Old 01-21-2012, 12:28 AM   #2086
jaumev
jaumev's Avatar
Oddometer: 1,498
Originally Posted by Wasp View Post
Woody from Woody's Wheel Works is currently working on a 21" front and 18" wheel replacement which should be ready in the not too distant future. We should be testing soon.
I am confident that 21" with a 90 section tire would make this thing killer in the dirt.
Greg.
Thanks!. I didn't see any information in his web.
I agree with you, shame Yamaha don`t built a true Adventure version with better suspensions, and these size of wheels.
But how can it works in road?
jaumev is offline   Reply With Quote
Old 01-21-2012, 08:44 AM   #2087
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,295
Greg.
I would be interested in this, as I have been wanting two wheel setups, one dirt, and one street. Good news for sure!
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker is offline   Reply With Quote
Old 01-22-2012, 05:35 AM   #2088
jaumev
jaumev's Avatar
Oddometer: 1,498
The problem to use easily these two setups is you have to make a lot of modifications to do if you want the 21" wheel: front fender, front brake hoses(?), centre stand extension... so I doubt we change the wheels often, dont you think?.
In order to do something more simple to increase the floor clearance I don't know if we can do anything to rise the front of the bike and put some links in the back. What do you think?.
Sorry perhaps I have to put these questions in the general forum??
Old 01-24-2012, 01:18 AM   #2089
jaumev
jaumev's Avatar
Oddometer: 1,498
Hi again
Finally I decided change the GSA for the S10. I use it for 90% on off road and I am convinced the Yamaha is better in it.
Do you think if we put the link in the rear suspension the transmission (cardan?) could suffered with the different angle?
My idea is try first only with the 3,5 cm link and if is necessary change the wheels.
Old 01-24-2012, 03:30 AM   #2090
Wasp OP
Supa10 pilot
Oddometer: 1,062
Originally Posted by jaumev View Post
Hi again
Hi jaumev.
I manufacture 1" raising links (wouldn't go much shorter) and distribute them through motorradgarage: http://www.motorradgarage.com.au/cat...oducts_id=1160
The price shown is including Aussie 10% gst which is removed for export. Contact mike at info@motorradgarage.com.au
I have been using links on my bike for about 12000kms now and would not be without them. I never had a problem with "casing out" prior to installing the links but I was riding a bit easier then as I identified that as a "must-do-mod" and got straight onto them. Certainly haven't had a ground problem since.
I did have a set of Heidenau's fitted for about 6000kms - 140 rear instead of 150 rear, and 100 front instead of 110 front... Made a HUGE difference to how the bike handled in the dirt. Much more direct and less floaty than the larger knobbies.
Greg.
The original WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=595933
The NEW "Long Term" WaspWorks S10 detail & evolution thread:
http://www.advrider.com/forums/showthread.php?t=778809
Wasp screwed with this post 01-24-2012 at 05:12 AM
Wasp is offline   Reply With Quote
Old 01-24-2012, 11:17 AM   #2091
jaumev
jaumev's Avatar
Oddometer: 1,498
Hi Greg, thanks for the answer
We are a group of crazy guys using GS to cross Spain, Portugal, Morocco… always on the dirt and better if it's a difficult track. www.transiberica.info
Yamaha Spain gives me the opportunity to try a whole day a ST because they want me to use it in our next trip.
During the test I realize the main problem for my use is the ground clearance, I’m afraid they need to change the skid plate after my ride, it was destroyed!! I know some people can say “these bikes are not for that” but we like these kind of challenges.
My GSA with enlarged Technoflex suspension it’s about 2” higher than the ST. It is also a bit shorter between axles and even like this sometimes I get stuck. That’s why I’m not sure its going to be enough with your raising links.
Any suggestion?
Thank you very much
Old 01-24-2012, 08:11 PM   #2092
GrahamD
GrahamD's Avatar
Oddometer: 5,308
Any suggestion?
Thank you very much
KTM ?
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 01-25-2012, 01:06 AM   #2093
jaumev
jaumev's Avatar
Oddometer: 1,498
Originally Posted by GrahamD View Post
KTM ?
Good suggestion.... but i think it needs a renoval, and Yamaha makes me a very good offer.
Old 01-25-2012, 03:53 PM   #2094
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 309
You can add a proper bashplate to the S10, like the SW Motech or the H&B ones. They can take an uge beating and act as a sliding base
Ze_zaskar is offline   Reply With Quote
Old 01-26-2012, 01:51 AM   #2095
jaumev
jaumev's Avatar
Oddometer: 1,498
Yes, it is essential. The OEM bashplate it’s just decorative.
Tomorrow I give my old GSA to the new owner and I hope next week to have the S10.
I’m thinking to buy Wasp’s raising links and see if with this is enough.
Later perhaps I’m going to try the 21” front wheel, it’s better in off road and raises 1” the bike.
Do you think It’s ok a combination of 21” front wheel with the original rear 17" if I have the links?
Greg, what about the high guard? Are you thinking in commercialiced? It looks great!
jaumev screwed with this post 01-26-2012 at 03:52 AM
Old 01-26-2012, 01:51 PM   #2096
GrahamD
GrahamD's Avatar
Oddometer: 5,308
Do you think Its ok a combination of 21 front wheel with the original rear 17" if I have the links?
Your suggestions seem to work OK..
Cheers
Graham
Old 01-26-2012, 03:12 PM   #2097
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,398
21'' wheels for Super Tenere...
hi greg and the rest of you,,,
regarding the front wheel,,,it sounds like the need for the Traction monitoring sensor ring is not a big deal to some of you and to others it is..perhaps some feedback is in order....
FYI,,,we originally thought we'd just use the Supelite hubs developed for the HP-2 and GS 1200 seies bikes with a disc adapter kit there's a possibility it won't fly because the bolt circles and number of bolts ktm [6 on 145 versus yamaha 5 on 150mm] may just over-lap each other...
the Superlite I hubs were developed to get the lightest disc/hub package ..converting the disc to a KTM-950 with Galfer wavy/floating rotors turned up the best/lightest combination especially when combined with the Galfer green pads...
if most of you want to save $$$ and re-use your oem discs,,well it would be aesthetically and technically simpler to use the basis of the Superlite I hub and widen it 10 mm and use the yamaha 5 x150mm BC ..
OBTW does anyone know what diameter/pitch of the disc mounting bolts are???,,,i would assume 8mmx1.25 or 6mmx1..
the wheel would similar to this.... a 1.85 double sig Excel we could go narrower ,,my experience is that the 1.85 is better all around
please give me some feedback...
holler ,woody
PS,,hope this doesn't qualify as spam,,if it does i'll delete immediately and move it to vendor section
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 01-26-2012 at 09:21 PM
Old 01-26-2012, 06:49 PM   #2098
GrahamD
GrahamD's Avatar
Oddometer: 5,308
I just see the post as useful problem solving.
Thanks from me. Good to see some of the Niche stuff coming along.
Old 01-26-2012, 07:11 PM   #2099
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,728
Woody, for me--the traction control in the 17/19 setup is important--however, if I was doing riding that required the 21" then I'd have it switched off--not necessary from my seat.
MoBill is offline   Reply With Quote
Old 01-27-2012, 03:22 AM   #2100
jaumev
jaumev's Avatar
Oddometer: 1,498
Wasp, Im not sure this is the right post to talk about this, if not please tell us and I open a new one in the general forum. Thanks.
Woody, the combination of my bad english and limited technical knowledge makes me difficult to understand your answer but I think you mean a 21 wheel disabled the traction control?. If yes, its a pity. I was very impressed how it works in the S10. I dont like electronics but in this case it really works well even in the dirt.
Graham, the S10 form Francesco Catanese its great but what a budget!! Only the suspensions must cost a fortune. I like it a lot but its too radical for me, also I prefer two front discs Pity Yamaha dont built a R version more dirt orientated instead a bunch of stickers like the Worldcrosser. But i also like to fly with big cows: this photo was taken in a motor show near Barcelona last year, whe had a great time: 10 BMW GS with old guys jumping full gas!!
Times are GMT -7.   It's 06:13 PM.
