect in the flesh and was put together to be ridden for fun and not just looked at.
The whole front end except the front fender is off a 70's KZ650. The front fender is off I believe a Kawasaki Spectre. Front master cylinder is from a Kawasaki Police bike. These were all cheap Ebay parts. The Fly Screen is from an old Buell Lightening and it has period K&N Superbike bars.
The whole rear end is from different year 70's KZ650. The rear shocks are cheapie aftermarket Koni shocks that I believe fit some old Laverda. They are a couple inches longer than the stock length and help get rid of the wobbles. These are cheap ebay parts as well. It also sports period Dunstall rearsets.
The engine is a little more involved. It had roughly 20K miles on it and slipping clutch when it was rebuilt. Right now it has period Denco Stage II drag porting, a Barnett clutch, and runs 34mm flat slide Mikuni's. The chambers are Jemco stingers with the ends cut off and Factory Pipe Product Silencers clamped on. I let the guy that did the engine for me talk me into the porting it has and it is way over ported for street use. It was actually no fun to ride as it had zero bottom end. That was fixed with some simple custom reed valves a buddy of mine makes. They fit right in the intake ports and can hardly be seen. They are not exactly high performance reeds but work great for a fun weekend street bike. It is now a very rideable street bike.
The electronic ignition boxes are getting old and fragile. Since this bike is far from stock I replaced the CDI and regulator rectifier with modern parts designed and built by a couple H2 aficionados. This set up allows me to run with no battery.
I guess I need a picture, this one was taken at RTB III:
Old 12-16-2012, 07:54 PM   #3399
Reverend12
Well there it is..
Reverend12's Avatar
Oddometer: 1,458
That 750 is freaking beautiful...
Reverend12 is offline   Reply With Quote
Old 12-16-2012, 09:10 PM   #3400
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,704
Fell in love with the Super T at the Seattle Cycle show.
West - "Oeste Sanchez"
RideAbout screwed with this post 12-18-2012 at 09:32 AM
RideAbout is offline   Reply With Quote
Old 12-16-2012, 09:19 PM   #3401
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,794
All nice shots. I really like bike camping too.
Old 12-17-2012, 12:43 PM   #3402
snakebitten
Small Town Hick
Oddometer: 963
BIGFOOT!!
Much easier to mount now too. I'm old, heavy, and far less limber. I just walk up and climb the steps. :)
And the fold up much easier than the oem stalks. Physics, i guess.
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 12-17-2012, 01:05 PM   #3403
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,794
Were they out of floor boards?
Old 12-17-2012, 01:27 PM   #3404
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,170
Originally Posted by snakebitten View Post
BIGFOOT!!
Holy shite! Those are some BF pegs!!
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 12-17-2012, 01:28 PM   #3405
DaFoole
DaFoole's Avatar
Oddometer: 4,170
eemsreno...very nice shots!!
Times are GMT -7.   It's 11:03 AM.
